Old 05-24-2012, 12:18 PM   #71
guy
It seems there is a usb port behind the Pioneer Stereo head unit, but i don't see one behind the factory head unit. Is it easy to hook up the new head unit and the usb/jack port in the center console? I always feel annoying to see a usb cable hanging there...
guy is offline   Reply With Quote
Old 05-24-2012, 02:38 PM   #72
Based on the schematics and parts I've seen, the gray cable in the photo above is the cable going to the USB port on the center console in the FR-S.
Old 05-26-2012, 12:19 AM   #73
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
Damn, I should have looked closer at the dealer event tonight. I looked at the finished head unit install which was sharp but missed the goodies in the trunk.
5hairpins is offline   Reply With Quote
Old 05-26-2012, 12:43 AM   #74
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
job was clean and still had room in the trunk, good job @Juanito08 very clean fit and finish on the sound system!
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 05-26-2012, 03:30 AM   #75
Staticfrost
Drives: Eight Six
Anyone get full pics of his setup?
Staticfrost is offline   Reply With Quote
Old 05-26-2012, 06:49 PM   #76
devo6273
Drives: 97 civic
Juanito, where did you get your vinyl from? Did you have to buy a gigantic roll of it?
devo6273 is offline   Reply With Quote
Old 05-26-2012, 06:53 PM   #77
Nitro
Nitro's Avatar
Drives: 2013 Firestorm Scion FR-S
What wiring harness was used on the radio install?
Nitro is offline   Reply With Quote
Old 05-26-2012, 08:45 PM   #78
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
+1, this is what I want to know also please.
kmbkk is offline   Reply With Quote
Old 05-26-2012, 11:28 PM   #79
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Sorry guys been working alot and having a lot of fun with the car. Time to answer some questions
Thanks for the pics. Those RCA's are stock?? Wonder if they supply the factory subwoofers (I believe there are 8's in the rear?).
No there my own Rockford fosgate RCA's
Originally Posted by fernan2 View Post
So, do you like the Frs way more than the Tc??? What do you think about the two of them?
Way better car over all, the Tc has nothing on this car
Originally Posted by triwoody View Post
did you need a different mount for the new head unit, or did it fit right in.
It fits right in there's just a small gap on each side that stereo dash kit would be needed I used my old Tc one
Im actually about to sell some look under the member classifieds
[QUOTE=Nitro;226880]What wiring harness was used on the radio install?[/QUOTE]
Okay check this out I thought at first it was the harness for a src well its not its the same harness as the Tc!! And the bash kit works as well. The only thing that doesn't work on the stereo is the radio because it has a funky antenna pictures below
Juanito08 is offline   Reply With Quote
Old 05-27-2012, 12:56 AM   #80
triwoody
Drives: asphalt frs
do you have an idea of which antenna adaptor would fit into that plug, and what year was your tc?
nice setup btw
triwoody is offline   Reply With Quote
Old 05-27-2012, 01:15 AM   #81
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
nice setup btw
i ordered an adapter, ill let you all know if it fits after i get it. i had a 2010 scion tc
Old 05-27-2012, 01:25 AM   #82
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
If you don't mind me asking which adapter and from where did you order it?
Old 05-27-2012, 03:02 AM   #83
Sasquachulator
Pavement Grey
So you dont have to take apart the dash to get to the stereo? Just pop those trim pieces off and its there??
Old 05-27-2012, 06:16 AM   #84
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Nice mods there Juanito!
stevo_12v is offline   Reply With Quote
