Old 03-12-2014, 03:08 AM   #29
suaveflooder
Looking great so far!!
suaveflooder is offline   Reply With Quote
Old 03-12-2014, 04:00 AM   #30
troek
troek's Avatar
Drives: 2012 Toyota 86
it will definately draw air out of the engine bay. even just a hole with no ducting will draw some air out, as the air rushing over the outside of the car would create a low pressure area and draw some air out, there is a word for this effect but i forgot it. plus, the engine bay will be some what of a high pressure area with all the air being forced in through the grill. robispec has done some work with this.
troek is offline   Reply With Quote
Old 03-12-2014, 04:05 AM   #31
ZionsWrath
Thanks
ZionsWrath's Avatar
Why not just cut and put new vent? What is the point of a duct? From what I've seen under the hood there isn't anywhere for the heat to go really so just opening a hole would be enough.
What benefit would ducting provide over just a replacement functional vent with a cut hole behind it?
Old 03-12-2014, 04:07 AM   #32
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by mokinbird87 View Post
So yea... The ducting thing.. I'm gonna have to find the optimal size and the route. I'm imagining the main part to be body colored and then the rod part be either carbon fiber or aluminum.
Would rather the whole thing look like the stock BRZ part, just the black plastic bit as an actual vent.
Old 03-12-2014, 04:11 AM   #33
Eminent Performance
Eminent Performance's Avatar
Drives: 2013 Scion FRS
Hmm, without some CFD at least, the heat escaping may or may not be effective. If you have access to get your model 3D scanned, I have a friend with a 3D printer in SoCal. And I also have a few major carbon / fiberglass manufacturers that could produce your product privately.
Hope I don't come off as too "sales-y" but I have a few personal ideas for aero I am working on and wouldn't mind sharing my connections. No pressure though! Just throwing it out there. PM me for info.
Eminent Performance is offline   Reply With Quote
Old 03-12-2014, 08:05 AM   #34
z3ro
Does all this low pressure/high pressure talk mean its gonna rain?
Sent from my SCH-I545 using Tapatalk
z3ro is offline   Reply With Quote
Old 03-12-2014, 08:08 AM   #35
ZionsWrath
Thanks
ZionsWrath's Avatar
[ame="http://www.youtube.com/watch?v=NeUrIA64ZOI"]Family Guy-Ollie Williams as a weather reporter - YouTube[/ame]
Old 03-12-2014, 09:02 AM   #36
FR-Slide
Drives: 13 Whiteout 6MT
This is what I was trying to bring up earlier; I THINK the best layman's explanation would be Bernoulli's principle, but I'm not really up to date on my dynamics anymore. Essentially, the air being pushed (or, rather, PULLED) out doesn't care about the shape or path so much as the fact that there is one at all. That's why I figured that a simple hole via hole saw or something would be sufficient to vent out most of the hot air.
The duct would potentially allow for waterproofing or at least protection from water/debris. Although, unless you spray a hose directly into the vent, I don't see much getting in there anyway. It would also definitely look more finished/professional. Would also add quite a bit of steps to manufacturing (and cost)...and weight!
FR-Slide is offline   Reply With Quote
Old 03-12-2014, 09:07 AM   #37
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
not so much a word, but a law - Bernoulli's
@FR-Slide got to it before me.
Old 03-12-2014, 09:09 AM   #38
cslntuee
Drives: Subaru BRZ Limited
HI,
I like the fender panel can come with BRZ Ts or BRZ STI concept type trim
(clean, simple and little bit more aggressive than the stock one)
with mesh grille.
ps. I personal prefer the chrome trim instead of the silver.
Thanks.
cslntuee is offline   Reply With Quote
Old 03-12-2014, 09:14 AM   #39
sshole
Doesn't Bernoulli's principle ignore boundary layer separation? Although, thinking about it, even with boundary layer separation, you'd still have a pressure differential across the face of the vent...
Carry on.
sshole is offline   Reply With Quote
Old 03-12-2014, 01:27 PM   #40
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
will get in touch with ya. thanks!
mokinbird87 is offline   Reply With Quote
Old 03-12-2014, 01:46 PM   #41
dirtymax
Gold Member
dirtymax's Avatar
Drives: 14' SWP BRZ MT limited
I want one of these so bad. I hate the fake piece on there now, way to much visual stuff going on for such a small piece on such a "clean" car. My vision would be just a plain mesh with no trim though the middle to keep it clean. But I'll take what I can get
I think this would be great for the forced induction guys producing lots of heat in an engine bay that it so buttoned up.
dirtymax is offline   Reply With Quote
Old 03-12-2014, 01:52 PM   #42
sirisvirus
Drives:
👍 can't wait to see final product
Sent from my Subaru BRZ Limited using plastic cup 2.0
sirisvirus is offline   Reply With Quote
Vent Side Marker MaximaZero Cosmetic Modification (Interior/Exterior/Lighting) 28 02-23-2014 03:09 AM
BRZ Side Vent Trade woode NY / NJ / CT / PA 4 12-31-2013 12:01 PM
Side vent change Andrew_FRS_DD Cosmetic Modification (Interior/Exterior/Lighting) 1 07-12-2013 06:33 PM
frs side vent lavisxice Cosmetic Modification (Interior/Exterior/Lighting) 7 04-02-2013 09:54 PM
Side Vent Swap? Allankh CANADA 0 12-19-2012 03:26 PM
