#197 | |
Drives: 86 GT MT
I will make a procede map up to 80 column. And make sure there is one more column to the right, that the active throttle won't reach and appears redundant, populated with "100", to enabled me to get full voltage signal from the 80 column. After calibrating the throttle, the last column is reached/read by the active throttle. This is the problem. There is no "100" cell to the right, and I the previous results I posted showed this gave a lower voltage of 4.06V. However, if there was a "100" cell to the right of the active cell, then I would get full signal voltage of 4.95V. Last edited by keen as; 06-26-2016 at 01:03 AM. |
#198 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
That's just odd... Strictly from a programing sense either it's reading to the right of wherever the blue square is.... Or there's a major glitch in regards to what 100 is defined as. Try putting in 99 and see if that fixes the issue. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#199 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
So, since the last row has no cells to the right, then it should drop when it gets to full throttle. Now everyone needs to recalibrate their throttles so the max ends up in the 90 load column, that way full throttle gives full boost. It's tricky, but do-able. I'll do it tomorrow.
I already have a great tune, I just bumped up my boost by moving all the columns in my map one column to the left. It was a fun trip to the store and back, though my average mpg took a hit. There is still a slight voltage drop between the switch and the Procede, 5.21 versus 4.95, but that's close enough for me. @keen as, what is your cal id? I'll send you a copy of my tune for you to experiment with.
If I say yes, will that make you think I understand?
#200 |
Drives: 86 GT MT
That all makes sense. @KoolBRZ
I don't expect any difference between 5.21v and 4.95V. After I get my dump pack back in, I'll log boost to see if there is any change when I switch from procede to throttle switch. My Cal id is A01G, currently on E85 (it's really good when full boost working). I had help with a local guy to fix the lean AFR at low revs. He also helped with cold start. It's winter and in Sydney, Australia, 3degress Celcius low feels like an ice age!! So, don't go out of your way for E85 tune, thanks. |
#201 | |
P.S. @keen as, if you simply don't calibrate, it won't engage as soon because the lower throttle limit is too low.
#202 | |
Good to know. Thanks. But why didn't Shiv just tell us this in the first place? Also why is this springing up after the fact for some of us? Sent from my iPhone using Tapatalk
#203 |
How many of us actually measure voltage at full throttle? The rest of us just took it on faith. Kudo's to @keen as for questioning it enough to test it.
#204 | |
Hah me. I had my procede replaced for the same reason. But nice job you two on figuring it out. Sent from my iPhone using Tapatalk
#205 |
Calibration walk through
Here is how to do it. Turn on your car without starting it. Plug the Procede cable into your laptop. Open Procede software, click on the red connect button to connect. Wait for current map to load. If you are going to continue using this map, proceed to next step, otherwise, click open to load the map you want to use. Wait for map to load. Click on the Analogue Inputs link on the left-hand column to open it. Click and drag it to the left, so you can see the readouts on the right, as shown in the pic. Calibrate the throttle by clicking on the "Set Throttle" button once, step on the throttle several times, take your foot off the throttle, click the "Set Throttle" button once again, step on the throttle several times, WHILE HOLDING THE PEDAL TO THE FLOOR, click the "Set Throttle" button once again, release the throttle.
Now add about 40,+-5, to the Max Throttle field and click on the "Apply" button. Notice the Engine Load In % field changes with the throttle. Make sure that you add enough so that the "Engine Load In %" is between 92 and 93% when the throttle is pushed to the floor. Over 95% is too much, it jumps to the 100% column, under 85% is too little, it drops to the 80% column. 92.5% allows for some variance in the throttle calibration, but ensures full throttle is in the 90% column. Notice this Procede map is rescaled, and the last two columns are identical. Also the first two columns and the bottom two rows are the same to allow for Throttle calibration variance. It kicks in very early and strong.
![]() Last edited by KoolBRZ; 06-26-2016 at 02:26 PM. Reason: Balky attachment tool |
#206 |
Drives: Asphalt FRS 2014
No boost up top
I'm seeing an issue where I have no boost at throttle >= ~70%. @Sojhinn pointed me here, so I recalibrated my throttle as per @KoolBRZ's above instructions. My throttle is now 170 - 890 and with the pedal all the way down load is 92% and I'm in the 90 column on my map. But unfortunately I still have no boost up high (partial boost is working fine). Does my map look ok?
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
#207 | |
I'm assuming the box is moving to the right and up correct? Sent from my iPhone using Tapatalk
#208 |
Ya, it seems to be tracking both RPM and throttle input accurately.
#209 | |
Next step sucks... You need to measure voltage leaving the procede while the car is on and someone is pushing down on the throttle. You should be reading approximately 5v on full throttle. Sent from my iPhone using Tapatalk
#210 |
Does the engine need to be started, or is accessory mode enough? I have a multimeter, but how/where do I put the leads?
| What does your user name mean? | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 355 | 05-01-2016 09:52 AM |
| OFT: New firmware and new user software | Shiv@Openflash | Software Tuning | 9 | 10-15-2014 03:45 PM |
| EcuTek End User/Retail Tuning Software Release! | Dustin@Dynosty | Forced Induction | 27 | 12-19-2013 10:17 AM |
| user tags | scottmcphee | Site Announcements / Questions / Issues | 3 | 04-11-2013 04:15 PM |
| User name | trueno86power | Site Announcements / Questions / Issues | 7 | 11-28-2012 01:48 AM |
