Old 07-08-2015, 04:28 PM   #169
jonzhuxD
Drives: Ultramarine FR-S
Originally Posted by Aqrab View Post
guys
from the previews pictures , where is the chime speaker ?
Is it the same speaker as the seatbelt chime? We don't have the overspeed chime in the USDM cars.
jonzhuxD is offline   Reply With Quote
Old 07-13-2015, 03:19 PM   #170
Awstryker
Drives: Scion FR-S 10 Series 6MT
First of all thanks for the great tutorial. I was able successfully swap my led's on my cluster gauges, but when I put everything back together I noticed that my needles don't do the sweeping motion when turning on the car. Any one know how to correct that?
Awstryker is offline   Reply With Quote
Old 07-19-2015, 08:12 PM   #171
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
You have to set the shift light again, only the brz does the sweeping, while the fr-s gauges shows u where u set the shift light on start up
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 09-08-2015, 02:02 PM   #172
Starkey
Drives: 2015 Subaru BRZ Series.Blue
Originally Posted by JHSurf View Post
I left mine red for a few days but it felt like an elephant in the room so I changed it to blue
Does anyone have advice/pictures on taking apart the start button? Two of my friends and I are working on redoing the entire interior of my car and none of us could figure out how to get to the LED in the start button without breaking the assembly. We've all searched the forums and googled to no avail. Any help is appreciated!
Starkey is offline   Reply With Quote
Old 09-08-2015, 06:42 PM   #173
stevesnj
stevesnj's Avatar
I would think that it's made to not come apart for theft protection.
My 2016 Build thread
Old 09-14-2015, 02:59 PM   #174
Kellhound
Drives: 2015 BRZ
Door "window and lock" LED's
does anyone by chance know the type of LED that is used in the door? I was able to get everything changed over to blue but the LED's in the door are different from what is used on the console.
I did try the larger LED's but they did not work (left one original LED installed to verify if I soldered backwards.
Kellhound is offline   Reply With Quote
Old 09-14-2015, 03:10 PM   #175
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
If this is the one you're speaking of its a T10 wedge bulb.
Old 09-14-2015, 03:11 PM   #176
Kellhound
Drives: 2015 BRZ
ROLF quoting myself...
Are these correct? LED
Old 09-14-2015, 03:14 PM   #177
Kellhound
Drives: 2015 BRZ
Na, already replaced that. Im talking about the actual window and lock switch LED's in the door (by the speaker).
Thanks though.
Old 09-16-2015, 01:14 PM   #178
Starkey
According to CJBRZ, the door LEDs are 0805:
Originally Posted by CJBRZ View Post
Just finished this up going to play around with gauge cluster a little more until I get exactly what I want, but for for anyone else who wants to do this, the correct LED sizes on the are as followed:
Dual Climate Control, Clock, Traction Control, Gauge Cluster are PLCC-2
Dim switch and headlight angle switch are 3mm LEDs.
Trunk open button is a single 0603
The doors and radio are 0805
On a different note, were you able to replace the LED in the start button? If you were, how did you get to the LED to replace it? A friend of mine and I could not figure out how to get to it without breaking the assembly. Thank you in advance for your help!
Old 09-17-2015, 10:33 AM   #179
Kellhound
Drives: 2015 BRZ
I did take it apart but was too nervous when I saw it was wired like an electro magnet. I also could not figure out how to remove the white plastic slider without breaking any tabs. Sadly, it's still red.
Old 09-17-2015, 11:01 AM   #180
Kellhound
Drives: 2015 BRZ
3mm round tops? Or the piranha's?
Old 09-27-2015, 10:21 PM   #181
dssence
Drives: Toyota FT/MT 86
Guys does anyone know if the gauge cluster the entire assembly is replaceable. I'm asking this as I have a toyota 86 not GT , its same as scion frs.
I want to buy a spare gauge cluster just in case so I leave my original untouched. some people the gauge cluster it paired with the ECU of the car but I don't think so.
What do you guys think or know about this.
dssence is offline   Reply With Quote
Old 09-28-2015, 10:19 AM   #182
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It IS tied to the ECU and car keys via the immobilizer. The car will not start after cluster swap unless you take it to the dealer and the cluster is programmed to the immobilizer.
Gauge Cluster on FRS tonytduc Scion FR-S / Toyota 86 GT86 General Forum 16 07-24-2017 10:56 PM
BRZ cluster gauge swap? InYOHface Cosmetic Modification (Interior/Exterior/Lighting) 31 03-25-2017 07:31 PM
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 03:54 PM
Gauge cluster mod? kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 8 11-27-2013 11:59 PM
Want to try a gauge cluster experiment with me? stockysnail Northwest 2 04-12-2013 11:57 AM
