Old 06-04-2015, 03:35 PM   #939
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Deadpool_25 View Post
Thanks buddy32. However, I've read through this thread a few times (and am reading again as you suggested) but I'm not really seeing an excellent solution.
@sw20kosh and @mkivsoopra look to be using the same 25 row setrab which seems to be doing a good job in 75 degree ambient, but is still untested in 100+ degrees. I suspect it will be sufficient at those temps, but there is still the issue of it overcooling for street use.
"This oil cooler is overkill for anything but turbocharged hot summer track days. It literally has to be disconnected or blocked for regular daily driving." - sw20kosh
"It is way overkill for street though. I actually have it disconnected now, otherwise I'll be seeing 150F while cruising on the freeway. This is WITH a thermostatic sandwich plate." - mkivsoopra
I'd like something that will suit all my needs:
- daily use during normal driving
- daily use during spirited driving
- occasional canyon runs
- occasional track days in "normal" weather
- occasional track days in omgwtfhot weather (100-115F)
I'm aware though that it's sometimes tough to find a perfect solution in this hobby.
I think the PTuning oil cooler may be the best answer, as it seems to be able to handle the first four of those just fine, and will still allow a little fun even during the last one. Or maybe I'll just skip track days in AZ summers and head out to San Diego and hang out on the beach.
Thanks,
Kevin
No the Ptuning cooler won't work for track unless you want to limit your sessions to 3-4 laps. We've witnessed it first hand here on CA tracks in "normal" weather. Not only does it not cool the oil enough during hot laps but it also raises the coolant temps with it.
Old 06-04-2015, 06:00 PM   #940
Deadpool_25
Drives: BRZ Limited
Ah okay. Thank you very much. I will eliminate it from my consideration. I will talk with the shop and see what we decide on. My guess is we end up doing something custom.
Build Thread
PTuning Turbo & Exhaust / JDL UEL Header / Delicious Tuning Flex Fuel / Eibach Pro-Kit Springs
Deadpool_25 is offline   Reply With Quote
Old 06-04-2015, 06:09 PM   #941
sw20kosh
20 row or 15 row series 9 setrab
Old 06-08-2015, 03:50 PM   #942
Deadpool_25
Drives: BRZ Limited
I have a question about some of the dyno graphs. If this is true:
"The formula for figuring HP is TQ x RPM / 5252. So HP is a function of engine TQ and is directly related to RPM. As you can see from the formula, HP will always be lower than TQ below 5252 RPM's and above TQ at over 5252 RPM's." - https://www.amsperformance.com/resou...-tq-dyno-chart
How come some of the charts don't cross at 5252? Just curious what causes it to be different sometimes.
Build Thread
Old 06-08-2015, 05:17 PM   #943
mkivsoopra
HP and torque will always have equal values at 5252, but if they don't visually cross at 5252 on the graph, that just means the HP/torque axis scaling is different. (or someone is using photoshop)
mkivsoopra is offline   Reply With Quote
Old 06-08-2015, 06:47 PM   #944
sw20kosh
If the left and right Y-axis of the graph don't line up, then hp and tq wont cross at the same rpm.
Old 06-08-2015, 06:56 PM   #945
Deadpool_25
Drives: BRZ Limited
Ah. Obviously. Yup, thanks guys.
Build Thread
Old 06-08-2015, 07:31 PM   #946
MooKz
MooKz's Avatar
Drives: 2013 Scion FR-S Firestorm Red
Quick question guys.. I'm wrapping up the install of my turbo kit tonight.. is the basemap preloaded on the supplied usb flash drive or do I have to get the file from PTuning?
MooKz is offline   Reply With Quote
Old 06-09-2015, 08:28 AM   #947
Martyr03
Drives: Scion FRS
you have to get it from ptuning.
Martyr03 is offline   Reply With Quote
Old 06-09-2015, 10:09 AM   #948
kanundrum
Drives: 2013 Whiteout FR-S
They should be open in a little bit I would give them a call as that is the fastest way to get a hold of them
Old 06-09-2015, 10:36 AM   #949
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Dat PTUNING low turbo lifestyle bro:
Old 06-09-2015, 10:40 AM   #950
Raven604
Wrong car
Raven604 is offline   Reply With Quote
Old 06-09-2015, 10:53 AM   #951
Ken@PTuning
Drives: '92 Nissan 240sx KA-T
Send a message via AIM to Ken@PTuning
It comes down to exactly how we measure engine RPM on the dyno at the time of tuning. We have 3 ways to measure engine RPM: ignition signal, tachometer signal, or road speed.
Usually, we use road speed as it is the quickest/easiest way to do it but its not the most accurate. Just like how the vehicle measures road speed at an axle, we measure RPM by using a ratio of MPH/RPM. The problem is that the tires like to expand at higher torque numbers so the MPH/RPM ratio changes. This isn't a problem because the HP/torque is measured independently of the RPM reading but can make tuning irritating because we have to figure out where we are relatively in the RPM range. We always end the pull at redline so the end point is always a known RPM but the entire scale may be off.
For a cleaner reading, we can take a reading directly from the ECU's tachometer output wire. This lets us plot the true RPM and is the most accurate. Depending on the vehicle, this is the hardest source to get as normally we have to T-tap directly into factory wiring. Worse yet, the FR-S doesn't have a tachometer signal wire! We have to use a patch harness to connect to a pin that exists on the ECU, likely there for development and R&D purposes. We'll normally do this on high HP builds (turbo, SC, etc). The third way is to use an inductive clamp like a timing light, but getting to the ignition coil wires is not the easiest thing (no space).
Ken@PTuning is offline   Reply With Quote
Old 06-09-2015, 11:10 AM   #952
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
So would you recommend an oil cooler for my oil cooler so i can cool while im cooling?
Darryljr11 is offline   Reply With Quote
ptuning, turbo kit
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2639 04-05-2026 11:31 PM
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 11:46 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
