#15 | |
#16 | |
Drives: 2013 Firestorm FRS
Trying another one haha |
#17 | |
I think that part number might be wrong, the OEM part number WE WANT FOR UPGRADE is 30620aa111 So, I called autozone again, and gave the proper OEM# (30620aa111-which is the 3/4 one) and they pulled it up as $23.99 autozone Part # 52337 or alternate # LSC337 Okay, here is the AUTOZONE BREAKDOWN: The correct part to order is "900061"-CLICK for Link Which is $31.99 (11/18/14) Part #52337/alternate #LSC337 will fit. However, the mounting point for the clutch line is oriented differently, so this is not ideal. Last edited by continuecrushing; 11-18-2014 at 08:51 PM. |
#18 |
Drives: 14 Ultramarine FR-S
I grabbed the linked one below. Not installed yet.
http://www.autozone.com/drivetrain/c...er/383444_0_0/ Edit: So if you look @ vehicle fitment on both links... The one I posted is for 2007 & newer the other one posted is for 2005 & older. I wonder what the differences are...
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#19 | |
haha. When I called the first time, the guy came up with that part number/price. I guess we'll see lol |
#20 | |
http://parts.subaru.com/p/Subaru_200...0620AA042.html Take a look, different PN & matches with vehicle fitment on Autozone. I'll take a closer look when I'm home...
#21 | |
Get the right one. @Phantobe has it. Autozone P/N 900061 |
#22 | |
Yours, the correct one, has a guide oriented at 45° to the cylinder. |
#23 | |
Are the washers also referred to as "brake line washers"? http://www.autozone.com/brake-system...er/773866_0_0/ Was gonna grab those instead of OEM.
#24 | |
#25 |
Drives: 2014 BRZ
Sorry guys. it came in a bag with the 90028 number on it. Let me see if I can still find the bag today. Its a duralast part if that helps. When I went I gave them the oem 3062aa111 and that is what they gave me.
#26 | |
I installed mine last night, everything went on just fine. Since I'm running the "wrong" one, I might remove the bracket between the hardline and the rubber line and bend the metal hardline so its a little closer to the slave. Or just replace the whole line entirely with an aftermarket one. |
#27 | |
degrees
Drives: 6MT BRZ
#28 | |
Edit: I haven't replaced it. Works fine. I'll get the correct one when this one is no longer serviceable. Last edited by Ultramaroon; 03-21-2015 at 02:55 PM. Reason: for truth |
| Tags |
| clutch line, slave cylinder |
| Clutch Engagement Improved! | enjoyminutemaid | Engine, Exhaust, Transmission | 53 | 11-07-2018 07:31 PM |
| Can steering feel, tactility, be improved? Without sacrificing adjustability? | Trettiosjuan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 101 | 08-16-2016 09:14 PM |
| Aftermarket Clutch Master and Slave? | Yruyur | Engine, Exhaust, Transmission | 5 | 07-27-2013 11:22 AM |
| Hate the feel of the clutch | FRSGeek | Engine, Exhaust, Transmission | 18 | 07-10-2013 02:24 PM |
| Clutch feel? | Shit Luck | Engine, Exhaust, Transmission | 5 | 04-21-2013 06:32 PM |
