Old 04-30-2016, 03:03 PM   #1765
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by gdrider77 View Post
Im running essentially a stage 3ish on stock internals? with e85, around 400whp. Been running this for years and everything is still fine. Did wreck a tranny, so had to replace that, but other than that, everything been fine. Of course, I did upgrade all the other parts fuel, clutch, etc. when i did the initial turbo. This is my second cluthc, as my first one was an exedy stage 1, and it worked well for a while, but began slipping at higher powerlevels, now running an act 6puck
I garage this all winter, and really only drive on nice days, and the occasional track day, not a lot of miles, maybe 3000 miles a year, so not like i have been running it a lot, but always seems to run well when i do take the car out. but yeah, even with light use, my transmission went to hell.
This dude's my hero. He makes my turbo anxiety go away lol
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 04-30-2016, 06:31 PM   #1766
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
The biggest thing I will stress.....tune. A proper tune is key and will ensure long life vs grenaded engine. So get a good tune and should be no worries. Took me over a year to get the right tune and spent close to $2000 just to get there. Of course this was almost 3 years ago, so not many tuners around at all. Now there are many more options.
gdrider77 is offline   Reply With Quote
Old 05-13-2016, 12:20 PM   #1767
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Truth! I went through a few visconti tunes NA, two tunes from AVO and now run a delicious flash and go tune, which is working great.
Old 06-01-2016, 06:17 PM   #1768
Astroboy
Astroboy's Avatar
Drives: None
Just thought I'd share my AVO rev here if anybody cares ☺
Old 06-01-2016, 10:11 PM   #1769
kbogarto
Drives: 2013 BRZ limited WRB
What exhaust are you running?
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 06-01-2016, 10:19 PM   #1770
Astroboy
Astroboy's Avatar
Drives: None
SRT. Swift Racing Technologies. Idk if they still sell tho. Even w/o the turbo it sounded smooth
Old 06-02-2016, 12:01 PM   #1771
Dammod
Dammod's Avatar
Drives: .
Hey everyone,
Just though I would share a graph of a AVO kit I installed and helped tune for someone recently:
*Stock car does around 125kw+- and 190nm at that dyno.
Low boost = pump
High Boost = pump + octane booster.
Our pump fuel is equivalent (worse actually ) to California 91.
There is a good 20kw still to be had at the same boost level but the 5PSI actuator isn't holding boost at higher RPM's on high boost and there is still some room for it to be leaned out - having said that, its probably a decent amount of torque already for the stock rods to handle, but I guess we could always play with how we ramp it up - the owner however is SUPER happy with the current power levels...for now.
The car is VERY quick on the street with all the torque where you need it. Really going to miss not driving this one!
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
Old 06-04-2016, 04:15 AM   #1772
tonytduc
tonytduc's Avatar
Can someone tell me how or a picture of how to install the heat shield? I have this long bolt with spacer that I do not know where it go. Anybody with an aftermarket over pipe having problem of it hitting the sub frame? Thanks
tonytduc is offline   Reply With Quote
Old 06-06-2016, 01:56 AM   #1773
Astroboy
Astroboy's Avatar
Drives: None
What are everybody else's thoughts on the AVO customer service?
Old 06-06-2016, 01:14 PM   #1774
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I'm guessing you're having problems getting replies from Paul @ AVO
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 06-06-2016, 01:16 PM   #1775
Astroboy
Astroboy's Avatar
Drives: None
No, I just remember how when I was first installing my kit, I needed replacement parts and was willing to pay but never got responses. No disrespect to AVO, just wanting to hear other people's experience with their customer support
Old 06-09-2016, 02:37 AM   #1776
JD86
Drives: 2013 Toyota 86 GT
Probably not helpful given that I'm in the same country as AVO's head office... But their customer service has been nothing short of amazing for me.
JD86 is offline   Reply With Quote
Old 06-09-2016, 10:35 AM   #1777
Astroboy
Astroboy's Avatar
Drives: None
I have another question. Does anybody else's car feel like it's stuttering a little while going wot? Could it be turbo lag or fuel cut?
Old 06-10-2016, 02:24 AM   #1778
JD86
Personal advice... Don't ask people over the internet "my car feels like this... What's wrong?" Take your car to a mechanic/workshop that you trust. If you don't have one, find one. Things go wrong with modified cars and internet mechanics can lead you down the garden path and cost you money you need not have spent. If you can't find a mechanic at the very least find someone near you knowledgable about cars that you can ring up and take for a spin in your car.
It could be a multitude of things and you haven't given us enough background... You've had your turbo on for years, has it always felt like this or is it a recent thing that's developed? Besides the kit what have you done (injectors, fuel pump, spark plugs etc)? Has it been tuned properly for what you've done or have you been using flash tunes? Have you regularly serviced your car, is it due for a service? How's your clutch? How much boost are you running? Has there been any fault lights or problems other than "stuttering?" Have you logged the problem and sent it to your tuner/have you spoken to your tuner about it? When you say stuttering do you mean it's just slow to accelerate or does the engine drop revs/make funny noises? Is it as simple as your tires breaking traction when you plant your foot?
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
