Old 10-17-2016, 10:20 AM   #57
Originally Posted by DarkSunrise View Post
I would guess it's the shape of the rear section of the OEM airbox. Most aftermarket oil coolers use a sandwich plate that routes the oil lines past that rounded off portion of the airbox (back right on pre-2017 models). It looks like that portion of the airbox is now square on the 2017 models based on that picture.
Not sure what solutions the aftermarket will come up with, but a Perrin-style CAI (long tube into bumper cover) might be an option. The Mishimoto oil cooler might work as well given the way it angles its lines.
Yep. When you are talking a space as crowed as the engine bay of these cars a 1/2 inch can be the difference between fitting or not a hope in hell.
Old 10-17-2016, 12:36 PM   #58
CSG Mike
CSG Mike's Avatar
I've seen too many Mishimoto oil cooler cars catch fire on track.
Sorry, but pass. I don't want to be checking the banjo bolts every session.
Absolutely correct; the more "square" rear makes it so 2 lines cannot fit side by side back there...
Old 10-17-2016, 01:29 PM   #59
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
My mind didnt even go to the fittings (mind you this was pre-caffeine), but that makes perfect sense. Well aftermarket loves to create intakes, so i am sure this will be addressed here shortly. Easier to fix the air box, than to re-route or relocate oil lines or components.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 10-17-2016, 10:00 PM   #60
CSG Mike
CSG Mike's Avatar
Most aftermarket intakes are a direct bolt-on to the 17, same as a 13-16, so in that regard, the problem is already taken care of!
Now, if for some reason the car is restricted to the OEM airbox...
Old 10-17-2016, 10:06 PM   #61
CSG Mike
CSG Mike's Avatar
This is happening.
Gotta make sure things stay looking fresh.
https://www.instagram.com/p/BLq8ASdjgdy/
Old 10-17-2016, 10:11 PM   #62
gramicci101
Off Topic
That's the one thing I regret not doing as soon as I got my car.
Old 10-18-2016, 05:47 AM   #63
ajc209
Drives: GT86 Cosworth
FWIW I am using the mishimoto banjo fittings but with a mocal oil to water laminova. They started to seep oil a little bit after I initially installed them.
I tightened them up but I added anti tamper paint so it would be obvious if they start coming lose. Its usually vibration that causes them to come lose, so need to make sure there is some play in the oil hose.
Just my 2 cents. I was very nervous using them and was checking under the bonnet every time I used the car for a while. Its now done 3 trackdays and about 5k road miles. If I get them come loose again they will go in the bin and I'll live with 10min track sessions until I can figure out a better solution.
ajc209 is offline   Reply With Quote
Old 10-18-2016, 03:12 PM   #64
CSG Mike
CSG Mike's Avatar
Even 10 minutes is too much if you're redlining. I recommend you keep an eye on your oil temps!
Short shifting will work, if your primary goal is car control rather than chasing lap times...
Old 10-18-2016, 05:11 PM   #65
ajc209
I think you misread me. I wasnt being precise about 10minutes, I just meant I'll live with shorter sessions. Oil Temps with my cosworth sc stay below 115C in 25C ambient! Even after 30mins of hard track abuse.
Stock I would hit 140C within a 20minute session on cooler days.
Old 10-18-2016, 05:56 PM   #66
CSG Mike
CSG Mike's Avatar
Ahh gotcha.
Yeah, the extra torque helps, especially when you don't need to rev as much!
Old 10-18-2016, 06:07 PM   #67
DAEMANO
Time Traveller
If the clearance is right and if the quality is up to par, and if you can source the sandwich plate from the SARD oil cooler kit, it might do the trick. @nigel-jdmparts might still have a lead. Still looks tight to me.
http://www.more-japan.com/blogs/2013...rs-subaru-brz/
Old 10-18-2016, 06:16 PM   #68
ajc209
Originally Posted by DAEMANO View Post
If the clearance is right and if the quality is up to par, but if you can source the sandwich plate from the SARD oil cooler kit, it might do the trick. @nigel-jdmparts might still have a lead. Still looks tight to me.
Now that looks nice! Is it good quality though?
Old 10-18-2016, 06:25 PM   #69
ajc209
Ahh gotcha.
I'd still say the sc puts more heat into the oil though, but the laminova works a treat and doesn't over cool in the winter on the street.
Old 10-18-2016, 07:06 PM   #70
CSG Mike
CSG Mike's Avatar
SARD is legit!
Mad Mike's Firestorm Build Mad_Mike Member's Car Journals 91 07-26-2026 01:09 AM
My thoughts on my build (Down South in Africa)! 86 South Africa Member's Car Journals 2 02-02-2016 08:55 AM
Mike&Ikes WRB Build Mike&Ike Member's Car Journals 8 09-18-2015 04:12 AM
Mike Mac's Raven FR-S NYC Build ScionFR-S Member's Car Journals 5 06-07-2014 02:49 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 10:11 AM
