Old 11-06-2014, 06:04 PM   #603
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by G-Man View Post
currently it is still with the flange, but there is talk of them updating this
http://www.ft86club.com/forums/showp...&postcount=260
I would have thought that the option would already be out but maybe is too soon. Still a great option to keep in mind.
yomny is offline   Reply With Quote
Old 11-11-2014, 01:34 AM   #604
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
Discussion: Oil/Water readings for Ptuning turbo setup
Optimal, high and low oil temperatures?
Optimal, high and low water temperatures?
What oil are you using for your Ptuning turbo setup?
What oil temps are you seeing with Ptuning oil cooler and without oil cooler?
What water temps are you seeing?
What modifications have you done to help reduce temperatures?
mnsayer is offline   Reply With Quote
Old 11-11-2014, 02:07 AM   #605
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
What oil temps are you seeing with oil cooler and without oil cooler?
Some of those questions depend on other factors - such as which oil cooler?
There is a big difference between the Setrab 25 row(?) that @sw20kosh and @mkivsoopra are using, and the PTuning laminova that I am using.
I am very satisfied with my oil cooler; especially that I don't need to disconnect it during the winter, however it has its limits. At 85F ambient weather, I was able to track my car for 20 hot lapping minutes at buttonwillow with the Ptuning laminova cooler while reaching 235F oil and 227F water. At 105F ambient weather at the track, I had to back off the throttle after 10-15 minutes. I suggest not taking the car past 245F oil and 235F water. I use Amsoil 5w30. I have Koyorad aluminum racing radiator.
Without an oil cooler, it is risky to track for longer than 5-10 minutes as your oil temp will sky rocket. You will need oil to be above a certain temperature to burn off any water - I think 200F? I don't know the exact.
Some good info on cooling here: http://www.ft86club.com/forums/showthread.php?t=73279
rb6freak is offline   Reply With Quote
Old 11-11-2014, 03:28 AM   #606
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
@kanundrum that has to be just a beast to drive now at latest numbers. Crazy and awesome all at once!!
Old 11-11-2014, 04:20 AM   #607
mkivsoopra
+1 @rb6freak
I have a big 25 row setrab and koyo radiator and saw a max of 214F oil and 214F water at the same track and about the same ambient temp... maybe a few degrees cooler.
It is way overkill for street though. I actually have it disconnected now, otherwise I'll be seeing 150F while cruising on the freeway. This is WITH a thermostatic sandwich plate.
Without any oil cooling, i typically see 215-230F on the street in mild ambient temp. If driving hard, it will easily hit 265+.
In other words, oil cooler is recommended, track or not. If you track, then it is mandatory. As for additional mods, I've put foam around the radiator and added panels on the side of the intercooler to prevent air from leaking through the sides.
@sw20kosh has the stock radiator and same oil cooler and sees similar temps that I do.
mkivsoopra is offline   Reply With Quote
Old 11-11-2014, 05:12 AM   #608
CSG Mike
CSG Mike's Avatar
Originally Posted by mkivsoopra View Post
+1 @rb6freak
Swap to a 10 or 15 row!
Old 11-11-2014, 12:14 PM   #609
mkivsoopra
Nooo... I'll install a bypass valve before swapping to a smaller one!
Old 11-11-2014, 01:55 PM   #610
sw20kosh
Drives: 2013 Black FR-S
Way too small.
Old 11-11-2014, 05:51 PM   #611
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
keep it above 212F for oil to evaporate the water.
Mrc@ptuning is offline   Reply With Quote
Old 11-11-2014, 06:41 PM   #612
Blizzz
If you guys are seeing 212+ water temps, you've got boiling water running through your lines...
Blizzz is offline   Reply With Quote
Old 11-11-2014, 06:56 PM   #613
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Not entirely true. But yes, it is common to see coolant boiling out of overflow tanks at the track in 100F degree weather. If you haven't seen this, you haven't driven hard in enough in the heat
Coolant has a higher boiling temperature. It also acts differently when pressurized vs in the atmosphere. It takes a higher temp to start boiling.
Old 11-11-2014, 07:18 PM   #614
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
PTUNING Turbo Kit Owners Topic
@rb6freak has it right! Subaru coolant is a 50/50 mix. @Blizzz is correct that pure water has a boiling point of 212F but that's not the case with coolant.
In reality, the pressure cap on a cooling system is key to raising the boiling point of the 50/50 mix. For every pound of pressure cap rating the boiling point of the mixture raises 3 degrees. This is essentially that @rb6freak is saying when he states that it acts different pressurized vs in atmosphere.
None the less, @Blizzz nice try with the scare tactic.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 11-11-2014, 07:32 PM   #615
mkivsoopra
Old 11-11-2014, 08:03 PM   #616
Mrc@ptuning
Drives: S1000RR
That's the reason the coolant system is pressurized. The best coolant is pure water. The antifreeze is added on to keep the water from freezing and potentially cracking the block in cold weather. Plus the additive is there to lubricate the water pump. If you track the car often and live in a warm climate, the best "coolant" is pure distilled water and some water wetter.
ptuning, turbo kit
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2639 04-05-2026 11:31 PM
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
