Old 03-12-2014, 07:59 PM   #1093
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Yep. @CivilXII is planning to buy one, and I am hoping to help him install it locally. Trying to guide him in his decisions of supporting mods as well.
Sweet, I'm hoping to pull the trigger on a kit with GTX3076 upgrade, built block and the works, saving up as we speak, aiming for 450whp on 91 octane
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 03-12-2014, 08:01 PM   #1094
Brody602
Drift King
Brody602's Avatar
Originally Posted by Ironsquid View Post
FA20Club
Yeah still trying to figure out if I should go with FA20Club or FBM for my turbo and built block.. I hear FA20Club has outstanding work/ performance and top notch customer service..
Old 03-12-2014, 08:01 PM   #1095
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Im close to that now stock block no knock with the 35r just sayin.
Ironsquid is offline   Reply With Quote
Old 03-12-2014, 08:03 PM   #1096
Brody602
Drift King
Brody602's Avatar
How much boost? And do you think i'll be able to get that 450whp mark with a built block?
Old 03-12-2014, 08:03 PM   #1097
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Do you still assert that stupid clutch Russell had is a good choice?
wat you talkin bout? I told him that his clutch won't last long at the 9 to 14 PSI he wants to run. I told him if he really wants to keep the stock clutch then he is going to have to run less boost. I still recommend the ACT clutch/flywheel as the best value.
Old 03-12-2014, 08:04 PM   #1098
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Only if you live in South Florida, and even then it is only a 50/50 shot.
Old 03-12-2014, 08:08 PM   #1099
Brody602
Drift King
Brody602's Avatar
@Ironsquid I plan on getting the GTX3076 with a .63 A/R backhousing, 0.63 to try and minimize lag and to try and make it about on par with the GTX28
Old 03-12-2014, 08:10 PM   #1100
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
13.5 psi
Built block gives you more tolerance to knock conditions. Doable/Probable. Especially if you do the "timing" trick.
Usable 450 everyday on 91octane might be a little hard without the extra VE a 35r brings.
Really depends on your compression and headwork if you plan on 450 on 91 oct
Old 03-12-2014, 08:14 PM   #1101
Brody602
Drift King
Brody602's Avatar
13.5 psi
Sorry, not the most knowledgeable around this stuff, what's VE? And I don't know if I want to go any bigger than the GTX3076 due to lag..
Also, what's the timing trick?
Old 03-12-2014, 08:19 PM   #1102
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Volumetric efficiency. I will let @Ironsquid handle the "timing" trick.
Old 03-12-2014, 08:25 PM   #1103
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Disabling knock correction and turning the timing up for a glory number dyno run.
Highly not recommended, but will give you extra numbers.
Old 03-12-2014, 08:28 PM   #1104
Brody602
Drift King
Brody602's Avatar
That sounds like something Toni would do... LOL
I think I'll stick with the GTX3076, because like I said, I don't want a lot of lag, so I guess whatever numbers I get will be the ones I'll have to settle for, planning on getting it tuned by FBM
Old 03-12-2014, 08:34 PM   #1105
Dipstik-sportech
Dipstik-sportech's Avatar
Highly doubtful on Canadian 91 pump and if it did it wouldn't last long
The Frozen North
Old 03-12-2014, 09:06 PM   #1106
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
For what it's worth the 35r isn't laggy at all on this compression. It would be easier to hit your target as well.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
