Old 12-09-2014, 09:48 PM   #43
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
You should <ahem> Czech it out!
This is why you're an engineer and not a comedian.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 12-09-2014, 10:25 PM   #44
Dipstik-sportech
Dipstik-sportech's Avatar
Do we know what vehicle the smaller slave comes out of?
Old 12-09-2014, 10:39 PM   #45
Koa
30620AA111 is the slave you want if going OEM subaru. It is fitted to Forester XT, Crosstrek, Impreza, and other platforms
https://www.subarupartsdepot.com/oem-subaru-parts.html
Old 12-09-2014, 10:42 PM   #46
Old 12-09-2014, 11:03 PM   #47
504
504's Avatar
Drives: 2014 86 GTS
http://www.quirkparts.com/oe-subaru/30620aa111
all compatible vehicles of part number 30620aa111 are listed on that webpage so I assume you can buy a used slave cylinder from any of the cars listed
504 is offline   Reply With Quote
Old 12-10-2014, 12:15 AM   #48
Technically yes but why on earth would you install a used one?
Old 12-10-2014, 01:05 AM   #49
504
504's Avatar
Drives: 2014 86 GTS
ah sorry responded to his post with my situation in mind. haven't been able to locate a genuine part that doesn't cost over $150 here in Australia, next best bet was used search for me I guess
Old 12-10-2014, 01:14 AM   #50
No worries - makes perfect sense. That being said, it's just a hunk of cast iron with a couple holes bored. IMHO, you'd be better off with a new fake one than an old factory one.
Old 12-10-2014, 02:21 AM   #51
JB86'd
JB86'd's Avatar
Drives: JAWS
So @Ultramaroon you mentioned lowering the clutch pedal before doing this. So if I'm correct the possible problem is this raises the clutch pedal level, possibly raising it too high and damaging the pressure plate?
I have mine a few mm above the brake pedal level, how much does this adjustment raise the pedal? Should I drop it a couple mm below the brake pedal before doing this?
Anyone else with the clutch pedal adjustment have any input on adjustment after doing this mod? I'm so close to pulling the trigger.
JB86'd is offline   Reply With Quote
Old 12-10-2014, 02:42 AM   #52
It doesn't raise the clutch pedal but it does result in more throw at the pressure plate. I'm likely going overboard with the caution but I'd rather be known for that than the alternative. I was considering worst case which would be the factory pedal adjustment.
I had already dropped my clutch pedal before the swap and, although the extra throw at the pressure plate is noticeable, assuming your clutch and brake pedal are even, it just brings the whole package together. There's enough disengagement at the bottom that, even though in principle, I disagree with using it as a gauge, it's safe to set the clutch pedal height to match the brake and then fine-tune from there.
A few mm above? Meh, you're fine. Drop in the new cylinder and decide if you even feel like adjusting from there.
Old 12-10-2014, 08:24 PM   #53
Well let's not go Russian into anything!
Old 12-10-2014, 09:33 PM   #54
Guess Iran right into that one.
Old 12-10-2014, 09:35 PM   #55
Well I will let you Finnish.
Old 12-11-2014, 01:10 AM   #56
Phantobe
Phantobe's Avatar
You guys are killing me here.
clutch line, slave cylinder
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 07:31 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 09:14 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 11:22 AM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 02:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 06:32 PM
