#3291 |
Drives: frs
I changed my engine oil today. I have the JR oil cooler. I sure wish there was a valve or some way to use air to empty the oil cooler of at least most of the trapped oil. It feels so wrong to leave that much dirty oil in the system. Rant over.
#3292 |
Drives: 2014 Scion FR-S|Whiteout
I sure miss my FRS 😞
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
#3293 |
Drives: 2015 BRZ, 2005 STI, 2024 Type R
#3294 |
Sure is!!! Looks like he's doing a good job taking care of Jenny
#3295 |
#3296 |
Drives: 2013 satin white brz limited
Been tempted to get this. Been on and over the fence and back over and down on what to do either turbo or supercharger. Think I have rested on the supercharger side. Will be a year out but think thats my plan.
#3297 | |
Drives: 2014 Monogram FR-S Whiteout
To help solidify your decision a little, stock rods do not like low end torque so I think on a stock bottom end going SC will be better for the long haul reliability test. |
#3298 |
Drives: 14 BSP Edelbrock BRZ
Why low end torque? A force is a force no matter how often you apply it. If the stock rods are bending from torque it is the maximum torque created doing the bending, not where in the cycle it occurs.
Sent from my Nexus 6 using Tapatalk |
#3299 | |
I am no tuner nor an engineer. Cosworth had a good explanation on this subject and you could probably for it.But here is how I understood it (disclaimer, this is not what they said but just one aspect that clicked for me that I could easily be wrong about): The faster rotation of the crank helps alleviate some of that stress on the rod. You make a certain amount of power in a certain amount of time (the fuel combusting) and at a higher rpm that torque is spread out over many more degrees of rotation of the crank rather than the crank pushing back on the rod because it is moving much more slowly but the combustion is still occurring and putting just as much pressure on the crank for it to not move as much as it would at a higher rpm. So all that pressure has to go somewhere: the rod. If I am completely wrong Mike will quickly swoop down and smite my idea and I'll love him even more than I do now for it because like everyone else, I am here to learn. |
#3300 |
So you're saying it is the instantaneous force on the rod, at higher rpm that force is spread out over a longer interval. Gotcha.
#3301 |
Drives: 2015 AOZORA EDITION
how much power can the c38 make on pump gas 93 with full bolt ons. i got the hks v3 kit and really decideing if i should sell it and go JR route
#3302 |
Depends on your bolt-ons and tuner, but you can imagine what it would do with an Ace header and good tune, if we are at 400whp on a C30 + ace + E85.
#3303 |
#3304 |
Drives: WRB Limited BRZ
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 05:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 05:14 PM |
