Old 03-07-2016, 07:00 PM   #15
Thatguyjeremy
Drives: 13' Asphalt FRS
@steve99 I'm assuming the same goes for the normal non big maf Perrin intake? That it would be close enough to stock to not scale?
IG: __thatguyjeremy
Thatguyjeremy is offline   Reply With Quote
Old 03-07-2016, 07:07 PM   #16
steve99
Drives: FT86
The 2.5" perrin is close enough to stock not to cause big issues or damage but would benefit from maf scaling
their is a link to a perrin 2.5" scale in @Wayno s posts in dialling in your tune it better than perrin supplied scaling
Old 03-08-2016, 11:51 PM   #17
Dru670
Drives: 2016 Scion FR-S
can see it here, ignition timing goes to zero and it goes lean is the k&n drop in filter oiled, if so some oil may have got on maf, try cleaning maf with maf cleaner
best to eliminate any mechanical issues or air leaks ect before looking at tune
http://www.datazap.me/u/dru670/log-1...rk=59-58-61-57
I just cleaned the maf with maf cleaner and that didn't work. I just read from a different post the following....
"Got the car back, nothing the dealership can do right now to fix it until Toyota has a fix. According to the data log, my car stalled because it was using port injection as I tried to accelerate. The tech thinks it's ecu software related and that there is definitely a problem."
Wonder if that's my problem.
Dru670 is offline   Reply With Quote
Old 03-09-2016, 12:55 AM   #18
steve99
Drives: FT86
Originally Posted by Dru670 View Post
I just cleaned the mad with mad cleaner and that didn't work. I just read from a different post the following....
load up your original stock tune if it still plays up take it to dealer if its under warantee
Old 03-12-2016, 05:34 PM   #19
Dru670
@steve99 I drove the car for 20 min drive highway and city/stop and go driving
http://www.datazap.me/u/dru670/20-mi...e?log=0&data=1
2nd gear bog
http://www.datazap.me/u/dru670/2nd-g...g?log=0&data=1
Sorry for bothering but if you have time to take a look at them. I trying to understand the meaning of all this. Learning how to interpret these logs what to look out for and what should be of concern.
Old 03-12-2016, 06:42 PM   #20
steve99
Drives: FT86
2nd gear bog
it the bogging log the afr (measured) is way leaner than commanded afr arround2500 rpm likely causeing bogging issue, Is that stock tune ?
Old 03-12-2016, 10:56 PM   #21
Dru670
It's on stage 2 Uel 91.
Old 03-13-2016, 12:32 AM   #22
steve99
Drives: FT86
fix the load limits as per @Wayno's tune thread links in his signiture
Few Questions for a Noob Falltima Cosmetic Modification (Interior/Exterior/Lighting) 0 03-02-2015 11:47 PM
Car noob questions Aenv BRZ First-Gen (2012+) — General Topics 14 12-17-2014 05:42 PM
noob questions theflathead Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-13-2014 09:57 AM
Noob Questions.. Jrryjms07 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-26-2014 11:29 AM
Noob Questions travace Scion FR-S / Toyota 86 GT86 General Forum 28 11-05-2012 12:37 AM
