Old 02-27-2014, 08:16 AM   #1289
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by Justkiz View Post
Would you mind sharing some pics of the set up in your car? I just can't make my head around to see any space to get plumbing behind the turbo.
isn't the dump pipe too low for metal skid plate if it is though below the pulleys?
I didn't put the metal skid plate back on.
I don't have any pics to share. I don't plan on climbing underneath for quite some time (changed the oil last week).
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 02-27-2014, 09:44 AM   #1290
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
I cut a hole of 3x3 inches for the dump pipe and issue resolved
I love boost!!!!!!
Old 02-27-2014, 10:59 AM   #1291
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
I just returned from reviewing this with the shop doing the work for me and there is no way that the recirc tube can take the same path as illustrated in @ecko04 post, mainly because I have the EL manifold and he is using UEL. There just isn't enough clearance between pulleys and collectors, regardless of whether it is catted or uncatted. The angle of the collector positions it about 3/4 - 1 inch away from the pulleys. Here is a snapshot of another members dump tube so you can see the clearance issue, and his is uncatted.
So, we are going to take another less direct route. We are going to bring it all the way down and route below and in front of the collector, and then bring it back up slightly to get the correct angle to the downpipe. I will post some pics of it once they finish the work and comes back from the coaters. It won't be pretty and is less than ideal, but should do the job...
pixel67 is offline   Reply With Quote
Old 02-27-2014, 11:05 AM   #1292
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
FA20Club Turbo Kit Owners Topic
Mine is UEL? Well hot damn, I never realized it. I certainly ordered EL. Might have been the recirc option that forced the change.
Old 02-27-2014, 11:07 AM   #1293
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
U really didn't realize that? I can't tell if ur trolling or not lol
lbroskee is offline   Reply With Quote
Old 02-27-2014, 11:11 AM   #1294
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Yep, definitely trolling. That's the running trend on the forums these days.
Seriously, I didn't realize it. I didn't check. I slapped it on the car the same day FedEx dropped it off.
Old 02-27-2014, 11:23 AM   #1295
lbroskee
lbroskee's Avatar
Oh ok. Looks lik it worked in ur favor tho. U get the boxer rumble and recirculated wastegate
Old 02-27-2014, 11:54 AM   #1296
pixel67
pixel67's Avatar
Just in case anyone is looking, i have a few parts up for sale in the members classifieds:
Turbosmart Dual Stage Boost Controller - New in Box for $200.00 shipped.
ATI 52MM/60MM Conversion Ring - $15 shipped
Old 03-05-2014, 10:14 AM   #1297
pixel67
pixel67's Avatar
I have updated the OP in light of the recent events over the last few months. I have removed some links and rearranged sections to the reflect the current status of FA20Club as a (non) participating vendor in these forums. Going forward I may not post as much in here as i used to but I will continue to visit from time to time. Please PM me with any edits/deletes/additions you would like to see.
Old 03-07-2014, 11:10 AM   #1298
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
FA20Club old intake charge pipe
3", x2 45 degree bends, MAF flange on a bend which creates partial throttle cruising issues
FA20Cluv new intake charge pipe
2.75", 90 degree bend, MAF flange on a straighter section to create less turbulence. Not perfect but better.
Old 03-07-2014, 11:17 AM   #1299
pixel67
pixel67's Avatar
Looks good! How much did that set you back? I am interested in seeing if it helps your issue.
Old 03-07-2014, 11:25 AM   #1300
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Well it took awhile to get this made and @ptuning finally eliminated the cruising and partial throttle fuel trim issues. That intake pipe is slated to be delivered today, but I don't need it anymore. The issue with my desire to install it will be that it will require a retune. I'll probably install it sometime in the spring/summer.
The cost was $164
Old 03-07-2014, 11:29 AM   #1301
lbroskee
lbroskee's Avatar
Attachment 69510
Attachment 69511
Sucks that smaller pipes tho
Old 03-07-2014, 11:33 AM   #1302
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Your statement is incorrect.
A 3" charge pipe for this car was only done so one could run a MAF based tune only. That was way before EcuTek updated their racerom to include speed density.
Now with speed density, there is absolutely no need for a 3" charge pipe and the better tuning option would be one that is MAF based for light and partial throttle conditions and switches to speed density when you put your foot down.
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 12:48 PM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 01:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 09:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 02:26 PM
