Old 01-05-2016, 12:22 AM   #1
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
What-if: Converting the car from an Automatic to a Quaife Sequential
For the purposes of this discussion let's discard reason shall we?...
Imagine I have automatic FR-S and want to swap out the existing transmission for a Quaife Sequential Transmission: I know I need...
  • New Sequential Trans
  • New Clutch
  • New or used drive shaft
  • New or used clutch master and slave cylinders
  • New or used brake and clutch pedals
...but what am I forgetting? What don't I know? Will have the ECM have to change? Do I need a different wiring harness other then what's on the car? Has anyone attempted this swap?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 01-05-2016, 12:53 AM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
For what purpose?
Old 01-05-2016, 12:53 AM   #3
Teseo
Drives: frs
My bet is the transmission will cost more than the car itself.
Old 01-05-2016, 01:04 AM   #4
steve99
Drives: FT86
In modern cars a whole heap of control modules talk to each other on the CAN buss (Control Area Network)
The Auto trans has an associated control module TCM, and the ECU talks to this, as well as dash, stability control ABS steering control and much other stuff.
If you remove the auto trans and associated TCM then the current ECU is going to get upset as it can no longer talk to the TCM.
And the manual need to get the clutch switch input to start car and other stuff.
you may be able to flash the equlivant manual rom into the auto ECU eg a ZA1JB01C rom instead of the ZA1JB01D rom.
BUT their may actually be hardware changes in ECU or in wiring and the DASH VSC ABS or any other control module may need updates as well to be able to talk to manual software in ECU.
you cannot just swap in another ECU as the eCU/DASH/imobilier module are part of a security set and either need to be swapped in togeather with a key fob or re-coded by dealer (or maybe locksmith)
My guess would be it would be a very expensive and frustrating excersise to swap auto to manual. without even considering the physical fitment issues of the new transmission.
Be far easier to use a manual car for the swap.
Unless you can find a guru who knows 100% what you need to change
Old 01-05-2016, 01:55 AM   #5
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
No one do that , go for buying MT
Toyota86.ir is offline   Reply With Quote
Old 01-05-2016, 02:08 AM   #6
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
I'm sure there'd be ECU concerns. In other words, this would be a PITA/money pit.
Are you looking at like old school transmission type of shifting?
May work if you swap engine+transmission, but I still dont see it on a FA20 due to ECU IMO.
Old 01-05-2016, 03:35 AM   #7
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
I'll probably do that one day, should cost around 10k€.
That's an entry level gearbox. good ones should cost twice that.
I would put it in a MT car.
Anyway, for street use, that's a bad idea :p
MaximeT is offline   Reply With Quote
Old 01-05-2016, 05:17 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Pity these guys don't make yet one for our cars. At listed prices would be more then happy to buy conversion kit.
Old 01-05-2016, 08:20 AM   #9
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Just trade it for a manual if you can afford the loss. If its a few years old and in good shape you may not incurr loss at all. Most want autos so you could be in good shape
RichardsFRS is offline   Reply With Quote
Old 01-05-2016, 08:46 AM   #10
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Just get a stand alone ECU.
Lunatic is offline   Reply With Quote
Old 01-05-2016, 09:06 AM   #11
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
If you got the car for a deal simply as a platform and you're going crazy with it you'd likely want a stand alone and a different FD. I'm pretty sure you can get quaife to make you whatever gear ratios you want but you'd save some money going with an off the shelf box and changing your FD to match.
Gear_One_Performance is offline   Reply With Quote
Old 01-05-2016, 09:08 AM   #12
MaximeT
MaximeT's Avatar
They offer different gear sets.
Edit: I mean not custom, but different base configurations.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
Old 01-05-2016, 10:23 AM   #13
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
You'll also need a cam plate to block off the hole after you remove the vacuum pump from the passenger side cylinder head.
You will need some interior pieces for when you remove the flappy paddles from the wheel.
Oh, and the MT version of the brake booster vacuum hoses, because theyre different too. and the clutch slave cylinder and line, because they bolt to the engine and will not come with the transmission. Well, they bolt to the top of the transmission bellhousing, but whatever.
And a flywheel and pilot bearing.
And a bunch of other parts that you didn't mention and I didn't bother to remember or look up.
If you can afford a quaife sequential box, you can afford to do it right and start with an MT car.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 01-05-2016, 10:36 AM   #14
Well if you're building a race car from scratch it doesn't matter that much what you start with in this case. But that's only if you're going crazy from scratch, and he did say to throw reason out the window.
Quaife LSD For BRZ/FRS in stock at Redline360! Redline360 Transmission and Driveline 24 11-28-2014 01:56 PM
New Quaife ATB Differential For BRZ / FRS Rev Works Transmission and Driveline 2 04-24-2014 05:46 PM
Anyone developing a Sequential gear box? diss7 Engine, Exhaust, Transmission 21 01-03-2014 03:36 AM
HKS SEQUENTIAL TRANSMISSION for the 86 ESBjiujitsu Engine, Exhaust, Transmission 20 10-30-2012 06:28 AM
Toyota's Automatic sequential shift davey90 Engine, Exhaust, Transmission 11 12-23-2011 01:18 AM
