Old 02-06-2015, 06:05 PM   #43
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by YouShallKnow View Post
Nevermind! I just sacked up and bought the damn thing. I didn't buy any kind of terminal adapter so I just kind of wedged the stock connectors on and zip tied them closed.
Works fine, cranks to start easy, and seems 15 pounds lighter.
I ended up getting a Lawn & Garden from walmart with 275 cca, cost $30 plus $12 core charge. I'll run it until it fails then get my Shorai!
Good to see it worked for you. I swear by them on my RallyX cars.
Old 02-07-2015, 06:22 AM   #44
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Originally Posted by quark View Post
Hi Stevo 12v
Where did you get the dome Leds's from? Jaycar?
How does the dimming go as the delay times out?
Hi,
I got them from Kenneth on this forum, KI_ZN6 is his handle I think.
Update:
Battery is running fine after over 2+ years. Car HAS to be started on the 3rd day of not using it, otherwise it will run flat. No problem if you connect it up to a trickle charger though.
stevo_12v is offline   Reply With Quote
Old 02-17-2015, 12:57 PM   #45
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Stock battery died in the cold. So I am thinking about the Lawn and Garden or a Miata battery.
Old 05-29-2015, 12:57 AM   #46
simonweisberg
Drives: 2013 Subaru BRZ
If you are going to be running larger speakers, a sub and led lighting, what is the best battery to upgrade to? (Not in terms of weight but in terms of power, ie not dimming the headlights while turning on the radio) Thanks!
simonweisberg is offline   Reply With Quote
Old 06-20-2016, 01:13 PM   #47
zoomzoomers
zoomzoomers's Avatar
So my stock battery has been giving me trouble now that my car is 4 years old. The stealership wants $160 to replace it. My plan was to buy one from the local auto parts store and just replace it myself, but was told that if I do it it will mess with my electronics. Anyone know what this is all about? It seems like a ploy to force me to buy from the dealer. Any advice?
Old 06-20-2016, 02:13 PM   #48
A battery with the same specs is not going to do a thing to your electronics. Probably one of the easiest repairs that can be done yourself really.
Old 06-20-2016, 02:25 PM   #49
zoomzoomers
That's what I initially thought, but was told something different from a guy at the auto parts store. That's why I asked. So if I buy a comparable battery I won't have any issues replacing it on my own? It won't need with the car's electronics? I'm not concerned about radio station in the memory, but I am worried that it will do something to the other electronic stuff.
So if I'm getting this right, I won't have any issues by buying a battery at the local parts store and doing an exchange in my own right?
Thanks for the information!
Old 06-20-2016, 02:29 PM   #50
Easy as can be.
Get proper battery.
Undo brackets and clamps
Remove old battery
Put new battery in tray
Replace brackets and clamps
Won't lose radio settings but ECU will have to relearn your driving. Not an issue since the solution to half the electronic issues is to unhook the battery for a minute anyway.
Old 06-20-2016, 03:09 PM   #51
Ben_G
Drives: Blue BRZ
Easy as can be.
Get proper battery.
Remove old battery
Some batteries (like the Glass Mat varieties) are shorter than stock and should come with a spacer to bring it up to the right height. Don't throw that out before installation.
Ben_G is offline   Reply With Quote
Old 08-01-2016, 09:28 AM   #52
Baramzisyan
turbo turtle
Baramzisyan's Avatar
Drives: exit GT86 enter STI
Hello! please recommende battery relocation kit for my brz.
i want relocate battery to trunk.
Baramzisyan is offline   Reply With Quote
Old 08-01-2016, 10:13 AM   #53
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
First stupid question: WHY?
That will help give an informed answer.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
Old 08-01-2016, 10:46 AM   #54
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Remedial battery info:
As long as you get a 12v battery, you can use ANY battery and it cannot harm your car. There has to be enough CCA (Cold Cranking Amperage) to start the car, so going too small is useless. It seems obvious but explains why some lawn mower batteries may not work.
Lesser CCA batteries will not last as long as the OEM battery should (all else being equal). Lifefespan of the battery- Smaller (low CCA) batteries will not last as long because they have less reserve capacity and have to work harder to crank the engine. Every crank takes a little out of a battery. Also cranking in the cold can be an issue with lower CCA batteries. Heat kills batteries, cold exposes weak batteries. In hot climates lower CCA batteries will have an even shorter lifespan and heat can mess with AGM batteries even worse so a very light low CCA AGM battery in a hot climate won't last very long. It is what it is- you'll just have to buy them more often. That's the price you pay for performance. If you care about battery weight you probably have a manual anyway so a dead battery every year just means you'd better know how to bump start (or have a jump box around.)
For the smaller batteries you'll have to fashion a decent hold down. There are battery hold down kits that are expensive, but honestly you can buy a couple of hooks and a bracket and drill the battery tray for a hold down that will cost a lot less. Vibration and moving around kill batteries and also will destroy your battery terminals. Make sure it is secured tightly. A rubber mat under the battery- like ones that Honda uses- will help to keep the vibration down and make the battery less likely to slide around in an over-sized battery tray designed for a Group 35 holding something much smaller. Make sure the hold down is well clear of the positive terminal.
guybo is offline   Reply With Quote
Old 08-01-2016, 11:03 AM   #55
WRBrzRX
Drives: runs&drives
this is down the list for me but someday:
http://www.kcmachine.com/products/su...ckage-preorder
WRBrzRX is offline   Reply With Quote
Old 08-01-2016, 12:05 PM   #56
'Cuz racecar.
Tow hook specs? mufasis BRZ First-Gen (2012+) — General Topics 15 10-21-2012 11:41 PM
Aftermarket battery speed-wiz Scion FR-S / Toyota 86 GT86 General Forum 59 08-08-2012 12:23 AM
BRZ CDN specs up at Subaru.ca! Sport-Tech CANADA 17 04-05-2012 10:12 PM
Aussie specs sneaky AUSTRALIA 7 03-14-2012 01:37 AM
Two Ft86 Specs for Aus church Scion FR-S / Toyota 86 GT86 General Forum 17 06-19-2011 08:53 PM
