Old 08-08-2014, 03:48 AM   #1
ptuning
ptuning's Avatar
Drives: White FR-S
PTUNING 4-1 Full T304 SS Equal Length Double-Slip Race Header (200+whp 93 pump gas)
Since we've sort of made our home in the Forced Induction section, many of you are probably not aware that we've been developing a header for the FR-S/BRZ/GT86.
We'll be testing this header the first part of next week. Our plan is to do a full dyno tune to extract the most out of the header. This will also include dialing in both intake and exhaust cams to hopefully within 5 degree or less of optimal timing. The idea will be to compare a baseline dynorun on our dyno with that of our fully tuned header. This will give you an idea of what kind of gains to expect from running this header.
For those of you that don't already know, we design, prototype, and dyno test and tune all of our products in-house. I'm personally involved with all the product prototyping and testing using our Dyno Dynamics Lowboy 450 Quad Retarder AWD Chassis Dyno. I've been tuning this platform using ECUTek from the very beginning. NA, supercharged, turbocharged, pump gas, E85 flex-fuel, water methanol injection, etc.
Before we get to the details of the header, let me be the first to say that this header will not fit all budgets. PTUNING likes to build premium quality products. Unfortunately, in order to do so, we often have to take cheap and inexpensive-to-build out of the equation. With that said, this header is designed to compete with the other high end headers on the market.
Link to website:
http://www.ptuning.com/subdir/partno...=PTP-EXH-15100
Details:
- Designed and manufactured in the USA using only the best quality domestic grade materials.
- Custom spec 1/2" thick CNC T304 SS head flanges with back cut gasket face for better exhaust port gasket sealing.
- Custom spec 1/2" thick CNC T304 SS 2-bolt overpipe inlet flange.
- T304 SS v-band near merge collector for possible future upgrades to a full v-band header back exhaust system.
- Runner lengths designed around the offset cylinder 1 and 4 exhaust ports on the FA20 cylinder head. All 4 runners lengths are within 1.5% of each other from the back side of the exhaust valves to the merge collector.
- Rotational firing order into the 4-1 merge collector. Only one of it's kind for the FA20.
- Double-Slip 4-1 merge collector with custom spring tabs to allow for proper heat expansion without the need for flex bellows. Only one of it's kind for the FA20.
- Minimal exhaust runner up sweep at the front of the engine ensures that radiant heat is kept to a minimum. This also makes this header SC friendly.
- Low profile design allows the factory metal under tray to bolt back into place without any modifications or spacers.
- Each mandrel bent exhaust runner is constructed using the fewest number of sections possible. This ensures perfect exhaust flow as well as eliminating the need for extra weld joints.
- All six exhaust port studs are readily accessible to allow for ease of installation as well as the ability to properly torque down each nut.
- O2 sensor bung placement does not require extending the O2 harnesses.
- No CEL codes.
Additional Info:
- Since we cannot put a price here, we'll be creating a post in the vendor for sale section soon. It is also listed on our website.
- These headers will not be available to ship out for about 4-5 weeks, but we are taking pre-orders on them at this time. You can PM us for details.
- Since performance is our sole objective, we will not be producing either a catted or UEL version of this header.
- Toan
Stock Baseline vs. PTUNING 4-1 Race Header Untuned vs 4-1 Race Header-Back with ECUTek Dyno Tune
These are not unicorn numbers. Here are 27 more dyno-pulls over 196whp to back up our claims.
ptuning is offline   Reply With Quote
Old 08-08-2014, 04:09 AM   #2
Turdinator
Señor Member
Turdinator's Avatar
Looks very nice! I am interested to see the torque curve these produce as the runners are longer than the current trend in EL headers, on this forum anyway.
Will you publish recommended cam timings?
1974 TA22 Celica
2013 86 GT
Old 08-08-2014, 05:02 AM   #3
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Excellent! Side question are you considering a ceramic coating option with this piece as well once finalized on design and in production?
Old 08-08-2014, 07:00 AM   #4
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Holy cow that's an awesome looking header. Can't wait to see dyno results. Can you also do a dyno run on fully stock car except header + tune only?
Fizz is offline   Reply With Quote
Old 08-08-2014, 09:57 AM   #5
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Great looking bit of kit there. May I ask if heat is a concern regarding that driver side engine mount. That runner looks close.
Cheers
F1point4 is offline   Reply With Quote
Old 08-08-2014, 11:06 AM   #6
EMS Guy
The cynic
Drives: An ambulance
Nice looking piece there PT!
Any more photos to share OFF the block?
EMS Guy is offline   Reply With Quote
Old 08-08-2014, 11:18 AM   #7
Arcadien Angel
I may be an idiot
Arcadien Angel's Avatar
Drives: Winona - White 2014 Scion FR-S
Originally Posted by ptuning View Post
- Low profile design allow the factory metal heat shield to bolt back into place without any modifications or spacers.
@F1point4, I'm assuming that the OEM heat shield SHOULD take care of that potential issue. Since the header is said to be able to be mounted without modifying anything, the heat shield should not only fit, but also protect the engine mount and anything else. I could be wrong though.
Side note: I'm just about to jump on getting the FT86 Speed Factory Catted UEL Header. So any more information on this header as soon as possible would be great.
-Angel
Arcadien Angel is offline   Reply With Quote
Old 08-08-2014, 11:45 AM   #8
Luis_GT
-Angel
The heat shield ptuning is talking about is most likely the bottom skid plate, not the OEM header heat shields
Old 08-08-2014, 12:27 PM   #9
jdmblood
jdmblood's Avatar
Drives: white subaru brz
in for dynos!
jdmblood is offline   Reply With Quote
Old 08-08-2014, 12:43 PM   #10
mkivsoopra
Any plans for a replacement turbo over pipe so that it'll be vbands all the way from header to muffler? :p
mkivsoopra is offline   Reply With Quote
Old 08-08-2014, 12:44 PM   #11
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
I have been waiting for this! can't wait to see how it performs!
Will you work with OFT/shiv to release OTS maps?
G-Man is offline   Reply With Quote
Old 08-08-2014, 01:49 PM   #12
ptuning
ptuning's Avatar
Drives: White FR-S
Yes, we'll have no problems supplying our customers with optimum cam timing settings. We'll likely offer ECUTek eTuning too.
- Toan
Old 08-08-2014, 01:53 PM   #13
ptuning
ptuning's Avatar
Drives: White FR-S
Since we're not huge fans of ceramic coating, we'll likely leave the ceramic coating option up to the customer. However, we would have no problems shipping the header directly to the customer's ceramic coating company of choice.
We'll likely offer an optional stainless steel puzzle piece header heat shield system later on down the road.
- Toan
Old 08-08-2014, 01:54 PM   #14
ptuning
ptuning's Avatar
Drives: White FR-S
Assuming the AFR's don't look too wonky during the first dyno pull with the header, we may post those numbers too.
- Toan
200hp na, 4-1 full, merge collector, ptuning, race header
WTB: Equal-length (EL) catted header ck-GT86 Engine, Exhaust, Bolt-Ons 1 04-10-2014 08:31 PM
PRE Stepped diameter 4 to 1 double slip collector Header Jmonty Engine, Exhaust, Transmission 9 02-28-2014 10:24 AM
BRZ/FR-S/GT86 – 4-1 Equal Length Header Group Buy P&L Motorsports Groupbuys 634 12-03-2013 06:36 PM
*PHASTEK* DC Sports Equal Length Header PhastekSport Engine, Exhaust, Bolt-Ons 3 11-14-2013 11:17 PM
