Old 09-04-2016, 12:11 AM   #1
akyp
Drives: 2012 86
OEM small(er) battery tray - Installed
While researching replacement for my OEM battery I came across this: http://panasonic.jp/car/battery/teki...a&cnm=%82W%82U
The JDM 86 came from the factory with a smaller 34B19R (thus lighter) battery, except 'cold climate' cars which get 55D23R. For whatever reason, the rest of the world get 'cold climate' cars with 55D23R (RHD) or 55D23L (LHD) batteries.
I asked around and turns out it was a very easy conversion to use the smaller size battery. Source (Japanese): http://minkara.carview.co.jp/userid/...7169/note.aspx
You need to order 3 parts (the 3 parts below the purple battery in the photo above):
SU003-02412 Battery pan
SU003-02414 Rod
SU003-02418 Holder
You also need these to convert the smaller terminals on the smaller battery to be compatible with the connectors: http://www.zoomerroo.co.uk/small-pos...is-to-sae.html
OR you could order more OEM parts to convert the car connectors to smaller ones, but you need to figure out the exact parts needed as I was not resourceful enough to do so (the diagrams confused the hell out of me ).
Result below. It was as easy as swapping in another OEM battery. Actually it's easier as the smaller battery means the Radium catch can I have no longer gets in the way.
Compared to the OEM battery, this saves anywhere from 2.5kg / 5.5lb to 6kg / 13.2lb depending on the particular battery you can buy. In where I live people are crazy about 'blue' (Panasonic CAOS) and 'purple' (GS Yuasa ECO.R) batteries so those are the only ones available. Unfortunately those are actually heavier than the OEM Panasonic. To make things worse nobody imports them at B19R size as no other car uses that size, so I had to settle for the heavier B20R size. Still I think the conversion is a no-brainer as the price difference between B20R and D23R sizes alone is more than enough to pay for the parts.
Compared to existing lightweight battery solutions, this is nowhere as light (11kg / 24.2lb) but at just a fraction of the cost. Apparently there are 4.5kg batteries available for the size (see Japanese link above) so there is more weight savings to be had. This conversion is also 100% OEM for those who care.
Battery weights:
OEM Panasonic 55D23R: 13.5kg / 29.7lb
Panasonic CAOS Pro: http://panasonic.jp/car/battery/caospro/cp01.html
Panasonic CAOS: http://panasonic.jp/car/battery/caos/ca09.html
GS Yuasa ECO.R: https://gyb.gs-yuasa.com/product/carbattery/ecor_ll/
akyp is offline   Reply With Quote
Old 09-06-2016, 02:34 AM   #2
drift86
Drives: GT86, 22 BRZ
SU003-02414 Rod
SU003-02418 Holder
Are these Toyota or Subaru part numbers?
drift86 is offline   Reply With Quote
Old 09-06-2016, 03:06 AM   #3
akyp
Drives: 2012 86
SU003-02414 Rod
SU003-02418 Holder
Toyota. I got the parts from a Toyota/Lexus parts supplier.
Old 09-06-2016, 04:44 AM   #4
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Thank you for a great find like this. 😀 Now I know where to get a cheap battery tray when I get a smaller battery.
Old 09-07-2016, 04:14 AM   #5
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Any other pro and cons besides weight reduction?
Sent from my SM-P600 using Tapatalk
turtlefeeder is offline   Reply With Quote
Old 09-07-2016, 10:09 AM   #6
akyp
Drives: 2012 86
If you live in a cold climate it might be wise to stick to the bigger battery.
With the bigger battery I have jump started my dad's car with a V8. Now I would think twice about that.
Other than that I can't think of any drawbacks with the smaller battery.
Old 09-07-2016, 10:44 AM   #7
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
SU003-02414 Rod
SU003-02418 Holder
Can someone help us out with Subaru part numbers?
JazzleSAURUS is offline   Reply With Quote
Old 09-07-2016, 11:34 AM   #8
celek
Resident Gear Head
celek's Avatar
Cold cranking amps as mentioned in another quote colder climates where freezing temps occur the oil is like sludge and to get the car started the smaller battery may not be able to do it. Temp effects amperage just like commonly when cold out batteries are weaker.
celek is offline   Reply With Quote
Old 09-07-2016, 11:49 AM   #9
JazzleSAURUS
Pros: Weight reduction, most likely able to handle an AGM LW in an OEM like fashion. (I intend on doing this with an Odyssey PC680.)
Cons: Can't listen to your stereo for hours with the ignition off....
A lot of the pros/cons will vary depending on which battery you pick. A lot of lightweights are finnicky with how long they sit, and how you charge them, and cold weather, others are more stable than a typical lead acid at temp, and can sit longer as long as there is minimal drain on the battery.
Old 09-07-2016, 04:38 PM   #10
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
so what is the cost?
Old 06-25-2018, 02:49 PM   #11
wulfstan
Drives: 2014 Whiteout Monogram 6MT FR-S
Cool
This thread helped me get all the parts/pieces to make an Optima Yellow Battery install. Thought this might be helpful as well, it's a link to the Optima Battery install I did... has pictures toward the end.
http://www.ft86club.com/forums/showthread.php?t=117178
BTW the D51R Optima Yellow top was $214.19 +13.54 tax = $227.73 ($12 core deposit, so actually $215.73, with 10% discount) military.
wulfstan is offline   Reply With Quote
Old 06-25-2018, 04:56 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
IIRC most in EU had 48Ah Panasonic battery fitted stock. But for many it went flat even in first year and in most cases Toyota replaced for free with 65Ah one. So far i hadn't have replacement go flat, so unless it's for track day only, i'd never think of less capacity for daily driven all year round. And if weight at track is reason for temporary switch, then imho even much smaller/lighter batteries make better choice, as compromise of something in between will be jack of all trades/master of none. Not as light at track, and not with capacity for carefree daily driving.
Lightweight battery that fits the stock tray and tie down? SPCorBUST Engine, Exhaust, Transmission 40 01-11-2021 11:46 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Shorai Battery, Tender, and PTuning Tray jack43 Engine, Exhaust, Bolt-Ons 4 08-23-2014 12:42 PM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 09:55 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
