Old 04-12-2015, 07:48 PM   #8555
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Sojhinn View Post
I thought we had to make sure we didn't touch it all otherwise 0 for the controller registered as a voltage which could change activation points.
The Procede output is 0v until a certain throttle threshold (~under 50% pedal input). So driving "normally" is all this required for the first 10 seconds.
Shiv@Openflash is offline   Reply With Quote
Old 04-12-2015, 08:41 PM   #8556
churchx
churchx's Avatar
Drives: 2014 GT86
I wonder if it's not worth it to progam in tune for first 10sec to not open throttle > 50%? Or better limit throttle position reporting to SC in other ways, if doing that in first 10sec is bad. Humans make mistakes. Imho simpler to automate not letting them commit mistakes. I can imagine not that often but possible situation of stalling in crossroad on doing left turn/waiting for oncoming traffic to clear, and needing to quickly start engine and leave stationary position at WOT as soon as possible.
Old 04-12-2015, 08:41 PM   #8557
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
For any of those situations just shut off the esc. Not a big deal.
Installed Mods:
Old 04-12-2015, 09:16 PM   #8558
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Still wish to catch a ride in a twin so equipped. The closest that I knew of (Milwaukee) sold his and went full time FI.
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
Old 04-12-2015, 10:25 PM   #8559
jflogerzi
jflogerzi's Avatar
I would like to see the rev 2 kit with the Procede controller
Old 04-12-2015, 11:13 PM   #8560
DAEMANO
Time Traveller
Cool, I have a rev2 kit and will be ordering a Procede as soon as the ad goes live. Also @Sojhinn and also @WRB5titch is upgraded too so any of us will be able to demo for you. Corona is just down the 91 from me.
Old 04-13-2015, 12:27 AM   #8561
SimplePortal
Drives: Hot Lava
So I'm started on installing the kit I just received. I'm not sure if I got the alignment correct for the ESC. It looks off center and pointing a bit down. It felt like the silicon tube provided for the throttle body was a little bit short or maybe I installed it wrong.
Also is the fuse suppose to stick out higher than the others, am I not suppose to be able to put the fuse box cover back on?
SimplePortal is offline   Reply With Quote
Old 04-13-2015, 12:29 AM   #8562
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
Looks off to me too, and I'm not able to easily access my car at the moment to check the differences. Can you take a picture of your air box?
Also on the fuse. You can close the cover just have the wire side stick out towards the edge.
Installed Mods:
Old 04-13-2015, 12:34 AM   #8563
Sojhinn
Sojhinn's Avatar
Figured it out. You have the tube for the throttle body covered on both sides. You need about .5 inches of aluminum showing. It should fix everything. Between the two clamps.
As seen here: Attachment 106952
Installed Mods:
Old 04-13-2015, 12:42 AM   #8564
SimplePortal
Drives: Hot Lava
Airbox looks fine to me, it's mostly flush.
Do I need to push the fuse in more or does it stick out like this:
Old 04-13-2015, 12:46 AM   #8565
SimplePortal
Drives: Hot Lava
Can't see your attachment. Can you re-upload it again or host on an image site. I'll try readjusting the tube tomorrow night after work. Thanks.
Old 04-13-2015, 12:46 AM   #8566
DAEMANO
Time Traveller
I cant see your pics, but the fuse does stick out a bit more than the others. You'll know its in all the way when it wont go in any further and if the ESC turns on when the car is turned on.
Old 04-13-2015, 01:48 AM   #8567
tyrantcf
Drives: '16 WRX, CBR1000RR
Originally Posted by LucidMomentum View Post
YES. If the procede does all it's supposed to do, and makes this a more linear increase in power, then I am sold beyond sold. Perfect.
I do believe some of the credit for selling you on it is mine though
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 04-13-2015, 02:07 AM   #8568
TM
TM's Avatar
Drives: DGM BRZ 6MT
Does the procede controller only tap into the ESC system or does it tap into other wires in the car as well? How easy would it be to uninstall the ESC kit with the procede controller tapped into the car?
TM is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
