Old 01-16-2014, 03:15 AM   #155
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Hmmm
[ame]http://youtu.be/52Yyo5s9HgQ?t=41m35s[/ame]
that specialized breaking in by nissan for their GTRs .. proper warm up + high revs = win
and yeah i dont like the babying idea too much - definately rev her up throughout the entire band
Old 04-03-2014, 07:53 PM   #156
GotMunchies?
Drives: '14 WRB BRZ 6MT Limited
Originally Posted by sero901 View Post
not to add to the controversy on an old thread but pistons are slightly off circle when cold. Im a aircraft mechanic and when we measure tolerances for pistons going into an engine, they are slightly elliptical. whether they are for this car or not i don't know but i do know there are pistons when become circle and seal better when at operating temperature.
Are you measuring radial run out on the piston relative to the cylinder axis? What kind of measurements do you see? If its anything up to two or three thousands of an inch, I wouldn't consider that "intentionally elliptical," and could arguably be within acceptable manufacturing tolerances.
If I get a round part back from grinding and its within .05 - .07" on runnout, I dance a jig.
Source: Tooling engineer for aerospace industry.
GotMunchies? is offline   Reply With Quote
Old 04-05-2014, 03:42 PM   #157
sero901
sero901's Avatar
Drives: 2014 Scion FRS
Couldn't find it in the Lycoming manual but i did find a pretty good description in a automotive text book.
Check out expansion controls on page 256.
http://books.google.ca/books?id=vcMW...page&q&f=false
sero901 is offline   Reply With Quote
Old 04-07-2014, 01:49 PM   #158
GotMunchies?
Unfortuantely, I don't have access to that. But I used "Expansion Controls" as a search term and stumbled on this:
http://www.waybuilder.net/sweethaven...Num=3&modNum=1
For the curious, this offers some interesting information on the design of automotive pistons. Thanks for pointing me in the right direction, @sero901
Old 09-10-2016, 02:18 PM   #159
Shinchu
Shinchu's Avatar
Drives: 2016 FR-S Asphault MT
Soooo im about to hit 4k on the odo. Original oil. When do i go get it changed?
Other than that i did a nice break in rarely over 6k rpm for the first 1k miles. Ive been gentle but now im hesitant to flog on old oil.
Also hesitant to bring to dealer for change as its a lease with full perrin intake and coilovers. Stupid? Maybe. Fun? Hell yes.
TEAM HINGA | Shift-Lock.net | Club4AG
http://www.poweredbymax.net/
Shinchu is offline   Reply With Quote
Old 09-10-2016, 04:52 PM   #160
What does your service manual say?
Old 12-17-2016, 01:01 PM   #161
~el~jefe~
Drives: 2019 MX-5 RF
If someone read this thread, and followed 3/4's of the suggestions, they would have a nice bucket of crap metal.
1. 0-20 oil is better than heavier oil. Lighter oil gets to the parts faster and the beginning of a car starting is where the wear is. This is why they are spending billions on engineering over course of a century. 0-20 represents machining and engineering at its finest.
2. Your car engine already has many miles on it. It already had its oil changed before 0 miles on the odometer.
3. this is not 1984 and you are not racing rebuilt street bikes designed to have 1000 miles on them and then crash into a wall.
4. 4000 rpm is your max. Because the engineers are engineers and you are not. Neither is anyone in the links. Also, you are not a group of 200 Japanese mechanical engineers.
this thread should be deleted and people should just follow the instruction manual.
~el~jefe~ is offline   Reply With Quote
Old 02-25-2019, 11:10 AM   #162
chipmunk
Drives: _
I'm getting a new engine under warranty. So I have to resurrect this topic.
What role does ZDDP play to help break-in? I'm thinking either a ZDDP additive, or replacing with High Mileage Mobil 1 0W-20 with 800-900ppm zinc & phosphor within the first 100 or 200 miles.
chipmunk is offline   Reply With Quote
Old 02-25-2019, 11:55 AM   #163
Do not use additives the idea of break in is actually to create some wear where you want it.
Use the recommended oil it is what the car was designed to use.
Follow the break in instructions in the owner manual they know what they are talking about.
No need to get inventive El Jefe nailed that part back in 2016.
Old 02-25-2019, 12:08 PM   #164
chipmunk
Drives: _
Last time I followed the manual break in procedure, there was some oil consumption issue. That is what eventuslly led to this whole engine replacement. A quart of oil every 2500 miles shouldn't be normal.
Old 02-25-2019, 01:06 PM   #165
Well do what you want then. You asked I answered. Just wait for somebody that says what you want to hear. They will eventually.
Old 02-25-2019, 01:18 PM   #166
chipmunk
Drives: _
Given the arguments going on all over the forums, it won't be long before I hear what I want to hear. But I don't know what I want to hear. I have not seen (m)any credible technical sources with objective evidence. Obviously the argument "they're already broken in at the factory " will not apply to me.
Old 02-25-2019, 01:31 PM   #167
OK, chipmunk, do whatever you want to do.
I have no data to support that.
There ya go -
Old 02-25-2019, 01:39 PM   #168
chipmunk
Drives: _
That is an infinite loop I can never get out of!
Tire +/- size guide for FR-S/BRZ SpeedR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 12-11-2016 01:12 PM
Best Break-in Procedure xantonin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 198 02-11-2015 05:40 PM
Break-in question Baldeagle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-31-2012 03:28 PM
Break-In Period UriarteMD Scion FR-S / Toyota 86 GT86 General Forum 10 03-29-2012 04:26 AM
Feature Guide slizoth Scion FR-S / Toyota 86 GT86 General Forum 4 01-19-2012 09:32 PM
