Old 11-16-2016, 12:43 AM   #1
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
GReddy X KW
http://www.greddy.com/products/suspension/greddy-kw/
Apparently new collaboration between the two! Any one got any info on these?
$1450 MRSP
Car Year:2012-16Notes:Scion FR-S / Toyota 86 ZN6 (4U-GSE) or Subaru BRZ ZC6 (FA20)
Spring Rate: (Linear)
Front: 6.0 K
Rear: 7.0 K
Adjustment Range:
Front: 20-50mm
Rear: 20-50mm
Adjustable Front Top Hat
Features:
  • Externally Adjustable Damping
  • Adjustable Aluminum Spherical Bearing Upper Mount (F)
  • Low Profile Helper Spring Set-up
  • Hardened Chromed Piston Rod
  • Low Friction Twin-Tube Dampening
  • Compression Bumpstop with Intergrated Dust Boot
  • Hight Strength Race Spring
  • Corrosion-resistant Composite Spring Seats
  • Galvanized Strut with Continous Threads
Includes all nceessary componets, adjustment tool and installation instructions
Part #:14016101Price:1450.00
umpadupa is offline   Reply With Quote
Old 11-16-2016, 03:37 AM   #2
sugoi
Drives: 2015 BRZ Limited CWP
Looks similar to ST XTA coilovers in terms of terms of construction (galvanized steel instead of stainless used in KW) with a stiffer rear rate:
http://www.ft86club.com/forums/showthread.php?t=100030
sugoi is offline   Reply With Quote
Old 11-16-2016, 10:41 AM   #3
15limited
15limited's Avatar
Does twin tube mean compression and rebound are independently adjustable?
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 11-16-2016, 11:33 AM   #4
bfrank1972
Drives: 2013 FR-S Argento
Nope
Old 11-16-2016, 11:39 AM   #5
redlined600
redlined600's Avatar
Drives: Fr-s
It refers to the construction of the shock.
A simplified explanation
Twin tube = a tube within the shock body, the inner cavity housing the piston/shaft and oil and the outer cavity being mostly gas
Monotube = the shock body houses the piston/shaft, oil and gas with a sliding divider between the gas and oil.
redlined600 is offline   Reply With Quote
Old 11-16-2016, 12:21 PM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Yeah it has that same gold colored metal body as the ST, but I think/hope this is more than a simple rebrand.
Originally Posted by baorz View Post
Looks like rebranded ST XTA coilovers with a stiffer rear rate:
Originally Posted by humfrz
I'm old and lazy
Old 11-16-2016, 02:02 PM   #7
sugoi
Saying rebrand is a discredit to the work they do at Greddy. I'm sure that it's built to Greddy's specifications based on their own R&D.
Old 11-16-2016, 02:26 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
I didn't see revalving of dampers mentioned in feature list though. They surely would have mentioned that if it had been done for extra "features"/better sales, no?
Old 11-16-2016, 02:44 PM   #9
sugoi
Maybe the existing damper didn't need to be revalved to accommodate different spring rates.
OR
Revalving would imply there's another variant of the suspension, thus cannibalizing sales of this Greddy x KW one. From my observation, ST isn't as marketed as heavily as Greddy.
Old 11-16-2016, 03:09 PM   #10
driggity
Drives: Silver Coupe with a Boxer
They probably don't list it under features because the description for the whole line of coilovers states "with unique GReddy specifications for damping".
driggity is offline   Reply With Quote
Old 11-16-2016, 03:43 PM   #11
umpadupa
umpadupa's Avatar
its prob a rebrand but at the same time, greddy most have selected their own spring rates/valving not to mention if you look at one of the photos there a little "rebound" adjustment knob, maybe it double adjustable?
Old 11-16-2016, 04:30 PM   #12
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I would venture it's rebound only adjustment. Most singles are rebound only or if adjusting both skew heavily towards rebound vs compression
Old 11-16-2016, 04:38 PM   #13
Tor
Tor's Avatar
Drives: Toyota GT86
I started the ST XTA thread mentioned above. I think these GReddy branded coilovers looks like a great option for you guys in the US!
But just to set some facts straight:
ST is just a brand of KW, I even got mine shipped direct from the KW factory near Stuttgart. So just saying what might not be obvious to everyone, ST is KW.
"GReddy US" on the other hand, is a US dealer of the Japaneese manufacturer "Trust". In japan "GReddy" is just a product series of Trust.
Hence, I doubt the US GReddy dealer did any research or development of these dampers. KW already have 6/7 springs as an option on the Clubsport coilovers, so they would already have all the information to change the valving to those specs. Frankly, if I were to get the GReddy coilovers I would prefer the R&D would have been done by those who have the expertise: KW.
**EDIT: Check post 18. Not sure if Greddy got their info mixed up, looks like the spring rate in the rear is 5 kg, same at the XTA. ***
As for the spring rates:
The 6/5 needs a more rear swaybar in my opinion. 6/5 is not understeery at all with the right setup. I think it works pretty well on track. Below my lastest track video with the XTAs. Additionally, I have ST 2-way adjustable swaybars, with the front set to soft and the rear set to hard. I run 2.8/2.0 deg camber front/rear.
The short version:
If I was looking for sub-1500$ coilovers, and I was in the US, this new offering from GReddy would definitely be on my list and I would probably choose them over the XTAs. I think they will run great on stock swaybars.
Tor is offline   Reply With Quote
Old 11-21-2016, 11:08 PM   #14
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
I have the original version of ST coilovers for the 86. What annoys me is this past year creaking/clunking started to develop and did not go away after retorquing everything. Also took months for the height to fully settle (had to raise it 3 times because height kept drooping). For peace of mind I was thinking of TRD coilovers (pricey but their parts have given me 0 problems for over a decade on multiple platforms).
These GReddy X KW coilovers got me reconsidering. Exterior construction looks too similar to my ST and makes me hesitant I will get the same drooping and noise issues. But Tor's thread makes me think these are higher build quality. Thoughts?
Greddy Base Map for FRS Greddy Turbo Kit hiranak Software Tuning 10 10-27-2014 07:55 AM
*** [DECIDED] GReddy *** Full Blown vs GReddy slisgrinder Forced Induction 31 08-13-2014 03:24 PM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 07:09 PM
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 09:13 PM
