#477 | |
Drives: 14 Ultramarine FR-S
Was wondering if there could be an issue there.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#478 |
Drives: FT86
look at the difference between commanded afr and actual afr if it way different then ol maf scaling is off or you have leaks. the stage 2 tunes do run a but richer than stage 1.
#479 | |
LTFT seems to be pretty stable... hmm...Shouldn't be any leaks as I double checked my torques on the install.
#480 |
Legend
Drives: Whiteout FR-S
This is OFT tune.
Hey guys, I just flashed to UEL Stage 2 E85. Do these values look normal?? They are different than what I had with the EL stage 2 E85 tune. Especially the AFR and fuel trims. This log is recorded during the 90-100 mile number after flash. My setup. MXP catless header + overpipe, berk high flow cat front pipe, q300 catback and E85. Also I never got a CEL light but if I check codes with OFT I get fault codes p015a and p015b. http://www.datazap.me/u/dnuorgrednu2...5?log=0&data=1 Thanks. Last edited by Sovereign; 06-24-2015 at 06:41 PM. Reason: Link |
#481 | |
Drives: FT86
Those codes indicate slow respomse of 02sensor to rich lean condition, maybe you have air leak in exhaust or problem with o2 sensor |
#482 |
Legend
#483 | |
Drives: FT86
you have high positive fuel trims up to 15% that means ecu is adding fuel if thats first tank of e85 then usually the residual petrol makes it run rich and you get negitive fuel trims you usually only get hight positive trims on e85 if you e% is rearly high like over E85 for those level of positive trim. air leak in exhaust will leak in fresh air and make o2 sensor think its lean so ecu adds fuel. or o2 sensor is damaged or your running a petrol tune with e85 in tank |
#484 | |
Legend
I'm pretty sure the tune is a E85 tune. I'll check again. This is not my first e85 tank either so I guess I'll check for air leaks since this just started happening after the headers were installed. It doesn't sound like there is a leak in the exhaust though. I also topped off my e85 tank after about around 50miles after the flash to the UEL tune with 1/3 tank left but it is in the same place I always do it so it shouldn't be a problem or a very high mix.
#485 | |
Drives: FT86
new gaskets ? did you run a thread tap chaser through the header o2 threads, if you had to force o2 sensors in it can damage the threads causing a leak. check the sensors are pluged in correctly black to black and grey plug to grey socket. |
#486 | |
Legend
#487 |
Drives: '13 UM86
Can anyone, maybe @steve99 give me a review/feedback of my mini run tonight? Just installed my Tomei UEL and OP. My full list of mods are in my signature below. I also have a HKS drop-in filter if that counts or needs to be known. I was running E85. It was 70 degrees out. I appreciate the help.
http://datazap.me/u/1086/tomei-uel-e85?log=0&data=1
![]() JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport Last edited by themajesticone; 06-25-2015 at 04:11 AM. |
#488 | |
Drives: FT86
Their is also a bit of knock somewhere before log started as IAM starts at 0.85 and is climbing back towards 1. it might just be fuel trims need a bit more learning and residual petrol causing that bit of knock. If you log FLKC and Knock Correction (FBKC) instead of vvt intake and exhaust would help to see knock. and log Commanded AFR and Engine load instead of oil/coolant temp. try a Vishnu Reset -Trick Yes you can google it :-) Basically it speed's learning of Fuel Trims and will Reset you IAM to 1 if it has dropped due previous knock events (assuming its not knocking at low/steady loads if so you have serious knock problems). If you do 2 or 3 "vishnu reset" runs ie partial light (20% or so) steady throttle runs from 2000-6000rpm or so in 2nd or 3rd it will set your fuel trims and reset your IAM (assuming is not knocking at low/steady loads) if its less than 1. The gear is not really important its the partial steady throttle the longer the run the better. A slight uphill grade can be useful (or you can left foot brake). This works anytime to reset IAM back to 1 (assuming its not knocking at light load) it useful when your chasing knock in an area and want IAM back to 1 without an ECU reset. |
#489 | |
Drives: '13 UM86
![]() JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport |
#490 |
Drives: FT86
no just drive the car at light throttle through the rpm range as above should do it.
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
