#253 |
Proud of Boxer
So can this get rid of cels when running catless headers?
#254 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
#255 |
Drives: BRZ SWP 14
OFT v2.06 Non-Beta
#256 |
Drives: Yes
http://www.datazap.me/u/chas3wba0/st...0&data=1-11-12
Out of curiosity, I ran Stage 2 (v2.06) for a week with the FT86SpeedFactory catted UEL header and then took a quick log. I'm back on Stage 1 now, as recommended by Shiv, but I know some are curious about whether Stage 2 works well with this header. Everything looks decent to me (someone please confirm this), but no obvious gains over Stage 1. Will do another log on Stage 1 (v2.06) sometime this week, for good measure.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#257 |
Drives: GTS86
Not sure if this is the right thread.
But have a problem with OFT OTS v2.061 Stg2 EL A01I I have a fault code P0420 I thought this was turned off, I also note that Rom Raider Trouble Codes does not list this code. I am new at this and a steep learning curve for me so I will appreciate any help |
#258 |
Drives: Toyota 86 GTS
No it's not turned off, we have the modified files in the group, still waiting for approval.
#259 | |
Drives: FT86
Email shiv and he will sort it. if you cannot wait use def below A01I is not a calid modified rom so standard RR def will work this is NOT always the case. Last edited by steve99; 09-23-2014 at 06:33 AM. |
#260 |
#261 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Thanks guys, I'm just paranoid about the effects this might have, especially with my warranty.
Has anyone had warranty work refused (DI seals, crickets) because of an OFT tune? |
#262 | |
Drives: FT86
If you have headers they usually spot those, as well as turbo's and superchargers. |
#263 |
Because Racecar
Drives: 2013 Lightning Red Subaru BRZ
Is there a way to lower the revs on a cold start? As much as I like the relatively loud start (with my Perrin exhaust), I wake up my toddler at 7:00am. Otherwise I'm going to have to start parking a couple of blocks away...
Thanks. |
#264 | |
Drives: GTS86
Wayne on the files you linked to, the defenition file has the code for 0420, the question I have is this, can that defenition file be used on the latest 6.01 release... |
#265 |
You mean 2.06? Yes
#266 |
Drives: GTS86
Yes . sorry mate
I have assumed it is compatible and did changes to official release, reason that I am not sure about the 98 and 100 situation. The latest 2.061 worked well but for the very occasional p0420 code. I am for a long drive to Sydney in the morning some 600K from here, I will get to test it properly. |
| OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] | Shiv@Openflash | Forced Induction | 226 | 03-12-2019 10:26 PM |
| iOS 8 beta 1 not working on BRZ USB | Kids Heart | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 04-13-2015 09:17 PM |
| v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT | Shiv@Openflash | Forced Induction | 3 | 07-26-2014 01:23 PM |
| OFT 1.42 vs 1.5x Beta Who notices a Difference? | Cross | Software Tuning | 11 | 03-21-2014 04:17 PM |
| Anyone want to beta-test some door speaker spacers? | phenryiv1 | Electronics | Audio | NAV | Infotainment | 63 | 08-20-2012 10:02 PM |
