Old 07-20-2015, 02:35 AM   #2647
bumppinKota
Drives: FRS!!!
Originally Posted by SPCorBUST View Post
Take a look at the CSG track videos, they might give you what you're asking for.
Personally, I think the kit is quiet. Quieter than the Vortech kit, Sprintex kit, and the KraftWerks kit especially by a good margin, the latter which I've also owned, including their quieter cogged pulleys. (vs. their smooth pulleys)
If I wasn't always driving solo and had a UEL now, I would make a video for you. The way the car is currently set up, the exhaust basically masks any other noises.
Would be interested in that video.
bumppinKota is offline   Reply With Quote
Old 07-20-2015, 12:40 PM   #2648
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Yup- once you add a UEL, all I hear is a rumble.
ApolloSki is offline   Reply With Quote
Old 07-20-2015, 03:32 PM   #2649
CSG Mike
CSG Mike's Avatar
Originally Posted by twag4 View Post
Will somebody please make a good in cabin video of a run or two through the gears, or a run with hard acceleration and braking(such as a good mountain road run)? I have only seen one video that does this very well at all, and I just want to hear the sound of this supercharger. Or is I very quiet, and that is why I cannot hear it?
You basically cannot hear it in a video. You'll get a little noise off-throttle at higher RPM from the recirculator, and a tiny bit of induction noise with sharp throttle inputs at VERY low speeds (same as an intake).
Of course, if you *want* noise, you can always add a BOV...
Old 07-20-2015, 03:42 PM   #2650
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I'll make a better video soon, but mine is noticeable.
Still not sure if there's something wrong with it though since it doesn't seem to sound like anyone else's.
Old 07-21-2015, 12:37 PM   #2651
bear89103
Old Fart
bear89103's Avatar
Does a BOV work with this kit? And where would you attach it???
Project Panda86 Journal -
bear89103 is offline   Reply With Quote
Old 07-21-2015, 12:52 PM   #2652
DaiTT500
DaiTT500's Avatar
Drives:
The kit has a bypass valve that acts like a blow off valve but it recirculates. I am not 100% sure but I believe you have to recirculate it so that Mass Air Flow does not go crazy. I think if you vent it to atmosphere the engine could keep shutting off, but I am not a tuner so I don't know if this is the case or if there is a work around.
DaiTT500 is offline   Reply With Quote
Old 07-21-2015, 01:54 PM   #2653
CSG Mike
CSG Mike's Avatar
Where the recirculator is. A re-tune specific to the BOV is recommended, even though the BOV would be way, way ahead of the MAF.
Old 07-21-2015, 03:22 PM   #2654
bear89103
Old Fart
bear89103's Avatar
Seems like pretty ridiculous work just to make the car go woosh woosh.
Old 07-21-2015, 03:23 PM   #2655
DaiTT500
DaiTT500's Avatar
Drives:
You would have to do the same thing with a turbo kit.
Old 07-21-2015, 03:41 PM   #2656
Yoda
Drives: Crystal Black BRZ(Sophia)
Don't underestimate the power of the woosh
Yoda is offline   Reply With Quote
Old 07-21-2015, 04:07 PM   #2657
SPCorBUST
SPCorBUST's Avatar
Couldn't we use the Perrin BOV?
For cars that require recirculating blow off valves, it is vital that it recirculates the air back to the intake track to maintain proper air-fuel ratio and driveability between shifts.
For cars that can utilize vent to atmosphere blow off valves, this can be set up as a vent to atmosphere style blow off valve. We only recommend that on cars running aftermarket Speed Density type tunes (cars without mass airflow sensor).
If you're running an SD-only tune (perhaps from Delicious Tuning?) maybe you could just disconnect the MAF, block off the hole and set the BOV to atmosphere. Anything else, just run the BOV in recirculate mode.
I'm still setting things up for a custom tune anyway, so if that sounds doable, maybe I can try it since it fits with my build.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 07-21-2015, 06:23 PM   #2658
CSG Mike
CSG Mike's Avatar
The IAT from the MAF is still used, but you could always weld on the BOV.
Old 07-21-2015, 06:47 PM   #2659
Xuningshen
Drives: Subaru BRZ
[ame="http://www.amazon.com/Turbosmart-TS-0203-1022-Kompact-Universal-Valve/dp/B001N21VIE/ref=sr_1_1?ie=UTF8&qid=1437514985&sr=8-1&keywords=turbosmart+dual+port+25mm"]Amazon.com: Turbosmart TS-0203-1022 Kompact 25 mm Dual Port Universal Fit Blow Off Valve: Automotive[/ame]
this "fits" perfectly as a replacement of the plastic one we get with the kit. you have to set it pretty soft but it works.
whats cool too is that you can just use one of the included plugs and it can be full recirculating instead of 50/50 Vent to atmosphere/recirculate. it'd just be a replacement to a higher quality piece... not really needed but hey... because racecar.
I had it 50/50 when running the carb tune and I can tell you it didn't run as smooth as when running the included plastic BPV but it still ran. I swapped back and forth between the turbosmart kompact and the included plastic BPV.
ever since switching to a speed density tune its a lot smoother, but still not as smooth as the carb + plastic BPV, probably like 95% there though so I don't mind.
when you build up boost and let off the throttle it has that initial high pitch BOV noise, followed by a "who just unplugged an air compressor hose?" noise.
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 07-23-2015, 02:11 PM   #2660
264grendel
Drives: 2013 Scion FR-s
Hey guys, not sure if my google-fu sucks or what. Thought I'd try here to find some answers. For those who have supercharged their car and have installed a wideband AFR gauge with stock headers, where are you guys mounting your O2 sensor at. I've seen a thread where they have welded the O2 bung on their front pipe right before the cat, or on their overpipe, but instructions and other people say to place the sensor before any cat. Does that mean you can't have any cats in front of the sensor including the primary to have an accurate reading. Or does it mean you just have to have it in front of a cat? So would I be good welding the O2 bung to either the overpipe or the front pipe? Any help would be appreciated.
264grendel is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
