Old 02-23-2015, 02:38 PM   #435
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Open Flash Header Discussion
Last week I made an appointment for today to finally get it installed. I don't think that happening
[ame]http://youtu.be/bMeTAYjB8Ac[/ame]
I miss summer time
Kronos is offline   Reply With Quote
Old 02-23-2015, 06:26 PM   #436
JB86'd
JB86'd's Avatar
Drives: JAWS
So when I installed the OFH, I was able to remove the stock header without unbolting the overpipe to frontpipe connection. When I went to bolt it up, I tightened the header to engine bolts, and the flange from the header to overpipe did not line up. I ended up having to disconnect the frontpipe to exhaust connection, realign, and then tighten that connection last.
I've also noticed more NVH since installing, due to tension in the exhaust. Does that sound normal?
@2much @fenton @dodouble @Mad1723 @flippy @BRapZ @Shiv@Openflash
JB86'd is offline   Reply With Quote
Old 02-23-2015, 11:48 PM   #437
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I don't think I have enough experience with modding cars and NVH to determine if I have more. But I can say my OFH hasnt introduced any sounds I wasn't ready for, or that sound out of the ordinary.
2much is offline   Reply With Quote
Old 02-24-2015, 02:18 AM   #438
scarfo
Drives: gts 86
There's a slight whistle/air moving noise I hear through the Rev range,
I put it down to less shielding than stock. Paranoid it was a leak at first haha
scarfo is offline   Reply With Quote
Old 02-24-2015, 04:42 PM   #439
JB86'd
JB86'd's Avatar
Drives: JAWS
Thanks for the input @2much and @scarfo
I definitely hear a very faint bit of noise that's either slight rasp, or a slight leak. I'm also feeling the engine more through the pedals and steering wheel, maybe that's the nature of having no flex joints? @Shiv@Openflash
Old 02-24-2015, 04:49 PM   #440
2much
I wanna go fast
where in socal are you? if you really wanted to compare, if we are close, we could actually compare.
Old 02-24-2015, 04:57 PM   #441
Sleepless
Drives: 2016 FR-S
I finally had a chance to take the BRZ with its new OFH + Stage 2 tune to the track. At Pacific Raceways, my top speed at the end of the straight is up by 5MPH (125), which I consider quite impressive.
Sleepless is offline   Reply With Quote
Old 02-24-2015, 05:21 PM   #442
JB86'd
JB86'd's Avatar
Drives: JAWS
I'm in Lake Forest, about 10 minutes south of Irvine. Are you pretty deep in LA?
Old 02-24-2015, 05:21 PM   #443
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Nice! You must have had a blast
Shiv@Openflash is offline   Reply With Quote
Old 02-24-2015, 06:26 PM   #444
2much
I wanna go fast
I work in Huntington so not terribly close. If you are ever going to be in the area and you want to check the sound on mine though, i'd be happy to
Old 02-24-2015, 06:44 PM   #445
givemeporknow
Drives: 2015 brz series.blue wr blue pearl
Ordered the OFH and waiting for it to arrive! Was wondering if you guys had any advice on which overpipe/midpipe to pair it up with. I currently have a HKS Hi-Power SpecL Lightweight Titanium Catback, HKS Premium Suction Intake and OFT. I plan on staying NA and was also considering getting the Crawford PBP. Noise is not really a concern either...
givemeporknow is offline   Reply With Quote
Old 02-24-2015, 07:56 PM   #446
2much
I wanna go fast
if you are planning on staying NA - you will find that overpipe and frontpipe replacements will cost a lot and provide very little practical benefit. The value in these exhaust pieces only comes out under FI, or perhaps if you are building up the engine and need the absolute maximum power.
Old 02-24-2015, 10:30 PM   #447
steve99
Drives: FT86
have a read of the Basic Bolt on mods link below.
if you have aftermarket intake you mich want to brush up on maf scaling
Old 02-25-2015, 11:50 AM   #448
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
i have that air moving noise but not much vibration and it's only really rumbly and loud during cold starts. my mechanic told me that everything lined up perfectly
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline   Reply With Quote
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 07:29 PM
FS: Open Flash Header - SoCal Pickup nlowell Engine, Exhaust, Bolt-Ons 9 05-12-2014 07:29 PM
Open Flash Tablet Andrew025 Engine, Exhaust, Bolt-Ons 3 04-26-2014 06:03 PM
Open Flash Header Catless Clip Vmax911 Engine, Exhaust, Transmission 25 03-08-2014 07:51 AM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
