Old 11-23-2015, 09:12 AM   #365
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Originally Posted by ohmai18 View Post
The question many want answered.
This Saturday, VIR Grand Course
Videos & Datalogs to follow.
NotSoJDM is offline   Reply With Quote
Old 11-23-2015, 11:08 AM   #366
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Please try to log Intake Air Temps before and past the intercooler.
Old 11-23-2015, 11:20 AM   #367
NotSoJDM
NotSoJDM's Avatar
With the Edelbrock kit their MAP harness relocates IAT signal to the MAP sensor post heat exchanger, IIRC. Any suggestions on how to log IAT from original MAF sensor with this configuration for pre heat exchanger temps?
Old 11-23-2015, 02:58 PM   #368
Kodename47
Kodename47's Avatar
Drives: UK GT86
You'd have to make a custom harness and use the rear O2 port and custom map it. TBH it's relatively worthless as you can just log ambient temp which will give you a decent enough idea of the pre and post cooler temps.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-23-2015, 03:00 PM   #369
NotSoJDM
NotSoJDM's Avatar
Thanks for the info. That sounds much more attainable I'll make sure I'm logging both.
Old 11-30-2015, 02:35 PM   #370
NotSoJDM
NotSoJDM's Avatar
I've attached a temp graph I put together from one of my afternoon sessions at VIR. Still working through some of the other data. ECUtek did this wonky thing where it split one of my 25min logs into about 40 different files, so I have lots to look through. Ignore the units for the Time axis.
EDIT: Here's the same data formatted from my first session out in the morning.
Old 11-30-2015, 03:38 PM   #371
Kodename47
Kodename47's Avatar
Drives: UK GT86
Never known ECUtek to do that. There's a merge tool in the file menu where you can drag and drop multiple logs to join them up, or in your case restore them
Thanks for the data BTW.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-30-2015, 03:41 PM   #372
Uplink
Uplink's Avatar
Drives: anything you let me
Looks good, thanks for the log! You've got some important cooling upgrades. I wonder if there might be heat concerns with a stock setup on say an 80o average ambient temperature day and/or on a 'gearing challenged' track. ie, in a 6-spd stock setup on NJMP Thunderbolt or Thompson, the car spends a LOT of time in the 6.5-7.2k range because it's just not practical to grab the next gear before braking.
Have you thought about trying a 30wt or 40wt for track days?
Uplink is offline   Reply With Quote
Old 11-30-2015, 03:45 PM   #373
NotSoJDM
NotSoJDM's Avatar
No, I haven't really considered trying a different oil for track days. I have used Mobil 0W-20 since I bought the car new, and had an oil analysis done at 62k to check up on things. Everything looked good, so I have kept with it without much thought going towards changing it up.
Old 11-30-2015, 03:47 PM   #374
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
You have 62K and just put on the supercharger?!? Nice....
Old 11-30-2015, 04:06 PM   #375
NotSoJDM
NotSoJDM's Avatar
Received my car June 2012, put 66k on it prior to boosting (now at 71k), and installed around 10 different forced induction kits locally before I finally pulled the trigger on my own. To be honest, being able to experience the installation woes of a lot of the major kits, helped me wait for 'the one'.
Old 11-30-2015, 04:12 PM   #376
Uplink
Uplink's Avatar
That's good to know @checkup. Not sure how many long term oil tests have been done.
I'm a little OCD with it when I probably don't need to be. All Mobil 1 since 900 on the clock, 20wt in the colder months, 30wt in warmer and 10 oil changes in 15mos/14,500 miles. (One after every track day along with a full Castrol SRF brake flush.) Cheap insurance.
Back on topic, how did the car feel? Pull really well up the hills? Coming out of Oak Tree for the drag race up the back straight is rough in stock trim.
Old 11-30-2015, 04:13 PM   #377
Summerwolf
Panda Trueno
Summerwolf's Avatar
As soon as this kit was shown fully and available I knew it was the right one. I was waiting on the Harrop, but I think this one is cleaner and looks even more thought out if that's possible. I'll be following your build long term for what comes of it!
Old 11-30-2015, 04:29 PM   #378
Uplink
Uplink's Avatar
I've used Edelbrock products for years on my Vettes. Solid products that always perform.
Everything about this kit says it's 'the one'. Quality, performance, price, US made, least amount of 'molestering' to your car to install and a warranty to boot. How could you go wrong?
Now, *checks wallet*, how often can you donate plasma for money?
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
