Old 08-09-2014, 02:32 PM   #393
Iam-Naimless
Drives: 2013 Ultramarine FRS
Need Help.
I plugged my oft into the computer to update. I assumed it autoupdates. It did do some form of updating. When it stopped I went out to my car to hook it up to flash the new stage 2 93 oct uel map. The map wasn't there. None of the new maps were there. How do you get the new maps?
Iam-Naimless is offline   Reply With Quote
Old 08-09-2014, 02:33 PM   #394
nunonuna
nunonuna's Avatar
@Shiv@Openflash & and everyone
I just got dyno session today & here is the result.
169.1 whp with no correction factor applied
Temp was mid 80 with 74% humidity
Dyno Dynamic dyno
The stock graph is not my car but its stock BRZ
on same dyno on much cooler & dry day in October.
Mods are following:
OFT 2.01 stg 1 93 oct map
Perrin OP
Tomei catless front pipe
Invidia Q300
Apexi filter
perrin inlet.
nunonuna is offline   Reply With Quote
Old 08-09-2014, 03:10 PM   #395
ALB
Originally Posted by tonystewart View Post
For those running a stock intake with the latest tune, did you replace the Inlet hose
SuperTek
http://supertekindustries.com/index....-fr-s-brz.html
ALB is offline   Reply With Quote
Old 08-09-2014, 04:03 PM   #396
fstlane
fstlane's Avatar
Drives: BRZ Limited
For those running a stock intake with the latest tune, did you replace the Inlet hose, (Perrin, Mishimoto, Etc) ?
http://perrinperformance.com/images/F92268231.jpg
I'm running one of those inexpensive eBay silicone intake tubes from Rev Motors with the latest 93 octane stage 2 map. For $50 it was worth it to me to tidy up the engine bay even if there aren't any performance gains. Add a decent drop in filter and a modified stock snorkel and you've got a true cai that looks, sounds and performs well for under a hundred bucks.
fstlane is offline   Reply With Quote
Old 08-09-2014, 05:07 PM   #397
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Looking forward impatiently for EUDM versions!
BTW in the 700l Stg 2 UEL v1.59 P0420 CEL code is not disabled - would be nice to fix it in v2!
Efferalgan is offline   Reply With Quote
Old 08-09-2014, 10:18 PM   #398
lucid215
after 30 miles of driving normal i did a second gear pull to see how the car is running. im on stage 2 uel 93 rom.
http://www.datazap.me/u/lucid215/sta...l?log=0&data=1
lucid215 is offline   Reply With Quote
Old 08-09-2014, 10:39 PM   #399
Wepeel
Drives: '13 BRZ Ltd
Do you know what IAM was? Also - another log with huge long term fuel trims... hmmm...
Wepeel is offline   Reply With Quote
Old 08-09-2014, 10:55 PM   #400
nunonuna
nunonuna's Avatar
Yes I noticed ltft is pretty high.
Old 08-09-2014, 11:07 PM   #401
steve99
Drives: FT86
I'd guess aftermarket intake ??
It not rearly that bad once its off idle/low rpm, just needs lower end of MAF scale re-done , unless it an intake that creates turbulance near MAF at low rpm, possibly MAF sensor is relocated too close to throttlebody.
Old 08-09-2014, 11:13 PM   #402
Wepeel
Drives: '13 BRZ Ltd
Which header? Does it sound like it might be leaking?
I noticed occasional LTFT in the 7's, haven't logged on OFT yet but I see it on the Torque app. It's very transitional, seems to be during very low load and higher-than-idle rpm. I'm wondering if a header leak could cause something like this.
Old 08-09-2014, 11:15 PM   #403
steve99
Drives: FT86
quite possible.
Old 08-09-2014, 11:19 PM   #404
nunonuna
nunonuna's Avatar
He has OFH I think
Old 08-10-2014, 12:50 AM   #405
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by solidONE View Post
Stock tune on 91 has horrible knock, at least on A01C calibration.
Side note: Has anyone noticed the MPG's going way down? Like 3-5MPG less than the older OTS tunes?
Bueller..? I'm getting 18MPG city currently while I've been at 21-24MPG with the older tunes.
Old 08-10-2014, 07:49 PM   #406
lucid215
Sorry for the late reply. Yes I have the ofh and aftermarket intake. I didn't have those hi ltft with the stage one rom. She felt a lot better on the stage one. I don't have any leaks I torqued the bolts down a bit more then stock specs. She's starting to feel a bit better but still the vvt still doesn't kick in as hard. I'm running Takeda intake, ofh, invidia over pipe, invidia catless front pipe, and jdm TRD axle back exhaust.
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
