Old 10-02-2014, 03:11 AM   #29
cuddefred
Drives: Black 86 GT
It could be a number of things but the fact that he can't tell any difference when he is driving is the one that puzzles me most.
Originally Posted by Turdinator View Post
Could it just be that the P&L header requires slightly different cam tuning to produce max torque accross all rpm?
cuddefred is offline   Reply With Quote
Old 10-02-2014, 03:20 AM   #30
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
I would expect stuff like this would be more likely to pop up with all the different UEL header lengths. EL is EL, shouldn't matter so much if it's long or short tube I would think.
Old 10-02-2014, 03:21 AM   #31
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
I'll go for a spin tomorrow and take it easy, I've been punching it from 4th to 5th so there might be a chance I completely miss this area of dip. The car is too fun, can you blame me?
Hypothetically speaking though...is it even possible to miss that dip if I'm driving at higher RPM's?
If the dyno claims it dipped in 5th, then I should be able to replicate it from 4000rpms and upwards, right?
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 10-02-2014, 03:28 AM   #32
Wayno
Wayno's Avatar
I would think you should be able to feel it in 3rd and 4th easily, maybe even 2nd. Your right that it's possible you always drive around it, just like you can drive around the torque dip.
Old 10-02-2014, 04:41 AM   #33
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'll echo the above, the drop is far more sever than the stock dip, it would feel like the car hesitates every time you run through it. You would notice it.
Did you flash the tune immediately before hitting the dyno? Any chance the LTFT hadn't settled, causing a lean situation and possible knock correction to occur? That could cause a drop similar to that.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-02-2014, 04:50 AM   #34
ck-GT86
ck-GT86's Avatar
I haven't touched the tune ever since the v.2.0 beta maps were released. I'm a bit dated compared to 2.061
I'll report back tomorrow after my commute to work
.ck
|| My Build Thread ||
Old 10-02-2014, 05:12 AM   #35
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
Just saw this thread now... That torque dip you show should be very noticeable when driving, that's worse than the stock dip..... Curious to see results of this. I am OFT stage 2 uel. Love it!
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
Old 10-02-2014, 05:17 AM   #36
stonenewt
Drives: BMW 120d
Originally Posted by ck-GT86 View Post
I recognise that, it looks identical to the TC interventions I used to get on my Elise.
stonenewt is offline   Reply With Quote
Old 10-02-2014, 05:20 AM   #37
troek
troek's Avatar
Drives: 2012 Toyota 86
Ooo nice observation.
troek is offline   Reply With Quote
Old 10-02-2014, 06:53 AM   #38
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by DC2R View Post
....also 205 crank can probably be hit with stock car and filter
yeah, I thought the same thing. That stock the it made ~200hp at the crank -15% to the wheels.
Would it being catted make a difference? I don't know what header shiv was using to create his EL tune, but I know the UEL was based off the OFH which has no cat.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 10-02-2014, 07:40 AM   #39
troek
troek's Avatar
Im sure he meant to say at the wheels.
Old 10-02-2014, 11:08 AM   #40
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I know this is an older tune, but I can still feel it on the newest maps(It's not as bad, but still there). I had somewhat the same issue around 4500rpm. WOT the car would just stop accelerating for a bit, then keep going. Datazip WOT Log
at 4500 rpm (Almost on the dot) you can see the rpm's stagnate, then pick back up. This happens more often in 5th and 6th gear. Even this is extremely noticeable; so I would assume if the car dropped as the dyno showed, he would notice it.
Old 10-02-2014, 11:39 AM   #41
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
Am i the only one who looks at that and thinks its just timing being pulled and then ramped back in? Thats how it looks on LS powered cars. In a perfect world that part of the timing map would be fixed but isnt this an off the shelf canned tune in a holy crap epic amount of load that you'd never actually subject the car to?
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 10-02-2014, 12:04 PM   #42
d1ck
Drives: Black 2013 FRS
If it was an extended pull the load on the engine is higher, and it's possible that this increased load is causing some knock at that RPM / Load.
d1ck is offline   Reply With Quote
bromance, dip, dipsmorethanchipsandsalsa, dipsmorethangrandpaballs, dyno, ecutekbutthurt, maha, openflash, vishnu, yetanothersmearattempt
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 05:48 AM
1st Dyno Tested/Tuned 6AT - OpenFlash Tablet Anorexic 86 Software Tuning 13 07-25-2014 04:09 PM
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) Rombinhood@OpenFlash Software Tuning 237 02-10-2014 04:35 PM
***VISHNU OpenFlash Tablet IN STOCK*** Garrett@Openflash Engine, Exhaust, Bolt-Ons 15 12-17-2013 02:30 PM
Interesting Findings about BRZ Audio Output Chad_W Electronics | Audio | NAV | Infotainment 14 05-03-2013 09:28 PM
