Old 08-09-2014, 01:03 AM   #1905
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Haha seriously!
Freeman is offline   Reply With Quote
Old 08-09-2014, 01:11 AM   #1906
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Originally Posted by nlowell View Post
I maxed out my stock injectors with the base C30 pulley at ~7k RPM. Injectors are now on my short-list.
Replaced mine a while back when @moto-mike of Moto-East said I'm very close to making out the injectors using corn. Using DW 700cc's right now, more than enough for the power I'm confident with on stock motor.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 08-09-2014, 01:14 AM   #1907
SPCorBUST
SPCorBUST's Avatar
Yeah you're probably not even at half the capacity. I was at about 70 percent on 550s at 15 psi. You should have tons of room left.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 08-09-2014, 04:38 AM   #1908
CSG Mike
CSG Mike's Avatar
Originally Posted by SPCorBUST View Post
C38. I hit 385 already stock motor. Perhaps 450 is doable with the pulley, headers, overpipe, downpipe, and an aggressive tune. Certainly plenty of room left in the injector size I went with.
That's a lot of torque for the stock rods...
Old 08-09-2014, 04:21 PM   #1909
SPCorBUST
SPCorBUST's Avatar
Definitely, I'd probably get motor work done if I was going that high or higher though. Just wondering about the capabilities.
Old 08-11-2014, 02:16 AM   #1910
zoth
zoth's Avatar
Finally was able to push my car & the @KraftWerks SuperCharger kit during the 2nd Annual Texas FT86 Day Meet/Cruise. Thanks to @moto-mike of Moto-East for a great e-tune experience the car run extremely well.
Quick video of the run and event. 5 groups run "The Twisted Sister's route here in the Great State of Texas. BTW: I counted at least 61 FT-86's.
[ame="https://www.youtube.com/watch?v=uSV2OfFshtE&list=UUwKOWGq8PBT5LNTycnNJ3IA"]2nd Annual Texas FT86 Day Meet & Cruise - YouTube[/ame]
Old 08-11-2014, 06:12 PM   #1911
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Just rode in one with the c38 yesterday after tuning it. Holy hell, that thing is awesome. Nothing like wheel spin top of 3rd on pump gas. Granted psi for psi not a huge difference vs the 94, but where it starts to flatten out a bit past 6800, this thing just climbs.
Xero-Limit is offline   Reply With Quote
Old 08-11-2014, 07:02 PM   #1912
zoth
zoth's Avatar
Hey @moto-mike that or a high boost pulley for me?
Old 08-11-2014, 07:38 PM   #1913
Xero-Limit
Xero-Limit's Avatar
Pulley should be enough to achieve the same effect with the 94. You must be itching for the 400 number on e85!
Old 08-11-2014, 09:46 PM   #1914
zoth
zoth's Avatar
I didn't realize that torque is soooo addictive. Hard to resist.
Old 08-12-2014, 01:22 AM   #1915
Jcl
Drives: 2014 BRZ
Just installed radium catch cans. Do I need to add a check vavle on the pcv line?
Jcl is offline   Reply With Quote
Old 08-12-2014, 03:28 AM   #1916
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
thanks for the revised map Mike, car feels even better now with the adjusted timing and throttle mapping Maybe I will get a smaller pulley upgrade once I get an upgraded oil cooler and the new clutch kit..I think it wouldn't hurt to use the SC at its full potential
glamcem is offline   Reply With Quote
Old 08-12-2014, 10:14 AM   #1917
vgi
Drives: frs
that with the HB pulley
vgi is offline   Reply With Quote
Old 08-12-2014, 10:17 AM   #1918
vgi
Drives: frs
what do you think that thing would make with a proper dyno tune? vs c30?
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
