Old 10-14-2016, 05:06 PM   #1
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
2017 BRZ On Dyno vs 2013 FRS on Dyno
Zaku from FT86club.com getting a baseline for the 2017 BRZ
Vid is here for pretty much no reason hahaha
[ame="https://www.youtube.com/watch?v=bESpElAWeH4"]Zaku 2017 BRZ on PTUNING Dyno - YouTube[/ame]
The car is baseline about 400 miles after break in
The 2017 average about 177-178whp on Dyno.
The 2013 FRS of similar mileage Dyno is 159-160whp
The 2015 BRZ of similar mileage Dyno is 163-164Whp
Graph will be provided below,
https://imgur.com/a/qJTgR
My apologies that 2015 data is missing, this is a quote from 2015 owners.
for fun there is a 13 with E85 added into the mix
Also provided is a Data of a Stock FRS from 2013 and one with E85
Please remember this is mostly to give an idea but is not very technical data. Things like temperature and humidity can effect Dyno data greatly.
I mostly did this to know where my car stands atm, thanks Enjoy.
Special thanks to @ptuning @Mrc@ptuning
Old 10-14-2016, 05:29 PM   #2
max20s14
Drives: 14' Raven M/T - 02' is300
Now there needs to be a 2017 dyno thread! xD
max20s14 is offline   Reply With Quote
Old 10-14-2016, 06:18 PM   #3
Lantana frs
Drives: 13 frs red
It will be interesting to see tuning results on the 17. One reason I think this comparison is legit is the convergence of tq and hp when it climbs out of the dip.
Lantana frs is offline   Reply With Quote
Old 10-14-2016, 06:25 PM   #4
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
In which gear did you make these dynos? Thanks.
Old 10-14-2016, 06:29 PM   #5
DarkSunrise
DarkSunrise's Avatar
Looks about right to me. The general shape of your torque curve comparison chart (2017 vs. 2013) looks almost identical to the OEM comparison chart, except maybe the very top-end:
Appears the 2017 models will be slightly quicker.
2022 BRZ Build
2013 FR-S Build
Old 10-14-2016, 06:51 PM   #6
Zaku
Zaku's Avatar
@Mrc@ptuning could you please answer?
Old 10-14-2016, 07:21 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Gains are small, but then again changes were not that big off to start with. Free-er flowing airfilter (thus +5whp from dropin aftermarket filter in pre-17 will put curves much closer), slightly wider diameter header tubes, slightly less sharp angled intake tube, a bit reworked throttle spider. I guesstimate for butt dyno to feel acceleration differences from fitted as stock different ratio FD way more then from engine changes. But it also can be retrofitted with ease.
I'm more liking possible handling improvements from sach dampers & more rigid body, also more usable 'track' mode. VSC Sport was too intrusive.
Old 10-14-2016, 11:31 PM   #8
justinco
justinco's Avatar
Drives: 2022 GR86
Nice, not bad at all.
I'm getting ready to do the exact same thing next weekend to compare my '13 FRS to my '17 BRZ.
justinco is offline   Reply With Quote
Old 10-15-2016, 01:35 AM   #9
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Would the 2017 4.3 rearend have any affect on the dyno readings vs a 2013/2015 with 4.1 rearend?
JimmyMac is offline   Reply With Quote
Old 10-15-2016, 01:49 AM   #10
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
If the dyno was made on 3rd or 4th gear, then yes. It'll give higher numbers. That's why I questioned this before. In general, a shorter final drive ratio and changes on engine internals with less friction, helps to provide more power on the wheels under hard acceleration. There were many discussions on such differences with @justatroll.
Old 10-15-2016, 05:14 AM   #11
CSG Mike
CSG Mike's Avatar
Actually, higher gears put down higher numbers with this car, at least on an inertia dyno.
Old 10-15-2016, 09:32 AM   #12
Teseo
Drives: frs
That 18.5hp difference is starting to bother me
Old 10-15-2016, 11:23 AM   #13
Lantana frs
Drives: 13 frs red
Imo the difference is probably 10 to 12 horsepower when both ecus are on the same page.
Old 10-15-2016, 03:03 PM   #14
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Is that a manual 2017 with the new Aluminum Intake bychance? Because the motors can be entirely the same. With the new intake the car may have a more aggressive tune.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Looking for a 2017 GT86/BRZ for dyno tuning/testing Shiv@Openflash Northern California 0 10-11-2016 09:10 PM
Shiv dyno day 2 in lewisville, OFT users custom dyno tunes malubawla Southwest 14 11-21-2015 02:53 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 04:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 08:00 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 09:06 AM
