#2521 | |
Senior Citizen
Drives: Scion FR-S
So nice to see a manufacturer with management that actually listens to their customers Enjoy! |
#2522 |
The Stig's German cousin
#2523 |
Drives: In Perfect Control At All Times
#2524 |
i'm sorry, what?
Drives: Canada
I expect pax wins from the lot of you. also, I propose a separate thread on the TRD springset to document your impressions.
#2525 |
Drives: 2013 Fiestorm FR-S
Watching this with interest. Not sure if I should be excited or not. I don't really expect it to totally transform the car into an overdog. I would probably only do the springs. I don't generally like big rear bars without a proper limited slip dif.
#2526 |
So elite I'm 1338
Drives: WRB Subaru BRZ
... so you are all debating on the TRD stuff on a non RS FR-S and classing in Solo.
Well if the RS is a B Street car. and You are all planning on putting parts from a B Street Car because of a document that says they are port installed parts on all models of FR-S. Then the most logical thing to assume is: FR-S's will probably be moved to B Street. end debate.
-Jack Burton |
#2527 | |
i'm sorry, what?
Drives: Canada
well.. no... that would be an extremely hamfisted solution, not logical at all.
#2528 |
I think the easiest thing to do rules wise is make frs with the TRD parts run BS with the special editions. As much as I'd like to upgrade springs, it doesn't make sense to screw the brz's and upset the apple cart.
Unless.....the ND ends up in CS and is perceived as a possible over dog. |
#2529 | |
So elite I'm 1338
Why would you asume that? The only way the RS really differs from any other FR-S is the springs, sways, and aero. So everyone adding everthing but the Aero from a RS wouldn't prompt the SEB to consider bumping a FR-S to B Street, but instead moving numerous cars around to accomodate the FR-S remaining in C Street? Edit: Or the other option of maintaining the status quo, and essentially allowing a RS in C-Street.
-Jack Burton |
#2530 |
Drives: 2014 FR-S
This is street class autocross. Logic is a far from guaranteed.
-Mike
#24 CS/CSR |
#2531 | |
If you have a stiff enough front bar (i.e. Hotchkis, which I have) you may be able to get away with more rear bar. If you spend the money on these, make sure you're OK with this being a one year deal. Don't be surprised if the SEB takes your ball away next year. |
#2532 | |
Senior Citizen
Drives: Scion FR-S
Its common practice for SP guys to jump to SM, depending on competition. Never heard of it in Stock classes, but there is always a first, right? |
#2533 | ||
The adage is "if it doesn't say you can, then you can't" but the definition of standard part lets you do a lot. There's good reasons for it being so open, but it might be worthwhile to explicitly pare this back. |
#2534 |
i'm sorry, what?
Drives: Canada
because a flat move of the FRS to BS under the assumption that every FRS owner will go out of their way to purchase a TRD Spring and Swaybar kit is just wrong.
This not only punishes those that decide to do this by throwing them in a class they have no business in, but also those that didn't do this by throwing them along with them. :/ bulletin prohibiting this weaseling is much more sensible.
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
