Old 05-31-2016, 03:32 PM   #1
Amillionoh7
Amillionoh7's Avatar
Drives: 13' Raven FRS n 92 Camaro
Got Sidewiped time to go widebody?
Car got side swiped other day. just got insurance check for $2k should i repair back to stock or go wide body kit? damage would be covered up by the kit
Amillionoh7 is offline   Reply With Quote
Old 05-31-2016, 03:36 PM   #2
Amillionoh7
Old 05-31-2016, 03:45 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Bondo vs fender cutting and rivets. hmmmmm
Sounds like you just want an excuse to get a widebody.
Just fix your car it don't look bad from the high res photos you posted
Old 05-31-2016, 03:57 PM   #4
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
$2k doesn't even cover half the cost of going RB
Old 05-31-2016, 04:09 PM   #5
jasonojordan
Drives: 2013 satin white brz limited
Personally I think wide-body looks dumb as hell but to each our own.
jasonojordan is offline   Reply With Quote
Old 05-31-2016, 04:32 PM   #6
Amillionoh7
the only noticeable thing is the front fender.
the dent on rear quarter will drive me nuts even though no body else notices it.
so if i keep it stock the entire rear quarter has to be replaced "entire side of the car" and i refuse to use bondo = garbage. so the car will be at body shop for a couple weeks.
but if i do a widebody i can send it for paint and keep driving it. I will pay out of pocket to cover rest of cost on RB kit.
I will add a 3rd option of just replace front fender get it painted bout $500ish + buy a buffer 250ish and spend rest on some coilovers
Old 05-31-2016, 05:04 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
In addition to WB kit you probably will need extra spending on different offset wheels aswell.
Old 05-31-2016, 05:25 PM   #8
jasonojordan
You will end up spending that $2000 just on wheels and tires so that the RB kit does not look even more silly then they already do.
Old 05-31-2016, 05:53 PM   #9
mixtape
Posts in the nude
mixtape's Avatar
Drives: 2016 WRB BRZ
Wheels/tires, likely spacers, adjustable coilovers, lower control arms, camber bolts, fenders (plus paint, plus mounting or molding), the rest of the kit (bumpers, side skirts, etc.)...
That will definitely be more than some basic dent removal and body repair, which seem to be all you need based on the above photos. Of course, I am assuming that you have none of the above-mentioned mods already done to your car but I am going purely based on the photo you posted.
2016 Subaru BRZ - World Rally Blue [Build Thread]
Instagram: @mixtography | My Automotive Photography
"Lesbian trees have no wood." - Scoobs McGee
mixtape is offline   Reply With Quote
Old 05-31-2016, 06:18 PM   #10
Amillionoh7
already got money aside for rims and tires regardless of what option i choose. so does not matter.
and only reason i have not done rb before is because i did not want to trash perfectly good fenders. but now that they are both jacked im ok with it.
Old 05-31-2016, 06:21 PM   #11
Amillionoh7
i sold my camaro other day for 4k so that money is for rims and exhaust and a tune
Old 05-31-2016, 06:24 PM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
So why ask if you're okay with it now?
Unless you want our approval, if that is the case please send a $110 processing fee to everyone who replied in this thread. Add $80 for expedited handling.
-alex
Old 05-31-2016, 06:44 PM   #13
unlimited86
Drives: s2000
Exactly, some people don't realize its an easy over $10k project for a proper RB kit.
unlimited86 is offline   Reply With Quote
Old 05-31-2016, 06:58 PM   #14
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Also an opinion but Agree with this. The only reason why I don't like wide body because all that looks unnatural. And a bunch of bolt/pins around your whole fender looks cheap .. not cheap financially either. If the OEM fenders were made wide body ,w00t that's something to go for but Like @jasonojordan said to each their own
turtlefeeder is offline   Reply With Quote
Greddy widebody v1 help!! Celigts Cosmetic Modification (Interior/Exterior/Lighting) 3 03-07-2015 03:55 AM
Tax return time = WHEEL CLEARANCE TIME from Gram Lights and Yokohama vividracing Wheels and Tires 4 04-04-2014 03:46 PM
86-R Widebody Kit C130NAV Cosmetic Modification (Interior/Exterior/Lighting) 18 12-10-2013 10:34 PM
Looking for a widebody kit djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 8 06-28-2013 02:25 PM
