Old 02-29-2016, 01:24 PM   #869
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
I posted this in the FB group, but I'll put it here as well. I went to the track over the weekend, and managed to get some more temp data. I overlayed the data from this weekend (on e85) with the data I took in November (on 93). Ambient temps were similar (around 65). The only difference aside from fuel type was the removal of the factory snorkel this go around.
Since the data is colored to differentiate fuel type, I'll go ahead and tell you IAT is the bottom curve, Coolant Temp is the middle curve, and Oil Temp is the top curve.
NotSoJDM is offline   Reply With Quote
Old 02-29-2016, 02:29 PM   #870
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Very interesting. You always hear about how E85 "runs cooler" but it's nice to have the data to match.
Old 02-29-2016, 09:16 PM   #871
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
I can't explain how much faster the car is now ... i took 262 km/h (163mph) (german highway) in 5 gear and i had enough power to accelerate more in 6 gear but i have winter tires on it and i won't go faster. I will try it with my summer tires in a month or less i think ! Maybe i will it the 300km/h (190mph) =P For the 0 to 60 mph time 5.2 seconds with my AT.
Specs of the car :
Stock header
Stock OP
Stock FP
Agency power cat back
Edelbrock supercharger kit
Delicious tuning special 98ron octane gas tune.
The way the car work is just perfect for me, torque dip is gone, power come real fast and holy s**t THAT POWER !
It really kick me back in the seat, great torque and power everywhere, revs in neutral are impressive, engine is just like i want it to be !
no trouble with the kit or tune. No bucking or everything else, no dead pedal feeling. I enjoy this kit so mutch !
Smooth operation of the supercharger, no lag, you want power and torque he's there for you anytime !
Sound is cool, on board i hear a little whistling sound like à turbo, outside we can hear the twin screew sound.
I install it myself, so i can say, edelbrock you've done a great job, your kit is perfect, and thank's to delicious tuning for the great tune !
EDIT : DYNO DAY 3 MARCH !
Paulo86 is offline   Reply With Quote
Old 03-01-2016, 11:12 PM   #872
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Well it's been quite a struggle with my new Edelbrock supercharger. 5 weeks to be exact. Mostly idle problems, or just off idle. Tonight a found a line going to one of my radium catch cans that had come apart under the supercharger. Made a big difference once it was fixed. Still have some idle issues to iron out but anything above 1500 rpm LOOK OUT. Tonights test run on e-85.
Lunatic is offline   Reply With Quote
Old 03-02-2016, 12:08 AM   #873
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
You have me worried... I am just about to pull the trigger on this kit, but all these issues, even though minor, should not be happening. Is there a bad batch, as has been previously suggested?
Sent from my XT1031 using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 03-02-2016, 12:30 AM   #874
NahumCC
Drives: 2013 FR-S 10 Series
Originally Posted by clayrush View Post
I'll upload the dyno graph when I get home
But it made 295hp, from 187. And 213 Tq from 146.
Both numbers were on e85. Full catless exaust and Borla uel header.
The car is having some stalling issues when it comes to a stop. They are going to look into it next weekend.
I am going up after work to pick her up.
Originally Posted by Uplink View Post
Lightweight setups like a SPEC clutch/fw combo can cause decel stalling on these cars? Is it more prevalent in SC applications?
Light flywheels have a tendency to do that, especially if you have a super light one.
Concur with what Mike has said. I ran a SPEC lightweight flywheel on my SAAB and it took about a week and a half for the auto adapt feature of the Trionic 5 ECU to fully adjust to the lightweight flywheel under decel to stop, a/c kicking in at a stop, etc. to where it wouldn't bog down or possibly stall. Not sure how long the Toyota ECU's take to adapt but hopefully the nuisance will self heal itself or modify the tune with the tuner.
NahumCC is offline   Reply With Quote
Old 03-02-2016, 12:37 AM   #875
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
I wouldn't worry too much. Most of the issues have been installation related, not kit quality.
The Racers Line is offline   Reply With Quote
Old 03-02-2016, 12:45 AM   #876
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
Originally Posted by The Racers Line View Post
I wouldn't worry too much. Most, of the issues have been installation related, not kit quality.
This.
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
MicheleAbbate is offline   Reply With Quote
Old 03-02-2016, 02:20 AM   #877
BigFatFlip
BigFatFlip's Avatar
Sorry to hear that Lunatic, I know we've been all impressed during the factory tour and have been won over by what it can do (the Korean BBQ with you and Neal was also a treat). Just to be clear, the idle problem was in both 91 and E85, correct? Not one or the other?
Very impressive numbers none the less. Hope you get things squared away soon. Are you running an after market clutch also?
Old 03-02-2016, 09:43 AM   #878
Lunatic
Lunatic's Avatar
The problem was with both 91 and e-85. RPM at stops would drop so low engine would die. I have the automatic so I couldn't just step on the clutch. The problem was a line going to one of my Radium catch cans had not been installed properly and had come apart under the supercharger. This was sucking air. we couldn't see this and didn't discover it until we started pulling on lines. Once fixed the idly smoothed out. Still need some tuning tweaks which Delicious Tuning is working on. Still getting a P0068 check engine light/fault code, and I have lost the rev match for down shifts which still has to be sorted out, but yes I am happy with the performance.
Old 03-02-2016, 02:46 PM   #879
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Keep checking the lines to the catch cans and back to the engine. On the rare occasion, the lines tend to pop off slightly under boost and cause it to leak just enough to trigger that CEL code, which is historically known to trigger for boosted setups when there's a small leak in the EVAP line or one of the lines from the catch cans.
CounterSpace Garage is offline   Reply With Quote
Old 03-02-2016, 04:03 PM   #880
Lunatic
Lunatic's Avatar
Will do, we also put clamps on all connections where no clamps were.
Old 03-02-2016, 04:05 PM   #881
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
To be clear, this vehicle is still leaking air. The P0068 is a symptom of this leak, and the rev matching is gone because the code is being thrown. Rev matching will not be operational when the vehicle has this code active in the system. Logs indicate much higher pressure at idle than normal (less vacuum), coupled with wildly positive fuel trims, which indicate a leak is still present.
Also of note is that logs were reviewed thoroughly before the car left CSG after installation. Vacuum was proper as were trims, and the car was running quite well. It was not until the drive home that these symptoms started occurring, which would suggest that the leak occurred after the car left the shop.
Sincerely,
Zach
Old 03-02-2016, 04:08 PM   #882
Lunatic
Lunatic's Avatar
Another problem hopefully solved. I took my car to my local Scion dealer this morning to try and find out why I keep getting a CEL fault code. P0068 MAP/MAF. The technician spent over 3 hours trouble shooting the problem and discovered he could wiggle my MAF sensor, which would send false readings to the ECU. The way he explained it is the MAF sensor could not be properly seated in Edelbrock's intake pipe because the clamp cam on the hose clamp was at 12 o'clock and was interfering with the seating of the sensor. Even though the two screws were tight the sensor was lose and he would get all sorts of false signals when he wiggled it. He repositioned the clamp to the 9 o'clock position and was able to seat the sensor properly. I don't know if this is a design flaw or a installation mistake but something I wanted to pass along to all so they won't have to go through what I have been through.
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
