Old 05-02-2015, 02:48 AM   #1275
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Originally Posted by x1UP View Post
Finally, an answer! Thanks. I am looking to be flush with the car (without using any spacers) which is why I was going to go with 235/40.
So, basically, that would work right?
This is my favourite online tyre/wheel fit calculator.
I've got three sets of wheels now and this calculator was valuable in not only choosing the offset I wanted but also the tyre size.
Give it a try http://www.willtheyfit.com/index.php...et2=42#content
I've pre-populated with the stock 18" tyre size for you but you may want to put the original 17" wheels in a there as the "before".
nzer is offline   Reply With Quote
Old 05-02-2015, 10:12 AM   #1276
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
This is absolutely brilliant. Thank you for this. This has helped me so much now.
So, when putting in my existing settings, it seems that by having these size wheels of 18x8.5 and tires of 235/40, the setup will be about 13mm closer to the strut. With me getting these in Falken tires, I'm hoping that it won't affect it too much by rubbing on it on a full turn.
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 05-02-2015, 02:37 PM   #1277
Ripp91
Ripp91's Avatar
Drives: 2013 Subaru BRZ
I picked up a set of rpf1's with 245/45/17 tires on them with a lot of life left. Do you guys think I should ditch them for 245/40's or just run them ? I feel like they might look a little too tall if I do decide to keep them
Ripp91 is offline   Reply With Quote
Old 05-02-2015, 05:10 PM   #1278
nzer
nzer's Avatar
13mm closer will be fine. I'm running 18 x 9.5" +45 with 255/35/18 tyres all around (yes we spell it with a "y" down here). Put that in compared to what you have now and you'll see they are far closer to the strut than yours. Mine just rub at full lock so you should have no rubbing on the strut.
I have coilovers and the TRD narrower race springs as I think mine were too close for the stock suspension.
Old 05-02-2015, 05:17 PM   #1279
nzer
nzer's Avatar
Although taller the 245/45 will fill the guards more. With only 12mm difference I'd try them first as you might actually prefer the look.
Here's the comparison. I've guessed at wheel size and offset but you're only talking tyre size so it's irrelevant anyway.
http://www.willtheyfit.com/index.php...et2=45#content
Old 05-02-2015, 05:35 PM   #1280
Ripp91
Ripp91's Avatar
Well I just took 10 minutes out my day to try the look lol and I think I actually might run these until theyre shot and just get new tires next season. It looks pretty good IMO
Oh and they're 17x9+45
Old 05-03-2015, 04:33 PM   #1281
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by willnigguhwassuh View Post
I have to or else I will rub. I didn't roll my quarter panel yet.
ah that makes sense, you gain A LOT of room one you roll, which is funny because there isn't much to really roll
Originally Posted by Khyron686 View Post
Tires are a bit bigger in diameter by like 2cm if that's what you are after. It will work fine, but 235/35/18 would be a closer to stock size.
honestly, thats such a tiny sidewall and a 235 on an 8.5 is already a slight stretch i think.
i would honestly got with a 245/40 all around so that you at least have some tire and not rubber bands. 245/40 is stock STi tire size on an 8.5 wheel. i know its not OEM diameter, but still.
you should be okay with that though, if anything you could always add a 5mm spacer up front if you're having issues.
Jive Turkey is offline   Reply With Quote
Old 05-03-2015, 05:03 PM   #1282
Allan13
Allan13's Avatar
Rota grids 18x9.5+38
Re760 265/35r18
PBM angle kit, PBM coilovers, PBM RLCA, Tomei 2way diff, Hydraulic Ebrake, Bride Seat, Schorth harness.
Allan13 is offline   Reply With Quote
Old 05-04-2015, 01:26 AM   #1283
marlonthegreat
marlonthegreat's Avatar
Advan RS 18x9 +38 square
GT Radial SX2 265/35/18 all around
P1200770 by marlonmercado77, on Flickr
P1200764 by marlonmercado77, on Flickr
marlonthegreat is offline   Reply With Quote
Old 05-06-2015, 03:10 PM   #1284
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
He's running 18 inch wheels. 245/40 on an 18 is over an inch bigger than stock. 245/40 on a 17 is meaty but in correct diameter. I have a set on order for my 17x8 inch wheels so I can finally partake in this thread.
Khyron686 is offline   Reply With Quote
Old 05-06-2015, 03:48 PM   #1285
stokeless
stokeless's Avatar
Drives: 2020 BRZ PP Silver
Nice stance... Any rubbing or fender work?
stokeless is offline   Reply With Quote
Old 05-06-2015, 07:40 PM   #1286
Jive Turkey
the tuna, no crust.
yes i can read. i know he is on 18's.
this thread is not for people that want to stick within the stock diameters.
a 235/35 is going to be stretched and have small sidewall. 245/40 is the more appropriate tire to run on an 8.5' rim in order to be "square". this is not a discussion about what will be closest to OEM specs. this is a thread for people who want to run appropriate tire sizes on wide wheels. 265's on a 9.5 etc etc.
here is 245/40 on an 18x8.75. a 235/35 would have been a rubber band in my mind. notice how it has an ever so slight stretch with a 245. this car is on eibach pro kit only. no fender mods, no rubs no issues.
also you will notice that the thread title is meaty tire thread. so 255+ would be meaty, everything else is just normal.
Old 05-06-2015, 10:57 PM   #1287
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
I think I've reminded people before that this thread is for 255's and up. But for some reason people think 235's and 245's are meaty SMH. Go back to the beginning people and read.
texasbound972 is offline   Reply With Quote
Old 05-07-2015, 05:29 PM   #1288
Khyron686
For a lot of people, meaty tires are sidewall HEIGHT, not some 275/25 rubber band on 19's. I personally don't think anything on an 18+ qualifies at a meaty tire. But this argument has been going on pretty much every car forum since the dawn of Gore's internet.
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
