Old 06-02-2014, 09:39 AM   #1765
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
Drives: '13 Asphalt FRS MT
i second this^ seems like these fans are the only weak point on this kit. @Reaper & @carlossanchez89 Did you have the Ceramic coating and the heat wrap on, and still had the fans crap out?
FRS_FIEND is offline   Reply With Quote
Old 06-02-2014, 09:48 AM   #1766
Dipstik-sportech
Dipstik-sportech's Avatar
I don't get why people are having fan issues. Mine are over a year old and I'm not nice to my car and they still work fine
The Frozen North
Old 06-02-2014, 09:56 AM   #1767
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
@Dipstik-sportech
"The Frozen North"
I think your location has a lot to do with it? lol im playing
Nah but im betting you got the ceramic coating and thermal wrap and turbo blanket? I'm sure that helps the fans avoid some of that downpipe and turbo heat. Im no expert, but logically thinking that should be super beneficial. I intend on getting ceramic coating, thermal wrap, and turbo blanket options when i get my kit end of july.
Old 06-02-2014, 10:38 AM   #1768
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Dei thermal wrap, ceramic coated, ptp turbo blanket, 80*f ambient temps, 8qt oil pan and car has never ran hot. Yet one fan died on this last dyno session and the other died in the parking lot right after.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 06-02-2014, 11:30 AM   #1769
Dipstik-sportech
It's just common sense when something is that close to the exhaust wrap it lol. I actually ran it for 8 months with just the ceramic coating and didn't have issues until I took it to brainerd in the 105° heat and even then it didn't overheat it just ran warmer
The Frozen North
Old 06-02-2014, 05:05 PM   #1770
69Marshall69
69Marshall69's Avatar
Drives: 2013 Subaru BRZ-S
P0108(MAP sensor error) my car is running rich, this may be the possible cause, also traction control indicating light(when you start spinning) is constantly lit. No control over traction control or cruise control. Anyone know the possible causes!
Dan
69Marshall69 is offline   Reply With Quote
Old 06-02-2014, 05:42 PM   #1771
xwd
The traction/cruise happen when there is a CEL so it's because of the MAP sensor issue. How much boost are you running? If you are on the stock MAP sensor maybe you've exceeded its capability.
Old 06-02-2014, 07:09 PM   #1772
69Marshall69
I contacted LJ, I just did a reflash of a tune and it fixed the MAP sensor issue along with everything else. Must have just been a faulty flash from before. Car runs less rich, just a base tune. Thanks guys!
Old 06-02-2014, 10:21 PM   #1773
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
for the guys with the spal upgraded fans.. what did you guys do at the connector? did you cut the spal connectors and the oem connectors and just wire them up?
i want it to be as plug and play as possible... but looks like getting oem connectors is impossible.
@FullBlown what about the shop car?
xDBOYx is offline   Reply With Quote
Old 06-03-2014, 12:57 AM   #1774
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Cut em and wired em up.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 06-03-2014, 01:45 AM   #1775
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We just cut and use the basic connectors. Still working on trying to find the oem connectors
FullBlown is offline   Reply With Quote
Old 06-03-2014, 01:55 AM   #1776
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
@Reaper Well dam lol at least i know the upgrades will keep temps down pretty dam good. You mind showing me what you did to heatshield your motors? Im going all out on trying to protect those dam Fans lol.
@Dipstik-sportech Yes common sense is correct, I'm definitely not cutting corners when trying to protect those fans from heat, Oklahoma summers are mostly 100+ F, granted my summer will only be about 2 months this year lol But I always think about longer term.
Old 06-03-2014, 12:13 PM   #1777
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
My downpipe was ceramic coated and heat wrapped, and my slim fans also worked fine for over 15,000 miles.
Old 06-03-2014, 01:19 PM   #1778
Reaper
Reaper's Avatar
Drives: violent
I burned up my slim fans and now have the oem fans in. I have 2 pieces of aluminum wrap on the upper support bar as seen in the pic.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 04:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 10:15 PM
