#71 |
Drives: Toyota 86 GTS
No not EL. UEL.
#72 |
Drives: FT86
#73 |
Drives: FR-S 10 #103 AT
I've increased the timing a bit to get back some from Wayno's conservative timing tables for the craptastic Aussie fuel. I'm seeing some correction in the logs but the multiplier is rock solid at "1". Does this mean I don't need to worry about the corrections?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#74 | |
Drives: UK GT86
.: Stealth 86 :.
#75 |
Drives: Asphalt Scion FR-S
So i've read that thread for DBW editing in BRZ edit, but has anyone succesfully done it with Rom Raider?
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
#76 |
Drives: UK GT86
In what way? It's exactly the same.
.: Stealth 86 :.
#77 |
The tables look different. .. maybe I'm looking at the wrong ones
#78 |
Drives: UK GT86
The values may be different but the theory will be the same.
.: Stealth 86 :.
#79 |
Drives: Supra, 2014 BRZ
Hey guys, have the timing numbers for the ace header on the 1st page been tested?
Theres no link to go along with the timing numbers. I'll be installing mine tomorrow and will be flashing with the stage 2 el 93 oct OFT tune. Any info i can get is greatly appreciated. Thanks for putting so much time into educating us noobs. |
#80 | |
Drives: FT86
#81 |
UCSB!!!
Drives: 2017 GTI sport
Does anyone know if the OTS tunes for stage 1 and stage 2 are 91 or 93? All it says is Stg1 B01C.bin and Stg2 UEL B01C.bin?
#82 |
If your off the shelf C tunes don't have folders for 91 and 93 you need to download the latest 2.0x package from openflash.
#83 | |
UCSB!!!
I sort of wish each tune file was titled with the appropriate Octane, for example, 91 Stage 1.bin. Nonetheless thank you for assisting me
#84 | |
Drives: FT86
If you upload a new tune to the slot with the "*" on it its no longer the tune in ecu. the "*" just flags the last slot written to ecu OFT does not actually check or compare :-) |
| Drift Office Tune vs Visconti Tune | mechaghost | Engine, Exhaust, Transmission | 109 | 07-03-2014 01:57 AM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 09:15 PM |
| difference between vortech tune and perrin tune? | Frs32907 | Forced Induction | 7 | 12-05-2013 03:49 PM |
| Information I did not want to know. | K2 | Great Lakes | 19 | 07-23-2012 09:18 AM |
