Old 03-27-2012, 12:51 PM   #71
Calum
That Guy
Drives: 2013 asphalt FRS MT
Sorry for the lack of details! We'll spill the beans soon.
- Andrew
What's the hold up, are the non-disclosure agreements not expired yet?
Old 03-27-2012, 02:08 PM   #72
Nothing like that, just a lot of things going on at once!
- andrew
Old 03-27-2012, 03:14 PM   #73
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Hmm.. The slippery slope..
Springs..
Then plates for camber.
Then sways to compensate for the longer roll moments..
and the car becomes more knife-edged...... Hmm...
Old 03-27-2012, 03:42 PM   #74
zoomzoomers
zoomzoomers's Avatar
The car looks awesome! Even better since I ordered the SWP! Thanks for the post. Can't wait for more info. And here I was planning to keep everything stock.
Old 03-27-2012, 04:06 PM   #75
kayen
Drives: 2002 WRX w/ STi Spec C Swap
Send a message via AIM to kayen
RCE is definitely making it difficult keeping the BRZ stock lol. I have to try though, I want to run Stock Class AutoX, until either KW or AST Coils come out to jump to a Street Touring Classification.
kayen is offline   Reply With Quote
Old 03-27-2012, 04:22 PM   #76
KevinDuMa
Drives: 2004 Honda S2000
Looking sweet...and it's in SWP it's meant to be!
KevinDuMa is offline   Reply With Quote
Old 03-27-2012, 04:37 PM   #77
BRZ
Drives: SWP BRZ
i love the drop, but i'm really wondering how smooth it drives with it....
BRZ is offline   Reply With Quote
Old 03-27-2012, 05:08 PM   #78
skeeler
skeeler's Avatar
Drives: Miatas of Various Kinds
Originally Posted by 7thgear View Post
How it affects camber/toe/caster will be dependent on the car's particular geometry.
In the case of MacPherson struts, deviation from OEM typically creates positive camber, requiring camber plates, ball-joint extenders, lower control arm extenders, crash bolts, or a combination of those things.
Double-wishbone setups typically are not as sensitive to lowering from an alignment point of view, but there are other funky things that happen...
The camber loss under compression is probably my major concern with this car. My other cars are wishbone/wishbone or wishbone/multi-link, so they experience camber gain. Some say the struts shouldn't be a problem, even in an autocrossed or tracked car, but I'm still worried.
DD & STR: 2009 Miata. DD & HPDE: 1995 Miata. Sold: 2004 Mazdaspeed Miata, 1991 CRX, 1977 280Z.
skeeler is offline   Reply With Quote
Old 03-27-2012, 05:24 PM   #79
Draco-REX
Corner Junkie
Draco-REX's Avatar
Many people do quite well in MacPherson strut cars. Subaru likes to use long control arms, so camber loss is minimized. If you consider the range of motion you're likely to encounter, especially in modded form with higher corner rates, the loss of negative camber will not be that great.
Old 03-27-2012, 05:42 PM   #80
OrbitalEllipses
Drives: Attitude
Aw yeah, made the front page.
Are stock class SCCA autocross rules that you can now change the rear OR front swaybar? Bumping up to a stock STI bar may be a very cheap and effective upgrade for that crowd, as previously stated. Hm, I need to research autocross clubs around my area...
Old 03-27-2012, 05:54 PM   #81
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
worried? what do you mean worried
worried as in how do i tell my wife i have aids worried?
the only thing MacPherson struts are going to do in place of a double wishbone is change the way you approach car setup.
Old 03-27-2012, 05:57 PM   #82
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Looks good but...
(my italics)
"One thing we noticed is that the car has a fairly low roll center and if the car is lowered much at all the lower control arms will point upward with the roll center quickly ending up below ground. This will do two things that are not so great; the car will have a large roll couple and a strong tendency to roll which must be countered with stiff springs and/or swaybar."
"Whiteline if you are reading this, this car really needs your long shank ball joints and tie rod ends to correct the roll center."
http://www.motoiq.com/magazine_artic...cion-fr-s.aspx
Old 03-27-2012, 06:08 PM   #83
Turbowned
Turbowned's Avatar
If it's not draggin' frame, it's not low enough bro d00d!
But seriously, that looks just about right! Too bad I'll be going with coilovers...
Anyone else notice this? If that's a Limited, that's about 60-70lbs below target! - EDIT: This is apparently without jack & tools, but usually manufacturer's listed weight is dry weight, so 2762 for a Premium and ~ 2780 for a Limited (before fluids?), and this is showing 2714 with full fluids and no jack/tools (13 gals of fuel weighs about 65lbs, for reference). That is AWESOME!
Old 03-27-2012, 06:12 PM   #84
dsgerbc
Drives: BRZ(sold), STI
Looks good but...
(my italics)
Oh, thanks. I remember I read something about roll center in a BRZ but couldn't remember where. So I'm definitely waiting to lower before WL comes up with longer RCK and then some, for a second revision of those
First iteration of the original WL RCK wasn't too durable.
Did anyone try these? Looks more adequate.
Freed Engineering custom metal fabrication and parts development bFreed Announcements, Contests, Giveaways 23 03-24-2012 04:35 AM
Any thoughts on my "mini" engineering and business plan.? KidWonder Off-Topic Lounge [WARNING: NO POLITICS] 24 12-29-2011 02:16 PM
BRZ engineering video shown at Tokyo Motor Show. Japanese translation needed please. tranzformer BRZ First-Gen (2012+) — General Topics 16 12-16-2011 06:50 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 01:52 PM
$95 Track Day@Willow Springs March 11 Louie Southern California 0 01-23-2011 02:38 AM
