Old 11-27-2014, 07:12 PM   #1317
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by Skorov View Post
Anyone have any issues with the pulley hitting the charge pipe on medium-hard braking?
Mine makes quite a bad noise. Any solutions?
Yup mine did. I used something to pull the pipe back towards the rad support.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 11-27-2014, 07:28 PM   #1318
Skorov
Skorov's Avatar
Drives: 86 GTS White
I've done that with a cable tie. It helped, but didn't solve completely. I'm thinking of grinding down the pulley bolts a bit. Is this a good idea?
Skorov is offline   Reply With Quote
Old 11-27-2014, 07:30 PM   #1319
protpibe
protpibe's Avatar
I would take a look at the charge pipe mount first. Did you install it correctly?
Old 11-27-2014, 07:38 PM   #1320
Skorov
Skorov's Avatar
To my knowledge, I did. It's tricky mounting the airbox and the pipe to that same bracket. I'll double check to make sure it's on properly.
Cheers
Old 11-27-2014, 11:13 PM   #1321
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Originally Posted by Fizz View Post
Have u tried the soapy water trick?
Next weekend. I'm also going to record the logs to delicious tuning during the week...
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 12-01-2014, 10:32 PM   #1322
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
This is also happening to mine as well. It was confusing the hell out me. I put in the stoptech pad, rotor, and braided line kit and I thought I messed something up.
Old 12-01-2014, 10:33 PM   #1323
Skorov
Skorov's Avatar
Did you manage to fix it?
Old 12-02-2014, 03:08 AM   #1324
AVOturboworld
Did you install the pipe with the rubber grommet on the bracket? If so, remove the rubber grommet - it allows the pipe to move on the bracket a little, and at the far end (down near the pulley) it can move enough to hit the pulley slightly.
Old 12-02-2014, 02:00 PM   #1325
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
i did install the pipe keeping the rubber gormmet in place. I'll remove it and take another cruse with the car as soon as I'm able to...
Old 12-02-2014, 06:02 PM   #1326
Skorov
Skorov's Avatar
I did as well. I'll try take it off.
There was a spacer that was supposed to go between the bracket and the pipe. But I couldn't see a way to fit the spacer, intake box and the pipe bracket all in there. Is the spacer essential here?
Old 12-02-2014, 06:25 PM   #1327
AVOturboworld
Are we talking about the spacer that goes inside the rubber grommet?
Old 12-02-2014, 06:42 PM   #1328
Skorov
Skorov's Avatar
No. My kit came with a spacer similar to those used for the metal under tray. This spacer was in the same bag as the other parts used for this pipe. Could it have been mistakenly put in with the kit?
Or maybe it is in there in case someone is using an aftermarket intake and can't use the OEM airbox bracket as a spacer?
Old 12-02-2014, 07:10 PM   #1329
AVOturboworld
That's not meant for that purpose, no. That was probably a spacer for the heat shield.
Old 12-02-2014, 08:39 PM   #1330
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
There is plenty of room for the charge pipe, but you have to put it and the hoses together *perfectly*. You may need to play around with it some to get it in the right place.
FrX is offline   Reply With Quote
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
