Old 06-05-2015, 03:18 PM   #197
Eski
Eski's Avatar
Drives: '15 Brz Series Blue
Originally Posted by Demandred7 View Post
Still want to see one in person. I have to respect what Mazda is able to do with this car.
I still require rear seats (regardless of their small size) and I have no desire to own a topless car. Rent or borrow maybe, but, not to own. The FR-S suits me better. And not a fan of body roll in a car.
I second that notion. Also i'll never fit into these cars, being 6'5...
Condoms 97% effective at preventing pregnancy...
Miata's 99.9%
"Listen, smile, agree and then do whatever the fuck you were going to do anyway." -Robert Downey Jr.
Eski is offline   Reply With Quote
Old 06-05-2015, 03:28 PM   #198
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
I went from a NC2 to BRZ back to NC2.5 now going on to ND.
Hanzo is offline   Reply With Quote
Old 06-05-2015, 03:29 PM   #199
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Miata's 99.9%
Love the Robert Downey Jr quote in your sig.
Demandred7 is offline   Reply With Quote
Old 06-05-2015, 03:43 PM   #200
Sideways&Smiling
Drives: AP2 S2000, S14 240sx
Originally Posted by Entroper View Post
Depending on how it's measured, the weight distribution varies significantly. The fuel tank is in the back, and the driver's seat is behind the CoG. So it might be 50/50 with a full tank and a 175-lb driver, and front-biased when empty.
The article from my original post has a direct comparison on page 3: http://www.motortrend.com/roadtests/...son/specs.html
52/48 for the ND, 55/45 for the BRZ. Whatever the "real" figures are, this at least tells you that the BRZ is more front-biased, if you assume MT didn't screw up the measurements.
I'm pretty sure I read that the FR-S/BRZ 54/46 or 53/47 with driver... which is really close to the 240sx/Silvia (like it is in every other way too. haha.).
I'm pretty sure the ND is like the NC (and the S2000) where the engine sits completely behind the front axle, which is not the case for the FR-S/BRZ.
Sideways&Smiling is offline   Reply With Quote
Old 06-05-2015, 04:15 PM   #201
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Jives with owner results on the 86, I forget these things are solidly under 2,800 lbs for some reason.
http://www.ft86club.com/forums/showthread.php?t=7881
What's curious is that MT reports a 2,296 lb weight for the ND when Mazda is claiming ~2,330. 35 lbs ain't nothing to sneeze at, 10 of those are the Brembo package so I'm wondering if MT didn't have a full tank, would explain the 52/48 F/R balance. Subieyota claims a 2,758 so I can see 6 lbs here and there. Or maybe there's more weight saved on the Brembos than reported.
Maybe the conspiracy is that MT/Mazda pulled all the roadside safety kit out the back to get that extra 0.05 second on the comparison.
ineedyourdiddly
Old 06-05-2015, 05:03 PM   #202
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
@krayzie
Another quote, browser isn't letting me edit:
I guess my main point is that how I've always understood it is that; if you want to develop a good car, you can't purely rely on high grip tires and electronics as crutches to achieve the bulk of the available mechanical grip.
High performance chassis and suspension development will come into play in order to share the load especially when closed to the limit.
Effective marketing is usually just throwing out a bunch of numbers.
I don't think Toyota has ever had a FR sports car with dead on 50/50 weight distribution. It's always more like 53/47 or 52/48 even with the last gen Supra.
krayzie is offline   Reply With Quote
Old 06-05-2015, 05:08 PM   #203
DarkSunrise
DarkSunrise's Avatar
Journalists loosely refer to the 350z/370z, Miata, RX-8 and Twins as having 50/50 weight distribution, but all are slightly front-heavy. Same for some BMW's, despite what their marketing says about "perfect balance".
2022 BRZ Build
2013 FR-S Build
Old 06-05-2015, 05:25 PM   #204
fatoni
I think thatthat the thought process is based on accelerating out of the corners shifts the weight rearward.
Drive upgrades. Don't buy them.
Old 06-05-2015, 05:32 PM   #205
strat61caster
100% agreed.
However, I think saying that the tires were chosen to show off the chassis is a... well it's a statement I can't wrap my head around. If you remember this is the statement that made a few of us scratch our heads:
They even went as far as to equip the car with a low grip tire just to prove their efforts in chassis and suspension R&D is brilliant.
The primacy's were explicitly chosen to show off the car as you said, get journalists and potential buyers during the test drive to smile and rave about how much 'fun' the car is, and it worked like a charm. Sure it's indicative that Toyobaru did their homework but as you say, a lot of it is marketing.
As for the weight distribution thing, you're forgetting the MR2's ranging from 45/55 to 43/57 F/R depending on generation, trim, and conditions.
ineedyourdiddly
Old 06-05-2015, 05:48 PM   #206
serialk11r
Drives: '06 AM V8V Coupe
Well, when the rear tires are the only ones being driven, it's better to have more than ~55-60% weight at the rear. One thing I hate about my FR-S is that I can't gas it during a turn without drifting, I like how MR cars stay planted up till a certain point. Life is more fun when you floor it.
The twins are not close to 50/50 in my book, 54/46 unloaded is quite front heavy, some FF cars are around there.
Old 06-05-2015, 05:56 PM   #207
Sideways&Smiling
The 350z and 370z were never marketed as having 50/50 weight distribution. The 370z is like 54/46 without driver, I believe. They have marketing about this saying that it's forward to allow the weight to shift correctly to give better balance/stability under load, but it's mostly BS.....
Not sure about the RX8, but I know the RX7 and S2000 were specifically marketed as having 50/50 weight distribution.
Old 06-05-2015, 05:58 PM   #208
Sideways&Smiling
Yeah, the more forward biased weight is for easily holding/recovering from drifts and having more time to correct accidental oversteer... It's definitely not for ultimate grip or ultra-quick/sharp response.
Old 06-05-2015, 07:22 PM   #209
Pat
Pat's Avatar
Drives: 2023 BRZ
I highly doubt manufacturers intentionally put more weight up front to more easily hold/recover from a drift.
Old 06-05-2015, 07:56 PM   #210
DarkSunrise
Yeah that was Nissan's given reason. In theory it also gives better steering feel, making it more obvious as the fronts get unloaded with power. Obviously not the best for performance, but at ~200 hp not a big deal.
There's a reason I said "journalists" and not manufacturers.
2022 BRZ Build
2013 FR-S Build
4th gen ND Mazda MX-5 Miata Dark Other Vehicles & General Automotive Discussions 1392 12-16-2021 02:09 PM
Twins vs 2016 Miata (ND body style) will be revealed in 15 minutes glamcem FR-S / BRZ vs.... 56 09-13-2014 07:11 PM
2016 mazda miata (MX5) reveal 9 PM EST Ernie L Off-Topic Lounge [WARNING: NO POLITICS] 1 09-03-2014 09:41 PM
Motor Trend Car of the Year... Dorb BRZ First-Gen (2012+) — General Topics 1 11-13-2012 08:33 AM
