Old 07-13-2015, 08:56 PM   #1
kosoku
Drives: 2013 fr-s
new exhaust setup with no tune?
Looking for some insight.
Just bought the Perrin resonated cat back (should be quiet) + HKS dual resonated front pipe (should be quiet) + ptuning header (should be f*ckin loud).
Ptuning recommends tuning it ASAP after installation.
My question for those out there who have similar mods - did you tune yours right away?
I know I'll get the best results with a tune and I will do one this winter. Until then, should I wait to install?
I would think the air fuel ratio sensors would see the extra air and adjust accordingly, no?
I don't drive the car often but when I do I drive it hard.
Any insight is appreciated!
kosoku is offline   Reply With Quote
Old 07-13-2015, 09:03 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
So, you have the option to fully plan your exhaust from the ground up and CHOSE to have zero catalytic converters on a street car?
You won't get any help from me and I'd encourage others not to also.
Old 07-13-2015, 09:11 PM   #3
Bergen23
Drives: '15 Halo FR-S
Research what tuning options are out there. As far as I know, there's no damage done by not running a tune, but you'll have a CEL without a tune
Bergen23 is offline   Reply With Quote
Old 07-13-2015, 09:26 PM   #4
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
If you don't get a spacer with the header, you'll probably get a CEL. Not sure if theres a CEL workaround for the resonated front pipe though...
If you don't mind driving around in limp mode, there shouldn't be any harm in not getting a tune. AFR and trims should be fine. If anything, get a used OFT and then sell it back later -- they don't really go down in value at most you'll lose out on shipping only and a little bit more maybe...
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
Old 07-13-2015, 09:31 PM   #5
kosoku
Drives: 2013 fr-s
I do have the option of not running a cat. Who said it was a street car?
thanks for no help
Old 07-13-2015, 09:48 PM   #6
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Your fueling and timing maps are going to be off. As you said you like driving hard, I highly recommend you get a tune before doing any romping.
If you pop, the fun stops.
JDKane527 is offline   Reply With Quote
Old 07-13-2015, 10:09 PM   #7
kosoku
Drives: 2013 fr-s
Fair enough! Good advice.
Not sure if I'll be able to put the exhaust and headers aside until I can afford the tune. Its going to kill me!
Old 07-13-2015, 10:25 PM   #8
Bergen23
You can install everything but the header without a tune
Old 07-13-2015, 10:39 PM   #9
Teseo
Drives: frs
maybe?
Old 07-13-2015, 10:47 PM   #10
mcbrawr
Drives: 2014 BRZ Limited
Way to be an asshole. I'm sure that was very helpful for the OP to read.
I'd agree with the OFT idea. You won't lose much on the purchase with the added benefit of enjoying your car before getting it custom dyno'd.
mcbrawr is offline   Reply With Quote
Old 07-13-2015, 11:24 PM   #11
steve99
Drives: FT86
Put an O2 spacer or defouler in the REAR 02 sensor this should eliminate the P0420 car efficiency cel code due no cat in header .
some headers it shows up quickly some it takes a week or so, just be prepared to reset cel occasionally with andriod torque app or obd scanner reader or pull a battery terminal for 30 secs or so.. If you get cel other than P0420 investigate.
P0420 wont force ecu into limp mode but it will disable cruise control and may drop you to safe afr and timing maps reducing power.
it wont blow up without a tune it just wont generate optimium power due fueliing ignition and cam timing not being optimal for your setup.
stock tunes run rich
your more likely to get issues by changing intake and upsetting maf scaling
Old 07-13-2015, 11:29 PM   #12
kosoku
Drives: 2013 fr-s
Thank you!!
Old 07-13-2015, 11:38 PM   #13
DAEMANO
Time Traveller
Don't get exhaust parts without a tune. Especially a "full" exhaust without a tune as you'll waste hundreds chasing the unattainable without a tune. Don't worry, if you go the OpenFlashTablet route, you can always flash back to your totally stock tune and no dealer will know the difference. Pay attention to @steve99 's posts (many below) as well as @Shiv@Openflash 's posts if you decide to go the OFT route.
1. Get OpenFlashTablet first - Load Stg 1 tune - Enjoy ~170 WHP/ ~137WTQ
http://www.ft86club.com/forums/showthread.php?t=71157
2. Get e85 - Load Stg 1 e85 tune - Enjoy ~200 WHP/ ~157WTQ
http://www.ft86club.com/forums/showthread.php?t=67310
http://www.e85locator.net/State%20Pa...tml#Cincinnati
3. Get any catless/high-flow catted header UEL/EL don't really matter - Load Stg 2 e85 tune - Enjoy ~205 WHP/~162 WTQ
http://www.ft86club.com/forums/showthread.php?t=55450
4. Get any catback - Enjoy improved exhaust note and maybe a couple more WHP.
Skip everything else as the other exhaust parts only add a handful of extra ponies, but will cost you hundreds more in your build. Put that money on tires, brakes, driver-mod, oil cooler, catch can, etc.
Last edited by DAEMANO; 07-13-2015 at 11:47 PM. Reason: added "high-flow catted" cause Wayno made me feel bad =(
Old 07-13-2015, 11:42 PM   #14
Wayno
Wayno's Avatar
thanks for no help
You're pumping CO and NOx into the air around your own children and neighbors and I AM THE ONE WHO'S NOT HELPING?
In the very first paragraph of your blog it says:
"So, not wanting to rise the dead or piss off the entire neighborhood I decided the rest of the exhaust should be resonated and as quiet as possible."
So, you start the car and presumably drive it in your street, therefore street car.
Even rally cars run catalytic converters and they find they do not restrict flow at all.
Honestly, people without running cat-less should take some responsibility like grown fucking adults.
They also tend to be the ones asking the same stupid fucking questions over and over instead of researching or simply searching first.
Once again, grow up.
Anyone has this exhaust setup? jgonx213 Engine, Exhaust, Transmission 1 02-17-2015 06:01 PM
Help on exhaust setup fitment Simon Engine, Exhaust, Transmission 0 07-01-2014 04:05 PM
Exhaust Setup Help JohnAyySays Engine, Exhaust, Transmission 2 02-25-2014 03:46 PM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 03:58 AM
Exhaust setup? Kelbyat07 Engine, Exhaust, Transmission 37 09-19-2013 06:20 PM
