#43 |
That does not sound normal. Do you feel it in the clutch pedal as well?
#44 |
#45 | |
Waited 5 years for this
Drives: '18 MX-5 Club
Post #13 has a video. My car makes the same sound (My post is #17). |
#46 |
Drives: Asphalt Scion FR-S
My throw out bearing exploded at 43k. Replaced the clutch assembly with an exedy stg2 clutch. The stock clutch assembly was still in good shape and had a lot of life left when it was removed.
#47 | |
#48 |
Drives: for the sake of driving
Petro, your car is fine, don't worry about it lol
'13 Argento FR-S
#49 |
Drives: old
Have any of y'all with burnt up throw out bearings, experienced any strange honking noises while shifting prior to the bearing failure?
#50 |
#51 |
Drives: 2013 Firestorm FRS
will the aftermarket ones have the same issue as stock? Melting anyway...
#52 |
In this post, @LavosTRD explains it pretty well. At 15Kmi I am just now starting to feel an occasional little rumble in my clutch pedal as I depress it. With so much free play in the races coupled with a sloppy plastic guide, I can picture the rotating race sag and make contact with the pressure plate off-center. Is that the rumble I feel? Hmmm...
I suspect this is the beginning of the death march.
#53 |
Drives: FR-S Whiteout
I wish I had one of you forum members/toyota techs at my dealership. Life would be much easier. I'm hoping I didn't get an 86 with the bad rocker arms.
Intent > Content
cowardice is the mother of cruelty. |
#54 | |
#55 | |
Intent > Content
#56 |
Toyota Master Tech
Drives: Whiteout MT
There is not a bad batch of rocker arms. The reason they are failing are because they are losing oil pressure to them at higher rpm and they spit out. On toyotas other motor where I have seen it happen it harmlessly falls into a void in the cylinder head. But because of our boxer engine, gravity decides to give us the royal middle finger and blow shit up.
| Throw-out bearing | mhigham | Issues | Warranty | Recalls / TSB | 71 | 08-18-2016 11:21 AM |
| Muffler delete on track (melted bumper?) | celica73 | Tracking / Autocross / HPDE / Drifting | 12 | 04-01-2014 05:27 PM |
| Thrust Bearing Going Out | >(559)< FR-s | Issues | Warranty | Recalls / TSB | 22 | 06-19-2013 09:23 PM |
| bearing identification | paraguin | Other Vehicles & General Automotive Discussions | 7 | 04-16-2013 11:18 AM |
| Blown wheel bearing =( | silverbullet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 01-23-2013 11:34 PM |
