Old 03-16-2016, 09:42 PM   #1
Nah
Drives: 2013 Scion Frs 6mt
OFT KC learned
what is it? lol at WOT im hitting 2 goes up to 5 then back down to 0 at higher rpms. Thanks
Nah is offline   Reply With Quote
Old 03-16-2016, 10:02 PM   #2
steve99
Drives: FT86
have a read of the ecu logging link below :-)
it the knock correction timing avaliable to the ecu at a given rpm\load, its not knock
Old 03-16-2016, 11:42 PM   #3
Nah
Awesome bookmarked all those links... Lol. I'm actually messing around with timing and vvt angles.
if you don't mind, I'd like to pick your brain for a minute
My mods are a JDL UEL header, Perrin 2.5 CB
I'm using shivs oft base map stg 2 w/ his adjustments to vvt exhaust angle to accommodate the JDL UEL header.
LTFT at WOT are .78, I do not think I should mess with MAF scaling and commanded A/F is pretty damn close to actual AFR at WOT right now.
I am trying to create a full out race tune for the most throttle response, power, all while maintaining safety of course.
I understand the basics to logging and tuning. I can get around rom raider just fine, but I'm looking for a straight forward answer here.
My question to you Steve99, what table(s) should I start looking at to extract more throttle response, power, driveability, and of course more fun to the fa20 to give it a more race car like feel to it?
Thank you.
Old 03-17-2016, 01:52 AM   #4
steve99
Drives: FT86
Thank you.
id suggest you read @Wayno 's threads on dialling in your tune so it runs as close as possible to how tuner intended.
http://www.ft86club.com/forums/showthread.php?t=83945
http://www.ft86club.com/forums/showthread.php?t=94822
its possible to mess with the drive by wire throttle tables but your not creating HP your just making it feel fast by making small throttle pedal movements create bigger throttle plate angle changes. This can have drivability effects.
I have not changed any DBW tables so cannot really offer any more insight
the tune tweaks link http://www.ft86club.com/forums/showthread.php?t=74754
Just learned about European delivery dalli Other Vehicles & General Automotive Discussions 9 10-26-2015 06:21 PM
Everything I know, I learned from the internet. Chillswitch Cosmetic Modification (Interior/Exterior/Lighting) 17 01-09-2015 03:31 PM
KC learned, what does it mean? wparsons Software Tuning 4 08-16-2014 12:37 AM
New thing I learned about this car.. Lord-Hydro Engine, Exhaust, Transmission 33 07-22-2014 04:52 PM
Today I learned (TIL) IloveBaldEagles Off-Topic Lounge [WARNING: NO POLITICS] 5 03-16-2013 09:15 PM
