#8751 |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
Has anyone here with an ESC ever ran any of the short final drives. Such as Cusco or Mfactor 4.55, 4.88, etc?
I know I would like the 4.55 while I run the car NA, but I am curious as to the drivability of the car with the ESC installed. If anyone has any experience please let me know.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#8752 | |
Drives: 2013 Asphalt 6spd
Phantom ESC, OFH, OFT, K&N Drop in
#8753 | |
Drives: Scion FR-S A/T, Whiteout
Let me know if you have any specific questions. |
#8754 | |
CAR-AHOLIC
I wouldn't either. The primacy's were off my car the day I bought it. This is my second BRZ, and I already had an order in with Tirerack before I took delivery on my current BRZ. I run 245 square (probably try 255 next) and I usually run RS3, rivals, or equivalent tires. Do you believe the FD helps wake the BRZ up or do you believe with the ESC it is not needed. I primarily AX and track this car. It is not my DD, although I do cruise around in it on weekends. In hindsight would you do the FD again.
#8755 | |
Im pretty sure a FD change in a manual would result in very nice results especially for your application of AX. With my current setup i fight for traction in 1st when flooring it from a roll on stock tires
#8756 | |
When all is said and done, I'd probably do it again. Definitely would if I hadn't gotten the Phantom. On a track however, and even AutoX if you're competing, it makes sense to do the math and figure out what gearing you need for where you're racing. It's impossible to recommend an effective "across the board" final gear ratio. |
#8757 | |
CAR-AHOLIC
That is true. I actually AX( primarily) on a Sheriffs training course. It is much larger than your typical AX course and I see speeds of 70 or 80+mph out there quite often. My wife in the Cayman sees 80 to 90 quite often. So I am in 3rd gear a lot more than the average AXer. I will never get the gearing just right since our AX location allows for all kinds course layouts. I have no doubt that it could induce more wheel spin, since I can do that now even if the ESC is not installed......but as long as the FD does not make the car twitchy (bad manners) I can be judicial with the accelerator. Decisions, Decisions........Well I am definitely doing the OS Giken LSD, but I would love to complete both projects at the same time.
#8758 |
Drives: DGM BRZ 6MT
Does the Procede controller come with the necessary accessories to tap into the vehicle wires or do I need to make a trip to Home Depot or something?
#8759 |
Drives: Firestorm FR-S AT
Got a tracking number from Shiv for the Procede yesterday.
Phantom Electric Supercharger with Procede controller, GReddy SP Elite, CA-FI Dashlinq4
#8760 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Should come with everything you need if you are on v2. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#8761 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
![]() It's happening!!!
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
#8762 |
Just in case you need the link... heres the install video for the procede.
[ame="https://www.youtube.com/watch?v=5FpB5U2GJdo"]Procede Install for FT86 - YouTube[/ame]
#8763 |
Addicted
Thanks! Luckily it's easy to find on YouTube as well. "Procede ft86" done. Any other advice not in the video or areas to be extra careful?
#8764 | |
V2 or v1? V2 is a super easy install. Sent from my iPhone using Tapatalk
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
