Old 07-22-2016, 04:28 PM   #337
j_motion
Drives: 14 BRZ Red premium
Originally Posted by Rican_D View Post
Go under apps. Click on the one you wish to move and scroll down until you see the move to SD button.
Already done that .. i have move all the movable app to SD
But still have problem updateing apps like Google map.
and what is the Deal with the 12~16 gb of nand memory in the system, when you cant even use it.
j_motion is offline   Reply With Quote
Old 07-22-2016, 05:07 PM   #338
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
That should've done the trick, worked for me. Try clearing the cached data in the internal memory.
Rican_D is offline   Reply With Quote
Old 07-22-2016, 05:36 PM   #339
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by Kick Clutch View Post
besides the radio antenna adapter if you wanna use the radio and USB harness if you want to keep the factory USB jack and the steering control harness for the AUX
Thanks for the info. Just for my verification,
1) Antenna Adapter for Radio (https://www.amazon.com/Metra-40-LX11...&redirect=true)
2) USB adapter (https://www.amazon.com/AXXESS-AX-TOY...ords=AX-TOYUSB)
This USB adapter works for USB and AUX correct?
Also doesn't the harness that comes with this have these adapters (or at least the radio one)? The amazon listing says for BRZ/Camry/Corolla, so the harness hopefully is: https://www.carjoying.com/joying-har...ess-cable.html)
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-22-2016, 07:00 PM   #340
Kick Clutch
Drives: 2013 Scion FRS
Yeah those are the right adapters, I believe the USB adapter only works for the USB plug and not the AUX for AUX to work I think you need to get the steering wheel control harness. Correct me if i'm wrong.
The harness that came with my head unit that I bought model TQ123 did not have a radio antenna adapter or USB adapter. This is the harness mine came included with the HU https://www.carjoying.com/joying-har...head-unit.html
Kick Clutch is offline   Reply With Quote
Old 07-23-2016, 12:49 PM   #341
Baymax86
Baymax86's Avatar
Drives: Whiteout Monogram
Hi Guys i have a quick question.
So my joying unit keep on saying inefficient space when updateing apps.
I check the storage..
It show that there is 1 GB internal storeage
12GB Nand flash
and 2 aditional USB storage.
All the app seem to be installed in the Internal storage,
And the 12 gb of Nand flash space are not in use at all.
Is there any way i can shift apps into the free space in nand flash?
When i choose the preference installing location on the top of the storage tab.
it only show 3 option
Install in Internal storage
Install in SD
Let system decide.
how can i utilize the 12gb of Nand flash that is not in use ?
Are you familiar with custom Roms and rooting Android?
There is a custom ROM for these units that make them a lot better. Including using all the memory.
There is a lot to learn before jumping into installation. Like ensuring your unit is compatible with it. If you have a lollipop unit it most likely isn't but the KitKat ones typically are supported.
This thread is huge and a lot to go through but in here should be everything you'd need to learn about it all.
http://forum.xda-developers.com/show....php?t=3246370
Sent from my Nexus 5X using Tapatalk
Shameless Instagram plug : @BaymaxGT86
Baymax86 is offline   Reply With Quote
Old 07-26-2016, 04:24 AM   #342
j_motion
Thank you
I will look into it.
Old 07-27-2016, 01:23 AM   #343
l0aded
Addicted
l0aded's Avatar
Received everything today, I have a few questions about the install.
1) After re-pinning blue wire from #8 to #9, do I need to solder the blue wire on the antenna adapter to it on the FRS?
2) Do I need this harness as well for anything on FRS? https://www.amazon.com/Axxess-AX-TOY...&redirect=true
3) My Joying HU harness has no 28pin female connection, does the factory 28 pin plug into anything?
Earlier in the thread there was talk of something about the trigger wire for backup camera. Can anyone explain?
Thanks!
Old 07-27-2016, 10:18 PM   #344
djwishbone
Last Starfighter
Drives: 2016 FR-S Series 2.0
I'm trying to figure out what people are currently buying. I've seen links fly by for several different radios. Is this the current one people recommend?
https://www.amazon.com/Android-Lolli...android+toyota
A couple of questions.
The versions with 5.1.1 are you still putting a custom rom on it?
Anyone hook up the factory FRS backup camera to one of these yet?
Really excited to try one of these out!
djwishbone is offline   Reply With Quote
Old 07-28-2016, 06:46 PM   #345
arrow34
Drives: Firestorm red FRS 2015
I just got this https://www.amazon.com/Android-Lolli.../dp/B01I6LP464 . I hate the stock that came with my 2015. the BT sucks....
arrow34 is offline   Reply With Quote
Old 07-28-2016, 09:12 PM   #346
Rican_D
Rican_D's Avatar
That's the one.
Old 07-28-2016, 09:37 PM   #347
djwishbone
Last Starfighter
Has anyone tried the double din 7" screen version. I know the fitment isn't perfect but it might be nicer to have the larger screen?
Sent from my SM-G930T using Tapatalk
Old 07-29-2016, 05:35 AM   #348
Karl07
Drives: 2012 86 GTS - Storm Black
In using this at the moment.
It's the 7" universal joying with android 5.1.1 or whatever. I haven't modified it yet.
Tbh it looks very decent even though there are tiny gaps if you look side on.
It actually surprised me with its performance in sound, radio reception, mic, and responsiveness.
Karl07 is offline   Reply With Quote
Old 07-29-2016, 11:25 AM   #349
djwishbone
Last Starfighter
What dash kit did you use to install? It's hard to see if there are gaps on the side in your photo?
Anyone try this version? Any idea what the difference between it and the one above is?
https://www.amazon.com/dp/B01EG4S20K..._Rr2Mxb9C2JMND
Old 07-30-2016, 08:03 AM   #350
Karl07
I'll grab some better pics tomorrow.
Actually used the frame cover it came with but had to trim a little to make it sit nicely.
When it came to positioning of the unit it was a choice of either pushed in a little or sticking out a little.
Looked better sunk in.
I just didn't want to modify the actual car trim.
From what I can see its just a different positioning for the same buttons on that one you posted. They all seem to have the exact same processor, screen, etc.
I liked mine because it doesn't have a big ugly JOYING logo front and center. If it did I would have had to remove it or cover it.
The only thing I still want to do is get the adapter for the stock USB ports as I didn't have that so I am using the Y cable it comes with.
This has the WiFi dongle in the glove box and the other is near the OBD2 port as I chose to purchase a USB OBD2 adapter versus a Bluetooth one.
Amazingly I can't recommend this unit enough. Value for money it is hands down perfect.
I have only three little complaints
- not Toyota sizing but I'm very happy with fitment anyway.
- only has one micro sd slot which is by Standard taken with the iGO GPS software (I am going to try having the files on the unit or just put them on my 64gb music micro SD...see what happens).
- SOMETIMES if I turn the car off while listening to music on the micro SD it will remember where I was when I start again, other times it skips to a different song completely...usually one that was just played before and even though it was on random it will pay in the same order again.
First world problems...
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 01:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 12:55 PM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 12:57 PM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 06:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 03:42 AM
