Old 04-12-2015, 03:15 PM   #8541
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by Shiv@Openflash View Post
We have 40 Procedes in stock right now. I'll have online order links up tomorrow. Between MX5 and GT86 ESC kits, I suspect that they will all be sold. Price for this first batch will be $399. Next batch may be a few dollars more due to the price of some components creeping up over the last year.
To answer other questions, the Procede will work (and install) on v1 kits the same way it does on v2 kits. The only difference is that on v1 installs, you need to tap one more wire instead of unplugging the audio jack on the throttle switch and plugging it into the Procede harness.
Rob and I have talked about how the Procede fits into the grand scheme of things. If you have an original v1 kits, there may not be a compelling reason to upgrade to v2 controller and v2 compressor as the Procede offers similar improvements to max ramp-up times. This is because it starts moving the compressor earlier in the throttle travel and offers a light-duty pre-spool mode to keep the compressor moving between shifts.
The new v2 batteries, however, can be considered a very worthwhile upgrade for existing rev1 users.
Wow that's a helluva turn around time. Gotta work on that video...
Installed Mods:
Old 04-12-2015, 03:15 PM   #8542
Silent_Dan
Drives: 2013 Scion FRS
Originally Posted by Sojhinn View Post
It's a separate purchase through shiv.
Will the procede controller work for the guys that already have ecutec or is it only for otf tunes?
Silent_Dan is offline   Reply With Quote
Old 04-12-2015, 03:16 PM   #8543
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
Originally Posted by Silent_Dan View Post
Will the procede controller work for the guys that already have ecutec or is it only for of tunes?
Should work fine with someone else's tune. Since the procede controller is reading the crankshaft sensor and the the DBW throttle blade position sensor.
Installed Mods:
Old 04-12-2015, 03:18 PM   #8544
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The Procede should work with any form of Ecu tune. It doesn't effect the tune itself. Just how the ESC is activated.
Shiv@Openflash is offline   Reply With Quote
Old 04-12-2015, 03:19 PM   #8545
Shiv@Openflash
Drives: 2013 FRS
Should work fine with someone else's tune. Since the procede controller is reading the crankshaft sensor and the the throttle position sensor.
Correction: it reads the crankshaft and DBW throttle blade position signal
Old 04-12-2015, 03:20 PM   #8546
Sojhinn
Sojhinn's Avatar
Correction: it reads the crankshaft and DBW throttle blade positional signal
Damn. I almost sounded like I knew what I was talking about. Fixed.
Installed Mods:
Old 04-12-2015, 03:55 PM   #8547
DAEMANO
Time Traveller
better get shakin' man
Old 04-12-2015, 05:12 PM   #8548
jflogerzi
jflogerzi's Avatar
Very cool. Would love to see a dyno plot with the new controller
2013 Series 10 FRS #553
Old 04-12-2015, 05:15 PM   #8549
Sojhinn
Sojhinn's Avatar
Would look exactly the same.
Installed Mods:
Old 04-12-2015, 06:39 PM   #8550
fenton
Ok literally just got home.
First off thank you to @DAEMANO and @WRB5titch for the awesome lunch. It was great seeing you guys.
Also sorry @Shutter if it wasn't for the horrendous LA traffic I would of stopped by the shop today.
I just want to chime in on a few things that daemano touched on.
After driving 48 hours with the procede controller I do not think I could go back to the partial throttle switch. (And the partial throttle switch is really good too.)
Why do you ask?
Yesterday I took a mountain pass near Watsonville, ca (route 152 I believe) from the bottom of the hill to the crest I drove and activated the esc many times in the middle of curves. The traction control system never activated a single time.
I do not think this would of been possible with the old switch.
Feel:
It feels like the esc isn't there. I know this sounds bad but it isn't. The car feels like a larger engine. And this in my opinion is amazing.
Also like daemano stated I spend most of my time in the low and mid range of the rpm band. And the procede controller really fills this niche really well.
Also I think this system will really kick ass in an autox.
Batteries:
Not a single damn issue the whole way down. The grape vine was my *itch and the batteries held up like champs.
Here's what's interesting. Whenever I activated boost the system would stop after a few seconds since I achieved the speed I needed. I didn't realize how often the system wouldn't be under boost.
Install:
I plan on making a video (I know how much guys love hearing my voice) and also the written instructions for the install.
Shiv and I believe the install will take about 20-30 mins. The hardest part being removing the connections for the ecu to tap.
All in all there are three wires to tap and 1 connection to the male throttle switch connection.
Bad news:
The only issue this has is very small one. When you first start the car you must NOT touch the the accelerator pedal as this is during the initialization of the esc controller and it can make things go a wee bit hay wire.
What this means is that you have to wait 10 seconds before moving the car.
I'll be happy to answer any questions anyone may have. Also daemano and wrb5titch both got a decent feel of the system as well, so they can chime in too.
When you say it needs to sit there for 10 seconds is that only the first install or every time you start the car?
My car is extremely loud and I basically start it and immediately release the clutch to get on my way and quite it down.
Cold start is SOOOO loud!
fenton is offline   Reply With Quote
Old 04-12-2015, 06:57 PM   #8551
raven1231
Seems like its every time which does kind of suck
Old 04-12-2015, 07:11 PM   #8552
Sojhinn
Sojhinn's Avatar
Yeah. Literally wait 10 seconds every time. Maybe Rob can figure out a way to shorten the time.
Installed Mods:
Old 04-12-2015, 07:11 PM   #8553
Shiv@Openflash
Drives: 2013 FRS
Just a little correction, you can drive upon starting the car immediately. Just refrain from going more than 50% throttle for the first 10 seconds as this is the time the Phantom ESC controller needs to initialize.
The same applies to the standard kit (without Procede). Except that you need to refrain from activating the WOT or Partial switch for the first 10 seconds.
We will probably release updated firmware for the Procede which automatically accounts for this (so you don't have to).
Old 04-12-2015, 07:15 PM   #8554
Sojhinn
Sojhinn's Avatar
I thought we had to make sure we didn't touch it all otherwise 0 for the controller registered as a voltage which could change activation points.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
