Old 09-12-2015, 11:24 PM   #15
v12
v12's Avatar
Drives: none =[[
its not auto diagnostic forum here, no one will help much here. only will tell you go to dealership
check voltage when you turn key on crank position
maybe starter fuse blow? for some strange reason
check all the fuse, worth a shot
v12 is offline   Reply With Quote
Old 09-12-2015, 11:28 PM   #16
All sorts will try to help. Very few will succeed. It is the same as saying "I have this noise what is it". A thousand people can throw ideas at it but without being able to see and touch it there is little value in them.
Old 09-12-2015, 11:47 PM   #17
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
It may be a long shot... but I do very much appreciate the suggestions. Next I will try fuses. Any particulars to check? Not sure which fuse is starter... I guess I can just pullemall. But there are quite a few.
2015 FRS Ultramarine.
SkiRideDrive is offline   Reply With Quote
Old 09-13-2015, 12:08 AM   #18
joe strummer
Originally Posted by lupindub View Post
Not true. Even after my battery died - window auto scroll, locks, lights, etc. were gone, the anti-theft light was still blinking. So I essentially had no power in anything except for the anti-theft lights.
What's not true? The OP said that his electrics worked. Perhaps the anti-theft light has a dedicated battery, but with a dead main battery, the lights would not work. If the battery is too low to start the car, but still runs the lights, etc, he would have at least heard the solenoid clicking.
Maybe I don't understand what you're saying, but based on what he wrote, I can't see how getting a jump would help.
Checking the fuse makes the most sense.
joe strummer is offline   Reply With Quote
Old 09-13-2015, 12:14 AM   #19
Beastronix
Beastronix's Avatar
@SkiRideDrive I'll help you out. Definitely a fuse... I'll dig up the proper slot and post a pic shortly. Pretty sure the one you're looking for is going to be a 7.5a and should be spares in the box under the hood.
Beastronix is offline   Reply With Quote
Old 09-13-2015, 12:19 AM   #20
SkiRideDrive
Drives: 2015 FRS
Thank you! I actually just shot you an email. Good timing!
Old 09-13-2015, 12:23 AM   #21
Fuse 1 in engine compartment.
Old 09-13-2015, 12:34 AM   #22
S84kam
S84kam's Avatar
Drives: FBRZS
Originally Posted by jdmblood View Post
I think its totaled dude.
Originally Posted by ihaskrayon View Post
Try cuddling.
c'mon guys. The dude's car isn't working and I'm sure this doesn't help
S84kam is offline   Reply With Quote
Old 09-13-2015, 12:57 AM   #23
SkiRideDrive
Drives: 2015 FRS
This diagram looks quite a bit different than what I am staring at in my 2015 frs.
Old 09-13-2015, 01:02 AM   #24
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Try cuddling.
These kinds of stupid posts aren't funny anymore nor are they conducive to helping anyone in anyway. Way to make everyone on the forum look bad
Old 09-13-2015, 01:47 AM   #25
SkiRideDrive
Drives: 2015 FRS
Beastronix has been in contact with me via email. Very helpful. Have gone through a few fuses and haven't quite found the problem yet. Will continue to diagnose tomorrow. Thanks for the help guys.
Old 09-13-2015, 02:00 AM   #26
I have never looked at it against the real thing it was given a long time ago as the proper one. So I can't vouch that it is.
Old 09-13-2015, 02:02 AM   #27
joe strummer
its not auto diagnostic forum here, no one will help much here. only will tell you go to dealership.
Why the negativity? Someone here might have had the same problem and resolved it, or people might know enough to help diagnose and fix the issue.
Get together smart people, like we have on this forum, and the sky's the limit as to the help they can provide.
Old 09-13-2015, 02:18 AM   #28
steve99
Drives: FT86
"-The alarm (flashing red light with lock) light flashes on dash when I am not trying to start the car. I can't remember if that light flashed did that before this whole snafu, I'd be willing to guess it did not, but can't be sure. "
Generally if the alarm/security light is flashing the alarm/security is still active and the car will not start
We dont have the alarm function in my country just the immobilizer.
if all the dash lights illuminate and headlights work ect but car wont crank and imobilier/security light still flashing then i would concentrate on some issue with security system check the imobiliser/alarm fuses plugs/connections to alarm/imobiliser ect.
also measure the battery volts under load even a dead battery can measure ok unloaded.
as well as checking fuses check the big fusible links under the bonnet.
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 10:57 AM
Where did you start with your FR-S/BRZ jeepmor Scion FR-S / Toyota 86 GT86 General Forum 43 04-10-2014 02:39 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
