Old 04-11-2015, 07:41 PM   #113
2much
I wanna go fast
Drives: 2013 FR-S 6MT
same. I am loving reading about the development of your projects... learning a lot along the way. it's great marketing
2much is offline
Old 04-14-2015, 12:25 AM   #114
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
I'm not so sure on that, but thanks .
We are still deciphering through the data to ensure everything was tested correctly but the big thing is the LCA, adjuster, and rod end all made it to 50,000 cycles at a very large bump load . Not only that, but being loaded 10 times per second!
To re-iterate what has been said before, the bump load we are and have been testing at are for those FR-S/BRZs that are at the race car level. These are loads beyond what ~95% of the customer base will likely ever see. Think 12kg/mm (762lb/in) + springs that are under *severe* compression to achieve these loads. That or pulling a Furious 7 move and jumping out of a plane .
I know it's hard to comprehend what a 4G bump load is because I have a hard time quantifying it. So if I can explain it in another fashion, please let me know and I will work on quantifying it in that fashion.
VerusEric is offline
Old 04-16-2015, 01:52 PM   #115
pseudo
pseudo's Avatar
Drives: 2008 Cayman S
Originally Posted by NotEric6 View Post
I've spoken with Jeremy, we will look into a poly in-board mount for those autocrossing. No guarantees, but we will look into it!
Subbed for this. Keep up the good work
pseudo is offline
Old 05-18-2015, 10:25 PM   #116
VerusEric
VerusEric's Avatar
Here's a few of the adjustment pieces we broke on our test bench.
We are finalizing logistics on a few things yet which is where the hold up is. Probably a few months out on a production order fulfillment but we are moving forward with the design and production once a few things are cleared up.
We also tested the OEM unit which proved to be strong like originally thought. We did not measure any strain (out of gauges) but physically it withstood the same tests as our LCA.
Old 05-18-2015, 10:30 PM   #117
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Whatd you do at work today? I snapped metal threads
cdrazic93 is offline
Old 05-23-2015, 04:44 AM   #118
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
updates?
When in doubt, throttle out!
FRS Johnny is offline
Old 06-24-2015, 04:48 PM   #119
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Just making sure this doesn't get completely lost
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline
Old 06-26-2015, 12:51 PM   #120
VerusEric
VerusEric's Avatar
It hasn't... but we have been faced with multiple set-backs, primarily with pricing issues. This is due to using United States machine companies as well as a superior aluminum to 6061-T6; which all of the other units on the market use.
We are going to try to do a limited run build I think.
Old 06-26-2015, 01:16 PM   #121
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Cant have quality without price, and anyone who understands R&D and the materials used will understand and appreciate the price, as long as its not like $1500
Old 06-26-2015, 01:20 PM   #122
VerusEric
VerusEric's Avatar
It's nowhere near that. We posted up a feeler on both social media accounts we use (Facebook and Instagram) and got some positive, but mostly negative feedback on the pricing.
We were thinking of doing a single group buy to get them out there and then come up with a more cost effective (but heavier) design. We don't want to abandon the design without at least trying a group buy though as a lot of effort went into them haha.
Old 06-26-2015, 01:23 PM   #123
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I would even suggest the likes of element tuning and CSG to get their hands on a set for the abuse they are meant for.
Does the design lend itself to requiring high quality material or would it be as simple as using a different material and literally the same design?
Old 06-26-2015, 01:27 PM   #124
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Now im just waiting for you guys to update the engine/trans sub thread with your...other goodies you're working on.
Old 06-26-2015, 01:41 PM   #125
VerusEric
VerusEric's Avatar
It's already been considered but that doesn't change the fact that people don't want to pay over X amount while other options out there exist for less. Even if it was used on a NASA space shuttle, if it's too much it's too much for that customer. It's been a large internal struggle because we could get it made overseas for less, but we're trying to keep things here, in the states.
The way it is designed, it would break with 6061-T6 aluminum.
Old 06-26-2015, 02:10 PM   #126
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
what about 6061 T651? or T89? both have a higher shear strength yield and ultimate tensile strength than T6, and roughly the same cost not looking for aircraft aluminum, because need money for other mods lol
edit; any metallurgists can chime in and correct me if my alloy's wouldn't work for LCA stress applications.
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 10:15 AM
Verus' Shop BRZ - Development Thread VerusEric Member's Car Journals 266 12-19-2019 05:12 PM
FT-86 SpeedFactory Diffuser by Verus - Complete Aero Solution FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 574 09-15-2019 11:10 AM
FT-86 SpeedFactory Turbo Kit - Development and Testing FT-86 SpeedFactory Forced Induction 271 09-20-2017 12:07 AM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 02:41 AM
