Old 09-14-2015, 07:23 PM   #253
CSG Mike
CSG Mike's Avatar
Originally Posted by Elliryx View Post
Do you still get the rumble with Ace EL?
No, you need a UEL header to get a rumble.
Old 09-14-2015, 07:25 PM   #254
kch
Senior Misanthrope
kch's Avatar
I like the rumble but right now I have oem header, I'm now thinking either Jdl uel or Ace EL. Do you need to get special tuning if you get Ace or it will be just fine with OFT?
A (good) custom tune is always better than an off-the-shelf OFT tune. However, you could use the OFT stage2 EL tune with the Ace 4-2-1 and it would probably work just fine.
Old 09-14-2015, 07:56 PM   #255
tracerit
Drives: '13 SSM BRZ Limited 6MT
Without the rumble, how does the Ace sound compared to the stock header? Louder?
tracerit is offline   Reply With Quote
Old 09-14-2015, 08:13 PM   #256
CSG David
CSG David's Avatar
Have you heard of a catless header setup on the BRZ/FRS yet? The basis of this question is kind of resting on that answer, because it's really difficult to describe a qualitative type of response.
Old 09-14-2015, 08:15 PM   #257
Hawk77FT
Drives: GTS 86
OK, quick impressions of the short drive I had last nights after I installed these header.
Super high low end torque, good off the mark start, great mature rasp. Can't say much though as I didn't drive the car for much long, and the OFT tune needed tweaking to extract the max out of the longer runners.
Hawk77FT is offline   Reply With Quote
Old 09-14-2015, 09:43 PM   #258
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
I get super low end torque as well- then mediocre mid range accel - then crazy 5- 7 boost. I'm super happy with my ACE- I wouldn't go as far as to call it a "mature" rasp, personally - - But it definitely sounds racecar! - Now comes the real struggle of finding a good cat back to refine the sound and not accentuate the rattle/rasp.
Im getting a free borla catback so i'll have to let you know how it sounds but thats only temporary- I think what would sound really good is the Lachute from Quebec.
olsonpg is offline   Reply With Quote
Old 09-14-2015, 09:45 PM   #259
JB86'd
JB86'd's Avatar
Drives: JAWS
I would say get the ACE if you are going to get a custom tune to really bring out this header's capabilities (Shiv can do that for you for a fee, if you already have an OFT) and are really concerned about having every bit of power.
If you like the UEL rumble, and are just going to run the OTS map, you could get the JDL and you'll be happy. That's coming from a JDL uel owner who considered the ACE but likes the UEL rumble and just DD/occasional AutoX.
Now if I tracked my car, and money was no object, you bet your ass I'd have this beauty with a custom tune
JB86'd is offline   Reply With Quote
Old 09-14-2015, 10:18 PM   #260
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You can't custom tune a header without putting that header on a dyno. Period.
Old 09-14-2015, 10:39 PM   #261
churchx
churchx's Avatar
Drives: 2014 GT86
Wayno: hence i hope for someone with OFT to buy this header and releasing free tune or all cam/ignition/fueling timings changes needed for better starting point then OTS EL tune, that probably is made for short runners header. Imho it would rise this header value.
Old 09-14-2015, 10:48 PM   #262
JB86'd
JB86'd's Avatar
Drives: JAWS
So in other words, a "remote E-Tune*" can't get you the results you need to bring out this header's capabilities?
Old 09-14-2015, 10:59 PM   #263
Wayno
Wayno's Avatar
Not unless they already have tuned the fuel timing and avcs on a dyno previously. You can throw all the timing you want at it on petrol yourself, don't need a tuner for that.
Hawks car has intake spacers so we'll do the stuff that usually knocks like buggery on 98 for those - use the 91 timing map, remove the per cylinder timing retard, add more kca up top. Then tune out the knock. Then lean it up to 12 instead of 11.5 and see what the knock is like then.
And using some Frankensteined long tube avcs from one of Steve's threads.
The result won't be as good as a dyno tune.
Old 09-14-2015, 11:07 PM   #264
JB86'd
JB86'd's Avatar
Drives: JAWS
Thank you for the explanation @Wayno I'm still learning..can't tell you how much you and Steve have helped all of us.
Old 09-14-2015, 11:37 PM   #265
CSG Mike
CSG Mike's Avatar
You sound like a perfect candidate to purchase an Ace header, pay to get all the tuning done via OFT, and then release it for all the other owners to benefit from your generosity
Old 09-14-2015, 11:39 PM   #266
CSG Mike
CSG Mike's Avatar
The calibration requirements for this header are so different from the other headers on the market that there are no current "off-the-shelf" solutions to extract all the power available.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
