Old 06-06-2016, 02:48 PM   #295
philooo
Drives: 13' Scion FRS Track car
very interesting point, I can recall going through the same steps on my car for mounting the fuse box and power steering computer, also the cable to open hood and gas door. Your setup is very clean as always.
I am still open for a full diagram of the kill switch
I see that you have an additional red wire in there ? I assume going straight to the alternator. But i see on the left side of the battery the OEM positive terminal, what's up with that one ?
philooo is offline   Reply With Quote
Old 06-06-2016, 03:00 PM   #296
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
One side is the battery and alternator, the other side is the fuse box and starter. Can't just give you a wiring diagram, that'd be too easy.
GSpeed is offline   Reply With Quote
Old 06-09-2016, 09:53 AM   #297
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Sometimes having a 3D printer in the shop helps you find some pretty unique solutions.
Since we've removed the AC, we don't need the thermostat and blend knobs. We're keeping the heater core and fan for defrost, though, so we needed a new place to put the fan speed knob. We also wanted to move the Coolshirt pump switch and @Beastronix 86Nanny to a better location since the lower console is gone.
Any guesses what the big rectangular hole is?
Old 06-09-2016, 10:55 AM   #298
N234
N234's Avatar
Drives:
Iphone dock
Sent from my Nexus 4 using Tapatalk
N234 is offline   Reply With Quote
Old 06-09-2016, 01:48 PM   #299
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
This is a freaking genius idea! I need to go to local Library & 3D print some stuff!
As for the hole, to put this thing lol
Old 06-17-2016, 06:01 AM   #300
philooo
As usual impressive skill set !
As for the hole, looks like iPhone size but I would be surprised as to what would be its purpose... may be to use as a display for something, but considering OBD is already tapped by the AIM system... I am curious
Old 06-24-2016, 10:58 AM   #301
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Fire system is installed! We went with a 10lb SPA Extreme system, which uses Novec 1320. Think Halon, but safer.
We put the handle in place of the left-most AC vent, so it's easily reached by both the driver and a cornerworker outside the car.
We mounted the bottle at the base of the passenger seat, with one nozzle below the dash pointed at the driver.
Then there's two nozzles in the engine bay, one pointed at each cylinder head, roughly.
The two final nozzles are mounted to the chassis itself, aimed at both sides of the fuel tank.
You can also kind of see our new seat mounting base we're about to release. The first pair looked good, but we want to make a few small changes. We'll make a new thread for them, and post a link here when it's up.
Also, no one's correctly guessed what the rectangular hole in the dash is for yet.
Old 06-24-2016, 11:22 AM   #302
philooo
nice and clean as usual guys, very nice !
for the dash space, I would say the only think you are missing in a CoolSuit Control unit
Old 06-24-2016, 12:58 PM   #303
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Oh yeah, and the VAC billet seat mounts didn't work at all. Didn't bolt to the car, and we weren't happy at all with how the secured to the front mount, considering the angle between them. We're returning them.
Old 06-24-2016, 03:23 PM   #304
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Here's a link to our seat mounts we're running:
http://www.ft86club.com/forums/showthread.php?p=2688336
Old 06-27-2016, 10:27 AM   #305
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Prototype seat mount installed! We also added a harness mounting bolt to the transmission tunnel, with a reinforcement plate on the backside. Any harness installation in these cars should be done this way, attaching to the seat mount just isn't safe.
Old 06-27-2016, 04:12 PM   #306
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Since nobody got it right, here's a picture. Center net! You can also see the Coolshirt switch and Beastronix Dash Nanny button.
Old 06-27-2016, 06:55 PM   #307
derek1ee
Drives: BRZ/FRS/STI/M3
Are those anti-sub mounting point 20 degrees back? Looks like they are more like 0 degree. Also those plates are tiny- do you have more reinforcement on the other side?
derek1ee is offline   Reply With Quote
Old 06-28-2016, 10:03 AM   #308
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Not sure what you mean by the angle. This is a rear profile view, but it sounds like you're talking about the side profile view, in which case, yes, they're offset to the rear enough.
The plates are 2" x 3" and welded to the chassis. That's a total of 12 in² between the two of them, and the minimum size for a roll cage landing plate is 9 in² per NASA 15.6.14, for comparison's sake.
More reinforcement on the other side wouldn't help when they're fully welded to the chassis already. The shear area is already maximized. If you look at the total perimeter area of the reinforcement plates (≈20"), and the shear strength of mild steel (UTS*0.577), you'll see they'll have no problem holding in the weight of a driver, even at absolutely brutal deceleration rates.
North East Track/AX - what did you sign up for? dp1 NY / NJ / CT / PA 42 10-18-2016 12:51 AM
Ohio Track Day - Nelson's Ledges 2015 mcquarrieg Great Lakes 24 08-04-2015 04:43 PM
Bar & Track - 2015 Subaru WRX Review FT-86 SpeedFactory FR-S / BRZ vs.... 71 05-26-2014 01:08 AM
