| Software Tuning Discuss all software tuning topics. |
#15 |
Drives: 2014 WRB BRZ Limited
So, if I understand this right, you're trying to implement a system that uses both MAF readings and vehicle speed to improve afr accuracy?
#16 | |
Drives: Toyota 86
Speed density uses engine speed and manifold pressure to calculate (after compensating for temperature and volumetric efficiency) the mass of air flowing into an engine. The amount of air mass flowing in to the engine determines load (grams of air/rev) and thus everything that uses load as an input (fuelling, timing, AVCS, everything). At the top end of the MAF scale, resolution gets poor and under forced induction conditions, can easily exceed the maximum figure (MAF sensor capped) - this leads to the ECU thinking that a certain amount of air is going in but really much more air is going into the engine => leans out under high load/RPM (bad). Speed density gets rid of the resolution problem up high as well as the problem of having a capped MAF sensor. |
#17 | |
Drives: Whiteout FR-S, Evo 8 RS
#18 | |
Drives: Toyota 86
For B01C (are you using a stock ROM, or an OFT 2.xx ROM?), can you log the following to see if the addresses are clean? Code:
paramname = MAF_Sensor paramid = 0xFFF8D410 isfloat = 1 paramname = MAF_SD_Raw paramid = 0xFFF8D414 isfloat = 1 paramname = MAF_SD paramid = 0xFFF8D418 isfloat = 1 paramname = MAF_Final paramid = 0xFFF8D41C isfloat = 1 |
#19 | |
#20 |
Drives: FT86
#21 | |
Drives: Toyota 86
Last memory address referenced in A01G is FFF8D304 and in B01C is FFF8DC50. Can you try logging FFF8DC80 and up in steps of 4? I suspect they will be clean. |
#22 | |
FFF8DC80 FFF8DC84 FFF8DC88 FFF8DC8C FFF8DC90 FFF8DC94 FFF8DC98 FFF8DC9C FFF8DCA0 FFF8DCA4 FFF8DCA8 FFF8DCAC All are clear and showing zero's like you said. How far up do you want me to go? Last edited by D-VO; 08-23-2015 at 12:09 AM. Reason: More info |
#23 | |
Drives: Toyota 86
Fuelling: There is an engine load multiplier value in the ROM which is applied to engine load before the pulse widths are calculated for DI and PI systems - I wonder if we could just scale this value according to E% rather than adjusting each fuelling system seperately. Would need to do some testing. Do there need to be different OL tables to interpolate between on the basis of E%? The primary OL fuelling additive gets added in progressively on the basis of IAM, and could be redefined to add on basis of E% Cranking fuelling: There is a ECT/RPM compensation table that is zeroed. That could be used as a ECT/E% compensation table. Timing: Base Timing A does not get used much - there is already code that interpolates between Base Timing A and Base Timing B based on a value (I am led to believe related to AVCS activity). This one would be quite easy to hijack. E% sensor: Where would you wire this into, and how would you deal with the dropped signal for that input? |
#24 |
Drives: Toyota 86 GT
Could be just me but I can't open the zip. Looks like it's corrupt.
"I used a straight RPM/MAP to mass flow conversion table rather than full VE conversion to simplify code." What do I need to do to convert VE to g/s? I'll most likely do it in excel. Another question. Is there anything stopping me running full SD? Ie. maf-less. P.S. love your work. If you haven't seen the Aussie "86 Drivers Club" FB group jump on it. We love tech stuff. |
#25 | |
Drives: Toyota 86
You'll also need the .xml file additions in posts above, or I can send you my .xml (though it has been modified to how I think) and latest ROM including FlexFuel code. You don't need any conversion - the table holds a mass flow value in g/s per RPM/MAP cell that gets input into the ECU instead of the MAF flow and the ECU does the conversion to g/rev - you can run full SD if you want, though there is quite a lot of variation at low load/RPM in the final SD value that I'm not sure would run smooth - probably anywhere above 40-60 g/s flow would run well. If you do go MAFless, let us know how it goes. |
#26 | |
I know I don't need a conversion, it's more that I'd like to do it. Rather than explain what I'm trying to do, here's a picture (numbers are garbage):
![]() This seems like a common formula. VE = (3456 x CFM) / (CID x RPM) Though it doesn't take into account air temp or baro pressure. There's enough info out there (like this), it's just a matter of me finding the time to implement it. Quote:
#27 | |
Drives: Toyota 86 GTS
The amount of harassment people get whenever they mention anything open source on facebook from ignorant Australian online super-heros that blindly follow their tuners and unquestionably swallow all the horse shit said tuners feed them, is astounding. I'd advise anyone in Australia to stay away from facebook groups as much as possible if they want to discuss anything tuning related, I know for a fact this group is one spoiled by these hateful minions. This forum is a much better for tuning discussion where those people get banned and you can reach your audience of one or two people with their heads on straight, instead of facebook where there's thousands of useless fucktards whose sins are constantly removed and forgiven or rewarded due to the overwhelming mob mentality. I suspect ztan knows this full well already though. |
#28 | |
People don't get harassed in the 86 Drivers Club. It's all love and rainbows.
| Open Source Electric Supercharger | neutron256 | Forced Induction | 913 | 08-22-2021 06:16 PM |
| MAF (Mass Air Flow) versus Speed Density, Discussion & Debate for ALL | DeliciousTuning | Software Tuning | 40 | 04-11-2015 01:56 AM |
| Screencast: MAF and Speed Density | jamesm | Software Tuning | 6 | 02-08-2014 04:19 PM |
| Is Speed Density tuning required for under 400HP street driven cars | vgi | Software Tuning | 35 | 12-03-2013 07:29 PM |
| Speed Density Possible? | mrk1 | Engine, Exhaust, Transmission | 3 | 05-01-2013 02:21 AM |
